Philips 32PF7521 DTV My tv has stopped working and I cannot reset it to factory default setting. An F appeared in the top right corner last night, and today I could not get DTV to work, though analogue and the ext 1 and ext2 sources did work. I tried to reset to factory settings by pressing menu for 5 seconds in order to reprogramme the DTV channels and now nothing works. The TV will switch on in DTV mode the screen turns blue for a matter of seconds and then switches to black. It will not switch to anologue or ext1 or ext 2. What can I do?
  • 476 Answers
SOURCE: 26PF5521D wont show menu after reseting factory defaults
Switch the TV to analogue mode (if possible)
Press and hold the "MENU" button on the side of the TV. The settings menu should appear. Continue to hold the menu button until this menu disappears. (If you let go before the menu disappears, start again)
The TV should now go blank for up to 2 minutes, and then revert to factory settings and intitial installation screen.
Procede as per original installation.
Posted on Feb 16, 2008
  • 203 Answers
SOURCE: I have a samsung 32"
In the menu you should find an option to program the channels. Occasionally you have to reprogram them as I do on my own samsung and the ones I repair.
Posted on Jul 18, 2008
  • 6966 Answers
This is an internal weakness of the video source selection circuitry and perhaps your best bet would be to seek service/replacement from the point of purchase/dealer. Technically, it is "signal bleedover" or "video splatter" and has to do with shielding/grounding but again internally. Best temporary fix is to power off the video source plugged into EXT2. Alternately, you can try switching them around, make the DVD EXT2 and the Satellite EXT1.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Jul 21, 2008
  • 2071 Answers
SOURCE: Hi , Got a philips
All system, geometry and white balance alignments are performed in production service mode. Before
starting the production mode alignments, make sure that all manual adjustments are done correctly. To
start production mode alignments enter the MENU by pressing “M” button and then press the digits 4, 7,
2 and 5 respectively. The following menu appears on the screen
There are 3 submenu in service menu. These are display, calibration and deinterlacer menus. Press
“◄/►” buttons to select a menu title and then “▲/▼” buttons to select a menu item and “◄/►” or “OK
buttons to set the menu item to the desired option. To exit the service menu press “M” button.
Entire service menu parameters of Plasma TV are listed below
13.1. display menu
By pressing “◄/►” buttons select the first icon. display menu appears on the screen.
blank color
By pressing /. button, select blank color. Press ./. button to set the blank color. The options are:
black, red, green and blue.
Displays panel resolution
power on time
factory reset
By pressing /. button, select factory reset. Press “OK” button to return to the factory setting values
Posted on Jul 30, 2008
samsung advised  atv/dtv selection by that button not available on australian series 6
Posted on Sep 23, 2008
After switching off and on last night the volume and mute on stopped responding on Humax remote. IT is PVR9150T and remote RT531B. TV Remote works fine with volume. Humax remote works fine on all exce
Note that this type of device is designed to be left on at all times, so should not be switched off each night. I suspect that it has some slight corruption in the user-settings, so a factory reset may be required.
Apr 03, 2014 | Humax Televison & Video
Need information on a philips t.v. model 32PT6441/37
Resetting the TV
If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
hope this may help;
Aug 12, 2008 | Televison & Video
How to reset my Tv Plasa Philips model 42PFP5532D to factory (hard reset) ?
To reset to the factory default settings, press and hold down the MENU key on the side of the TV set for 5 seconds. A menu will appear on the screen with language and etc. If you want to, set everything like it was your first time with the tv.
May 26, 2011 | Televison & Video
The number of the selected programme does is permanently displayed at the left top corner of the screen. I tried to plug out the TV but the problem persists.
Tries used ur tv remote and go into the tv MENU and tries go down to do a resetting to the tv back to the factory setting to every funsctions,to every funsctions setting of the tv menu of setup setting menus like PICTURE,SETUP,OPTION.By resetting all these menus setting back to the factory settings,tv should have a great chances to get ritting of the permanently dispalyed on the left top corner.
Apr 08, 2011 | Philips 32PFL3403D/27 32 in. LCD TV
Key lock on
Your Dell tV can be unlocked by reseting it to factory reset.
To reset it to factory reset do the folloing.
Enter the TV main Menu.
Select Factory Reset to return the TV Menu settings to the factory default values
NOTE: Before you proceed with the Factory Reset, enter a four-digit access code. The Factory Reset and
Parental Control always share the same access code. The default Parental Control code is 3355
NOTE: Parental Control setting can be reset by doing factory reset
If you ar unable to do this proceedings, do the unlock method used for Philips, and your TVs kit is of Philips.
Philips sets use a four digit code to control the v-chip. The override code for Philip sets is 0711, although it may say "Incorrect code" the first time to trick you. If "Incorrect code" is displayed, simply enter 0711 again. To use it hit the MENU key to get to the menus. Go up or down until you reach AUTOLOCK or SMARTLOCK, depending on the model, and push the "right arrow" key on the remote. Enter the override code, and enter it a second time if it says it is incorrect.
Once in the AUTOLOCK or SMARTLOCK menu, go to BLOCK, and push the "right arrow" key. Go to BLOCKING OPTIONS and press the "right arrow" key. Go to MASTER DISABLE and press the "right arrow" key so that it says "MASTER DISABLE ON". The v-chip is now reset.
Feb 01, 2011 | Dell W4201C 42 in. Plasma HDTV
Factory reset on my philips s42sd tv
philips s42sd ydo7 this tv turns on an off thats it no pic no and again dtv flashies up in top left hand cornor ne one got a clue <!-- from fixya rte -->
Oct 03, 2009 | Philips Televison & Video
Yellow Line at the Top of Screen
Try doing a system reset. Not sure it that's the term they use but that option basically resets the tv to factory default settings. It's in the menu somewhere. I've done the reset twice already for a similar problem. Solved it each time.
Jun 05, 2008 | Toshiba 42HP95 Television
Oct 26, 2007 | Philips 26PF5521D 26 in. HD-Ready LCD...
'F' displaying on screen and remote not responding.
Excavated with Google from Philips website: " When a letter F appears on the right hand corner of the screen it means the television is in factory mode. To exit from factory mode, press the 'VOLUME -' and ?CHANNEL -? buttons on the TV set simultaneous for 5 seconds. " Hope this helps Michael Junge
Aug 04, 2007 | Philips 42PF5521D 42 in. HD-Ready Plasma...
Televison & Video Logo
62 people viewed this question
Top Televison & Video Experts
