Video card upgrade
I want to add video card for better game compatibility. What kind of video card would be most suitable for my old pc?
  • Display: Intel(R) 82845G/GL/GE/PE/GV Graphics Controller Chipset: Intel(R) 82845G Graphics Controller RAM: 64 MB DAC: Internal
What other info do you need?
  • brobert742 Oct 04, 2008
    Compaq Presario SR1023WM
  • Anonymous Apr 06, 2009
    when I try to play EverQuest II it just goes from my desktop at launching into the game for about 3 seconds then back to desktop. I have researched tirelessly and think my Intel(R) 82845G/GL/GE/PE/GV Graphics Controller just sucks.
    Can't afford a new pc, any ideas on a good replacemement?
    KarmicFluidity
I have Ati radeon x165o 512 mb pro agp card. But when i open need for speed hot pursuit game icon its turn into black screen and then close ? What is the problem ?plz plz tell me.
Posted on Apr 26, 2012
I'm using Dell Latitude C640 and when I'm playing games especially Need for Speed Hot Pursuit it's becomes slow . Can you help me correct this. Thank you.
Posted on Oct 04, 2008
Can I upgrade video card on t1831 e-machine
You can add a PCI-X video card and get to run dual display.
May 19, 2014 | Computers & Internet
USB 3.0 upgrade
You might need to upgrade you graphics card.
USB 3.0 is the newest connection port upgrade, arriving on the market in 2010.
The cable port connection is far superior to the USB 2.0 port, as it is able to transport up to 5 gbps (gigabits per second), instead of the previous version's max speed of 480 mbps (megabits per second).
However, most computers do not yet have this connection port installed, in which case you are left to upgrade your own computer system to the newer, faster connection method.
Turn off your computer, then disconnect all of the cables running into the computer.
Remove the Phillips screws from the back side of the computer.
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
Only work inside the computer case when the power has been switched off and disconnected. Never open the power source.
Some of the below steps recommend removing physical parts within the computer.
While in the computer it is highly recommend that you be aware of ESD and its potential hazards.
This unlocks the case, allowing you access to the interior of the system.
Slide open the computer case.
Inside the middle is a longer circuit board.
This is the motherboard of the computer.
On the back side of the motherboard, facing the rear of the computer, are PCI card slots.
These allow you to install additional hardware onto the computer.
Slide the USB 3.0 connection port into one of the open PCI card slots, then push down the plastic levers along each side of the slot to lock the card into place.
Close the computer cover, then tighten the Phillips screws and reattach the cables.
Power on the computer, then insert the driver installation CD into the disc drive of the computer.
Once the installation wizard loads, follow the prompts of the wizard to install the drivers.
Restart the computer once finished and the USB 3.0 connection ports are ready for use.
http://www.pcworld.com/article/186566/usb_30_finally_arrives.html
Compatible graphics cards for Gateway Computers
Just as a processor handles data and a sound card outputs sound, your computer's video card is responsible for processing graphics and displaying them on your monitor.
The video cards manufacturers build into computers typically have enough power for the average user, but it may be necessary to upgrade your video card for better performance in games or graphics heavy applications.
Understand which types of video cards are compatible with your Gateway computer and learn about all your options.
PCI Express Graphics Cards
Many newer Gateway computers have a Peripheral Component Interconnect (PCI) Express slot in which you can add any PCI Express compatible video card.
These devices range from budget cards suitable for everyday tasks to high end models for gaming that cost hundreds of dollars.
AGP Graphics Cards
Older Gateway computers likely have an Accelerated Graphics Port (AGP) slot for AGP compatible cards.
The AGP bus provides sufficient bandwidth for high performance graphics cards, but the technology is no longer in use and AGP cards are difficult to find.
PCI Video Cards
Nearly all Gateway computers should have at least one PCI (Peripheral Component Interconnect) slot regardless of age.
This slot has enough bandwidth to support a wide range of peripherals like sound cards and modems, but is not suitable for high end video cards.
You can find a number of low and mid-range cards for PCI slot computers, however.
USB Video Cards
USB video cards are also compatible with Gateway computers sporting USB 2.0 or USB 3.0 ports.
