Question about HP Computers & Internet
The driverfor my hp w2007 wide lcd monitor didnt load..windows located the driver but when it tried to install ..access was denied
  • 661 Answers
My hp w2007 turned blue after I moved it how do I access screen display from the monitor menu
Some monitors change colour if there is damage, internally, within the signal cable. Try another cable if you have one.
Alternatively, it might be that the monitor is near an extremely strong magnetic source, such as big loudspeakers?
Mar 11, 2015 | HP W2007 LCD Monitor
My HP W1907 monitor needs a driver update. Told access is denied
yes the monitor bad , which means your lcd lamps gone ....
May 09, 2010 | HP w1907 LCD Monitor
HP w2007 LCD monitor goes off Monitor going to
Make sure that everything is connected to the monitor properly. Go to the back of it and make sure the VGA or DVI cables are secured and then check the back of the computer to do the same.
Sep 16, 2009 | HP W2007 Desktop Monitor
BRAND NEW MONITOR OUT OF THE BOX? DRIVER WILL NOT LOAD. DRIVER WONT LOAD FOR HP W2007 WIDE LCD MONITOR (32 BIT) HAVE DISK. (STILL WILL NOT LOAD)
This monitor doesn't need a driver installed. If you can see an image on it, you don't need the driver for it. Windows will install the default monitor driver, and that works for 99.99% of monitors on the market. You need to go into the Display control panel and change your resolution. If the monitor's native resolution isn't available as an option in the control panel, it's because your video card can't display it, not the monitor's fault.
Jun 17, 2009 | HP W2007 LCD Monitor
I just purchased an HP w2007 hp monitor. After going through all the suggested start up routines, images are stretched horizontally. I'm using XP home edition with sp 3. My resolution doesn't seem to go...
if it's a wide screen monitor then the monitor is likely doing the stretching and you have to adjust using the monitor controls (either buttons on the monitor itself or it may have come with software as well if you loaded a CD when you first installed).
Mar 31, 2009 | HP W2007 LCD Monitor
Unable to install HPw2007 Monitor
I would like to inform you that if you are using HP PC, then there is no need to install the drivers from the disc provided with the monitor. HP PC already has in-built monitor drivers. The default account in Vista from first boot is an admin account, monitor should plug and play and the correct INF file will install for the monitor.
Still, if you want to install the drivers from the disc provided with the monitor, then please follow the steps given below:
== Disable UAC settings ==
You might get access denied error message while installing the monitor drivers.
The error message might come up if the UAC (User Access Control) in Microsoft Windows Vista is kept enabled, hence not allowing the installation.
To resolve the issue please follow the steps given below :
1. Click Start
2. Click Control Panel
3. Click User Accounts and Family Safety
4. Click User Accounts
5. Click Turn User Account Control On or Off
6. Uncheck the checkbox
7. Click OK
You will need to restart your computer for the change to take effect.
Now try to install the monitor drivers and check for the results.
If still the issue persists then :
Step 2 :
1. Click Start -> All Programs -> HP My Display -> Display Diagnostic Utility.
2. In the Display Diagnostic Utility click on “Clear Registry”. A Clean Reg Window would open, Click on “Yes”
3. On restart you will have “Other Devices” with “Generic Monitor” List under that same.
4. Continue the process of “Clean Registry” until you get “Other Devices” with “Generic Monitor” listed under that same.
5. Now insert the disc and install the drivers.
or Download the HP w2007 LCD Monitor Driver from the weblink provided below :
ftp://ftp.hp.com/pub/softpaq/sp39501-40000/sp39950.exe
Now install the drivers.
6. Restart the computer.
7. This time it says "new hardware found with recommendation to install".
8. Cancel it.
9. Immediately, it gives option "Do not show the message again" and also says computer won't function if we select it.
Proceed by check marking it. You may be prompted to check mark it twice if prompted.
10. Restart the computer to check for the error message.
It will no more ask to install the monitor drivers.
Take your time, please try the steps and get back to us with the results.
Jan 24, 2009 | Microsoft Xbox 360 Console
HP w1907 monitor driver software will not load
"Access is denied" is the key here. It sounds like your login in windows does not allow you the privileges for that installation. Try logging in as an administrator and re-installing. One thing bothers me though, if this was purchased as a system, why would you need to install drivers? that should have been pre-installed.
Dec 14, 2008 | Computers & Internet
Can not load f1903 software on microsoft xp system
This has nothing to do with your monitor. Windows has default drivers that will be installed for that.
The problem will be your video card drivers are not installed.
Get the right drivers for your card, install them and you should be away.
Mar 29, 2008 | HP Pavilion F1903 19" Flat Panel LCD...
Computers & Internet Logo
56 people viewed this question
Top HP Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
