Question about Kenmore 95592 / 95594 / 95595 / 95599 Electric Kitchen Range
THE STOVE WONT TURN ON. I DONT KNOW IF IT IS A FUSE, CAN'T FIND THEM ON STOVE
  • 3 more comments
  • JUAN_H77 Oct 04, 2008
    kenmore classic c880.644020L0
  • richrat21 Nov 26, 2008
    790 model number
  • Anonymous Nov 27, 2008
    it will only pre-heat once pre-heating is done it no longer heats up
  • vh0698 Dec 22, 2008
    Oven made a popping sound and shut off in the middle of cooking. Won't turn back on.
  • bmader May 11, 2010
    oven won't turn on
Same problem.
Posted on Nov 26, 2008
  • 796 Answers
Can you tell the model number
Posted on Oct 04, 2008
How does the top open is it lifting from front of stove top or threar of stove top
call a repairman being a GAS unit I will not recommend DIY the explode if not done properly SORRY
Feb 03, 2016 | Magic Chef 31000 Gas Kitchen Range
Why wont my oven work after a fuse was blown in my home?
There isn't more information listed about the brand and type, so I'll give you a couple of options that could be a problem. In most newer ovens, the burner is lit by a ceramic heating element that glows when the oven is about to come on. If it is cracked (coincidental from blowing the fuse, not related unless the fuse blew during an earthquake or when the oven was on), the circuit won't turn on the gas or make any noise. It may also have been getting old and weak, and if the oven was moved to troubleshoot the problem, it might fail from the movement. They do go bad eventually. You should order a spare online if you can find the part number because if you have to buy it from the appliance store at a moment's notice, you will pay a LOT more for it.
That's the most likely thing and easiest to fix. The next guess is that the oven switch itself (controller board if electronic) could have been fried by whatever blew the fuse (power surge, lightning etc).
Aug 27, 2014 | Kitchen Ranges
Hotpoint electric stove burners wont heat up
Water ingress has taken the trip out i expect. If only clean water, it may dry out and then you can replace the fuse/breaker. If in doubt, employ a service engineer.
Dec 21, 2017 | Kitchen Ranges
We are past due on paying our electric bill; hence we a a cutoff in our power... though we were told we will have basic electricity... the lights are on .. but we can use the stove only if we turn the...
There should be a disconnect or switch at the furnace, otherwise you'll have to go to the Main circuit breaker or fuse panel and hope the circuits are identified correctly and turn OFF the circuit breaker or unscrew the fuse. If the panel isn't labeled, just turn OFF the single pole breakers until the furnace turns OFF.
Jan 20, 2011 | Electric Circuit Breaker Kit for Furnace
All stove top elements and oven wont work
Go to your home circuit/fuse panel and reset the fuse or circuit breaker for the range.
Dec 30, 2009 | Frigidaire FEB27S5A Electric Single Oven
The ac/heater wont turn on. i checked the fuses
It is possible but not very likely. check your floor console fuse block and look at fuse 25(blower) or fuse 26(temp motors)
Nov 21, 2009 | 2004 Buick Rendezvous
Creda Concept Superglow Stove
I fiddled with the buttons until the oven came on. Dont know which buttons but working now. Thnx
Jul 18, 2008 | Ovens
Tappan gas stove
try it on broil and let me know if that works dont rate me till we are done though
Jan 10, 2008 | Tappan TGF320 Gas Kitchen Range
Kenmore 95592 / 95594 / 95595 / 95599 Electric Kitchen Range Logo
398 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