These external cards sit outside the computer and allow you to connect additional monitors to your system.
They are a good option for people who feel uncomfortable working inside computers.
http://www.pcmag.com/article2/0,2817,2371083,00.asp
How to buy a video card
http://support.gateway.com/us/en/support/default.aspx
Gateway Support
Upgrade My Video Card on My Gateway Desktop
Gateway desktops are affordable computers, but they often do not come with top-of-the-line video cards.
Computer games may run slowly or not at all on your Gateway desktop.
One way to solve this problem is to upgrade the video card.
Video cards come in PCI, PCI-E and AGP interfaces, so you should be able to find a video card upgrade no matter what Gateway desktop model you have.
Click "Start" and right-click "My Computer."
Select "Properties" from the menu that appears.
Go to the "Hardware" tab.
Choose "Device Manager."
Click the plus sign next to the Device Manager entry listed "Display Adapters."
Find your graphics card in this list.
Double-click it.
Go to the "Drivers" tab and click "Uninstall Drivers."
Click "OK" to confirm the uninstallation process.
Shut your Gateway desktop down.
Pull the power cable out of the back.
Look at the back of the Gateway computer tower for screws on the right side panel or on top of the case for a cover release handle.
Nov 29, 2013 | Gateway DX4200-09 PC Desktop
Does INTEL D915GLVG Motherboard supports Graphics/Video Card? OR Can I add Graphics/Video Card to INTEL D915GLVG Motherboard? - Kindly suggest me.
gaming is limited by the os that you have
gaming is limited by the speed of the cpu ( intel chip)you may even be limited by the graphic card that you can use in the mother board slot
when faced with all of these decisions and obvious lack of knowledge of what works best, find your self a computer repair shop and talk about upgrading to what you want
you say that cost is no object but to get what you want it will be a new mother board and fast chip ( probably a duel core or quad core) and a suitable graphic card for gaming
you can build a computer up from parts off the shelf and the cost will be around 1/2 the price of a computer from a retail shop and you will get exactly what you want
Mar 04, 2017 | Intel Computers & Internet
How to upgrade the video card?
You will have to add a new card to the motherboard. Open the cover and insert the new card in a slot and close the cover. Run Windows. Run the driver CD of the new card to install the drivers . From Control Panel->System->HW->Device Manager select the old card and disable it. Also check if the new card shows. Reboot the computer and connect the video cable to the new card. Your new card is functional now. Go to Control Panel->Display->Settings and configure Colors and Resolution of the new card.
Jul 06, 2011 | HEWLETT-PACKARD Pavilion Slimline s5304y...
I want to upgrade video card for my pc(HP Pavillion a1120n) i wanted to know what kind of video card is compitible with my pc. please help thanks. ;)
From what I gather, your computer has a PCIe v1.0 slot for a video card upgrade and comes with intel on-board video. So you will need a PCIe 2.0 video card (v1.0 are no longer available and 2.0 are backwards compatible)
I assume, like most PC's, yours has a 350-450 Watt Power Supply. Check your power supply to be sure, you just can't put any video card, you are limited to the available power from the power supply. If you want a top of the line video card for gaming you will need a more powerful power supply. If all you need is better performance and better video quality (DVI/HDMI) then any sub $100 dollars card will do.
I cannot emphasize enough, check your power supply wattage capacity and the watts required by the new card before buying.
Also, do you have additional power connection from the power supply for the new card? most cards, not all, require a 6-pin PCIe power connector.
For the average user I recommend:
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130395
Mar 13, 2010 | HP Pavilion a1120n (PX759AA) PC Desktop
My video card driver is not responsible in latest pc games
I think u donesn;t have sufficient video memory to run those games...Better try for a suitable graphics card to play high end games..
Jan 27, 2009 | Microsoft Windows Vista Ultimate Edition
Dell inspiron 1300 Video card upgrade
Sorry you cannot upgrade the graphics on your laptop according to the articles i looked up.
You should call DELL. I think the display card is part of the mother board on your computer. In this case, you cannot change it. In some models you can add some memory to the display card, but this may not make the card faster. Higher amounts of memory allows for more resolution and colours.
Dec 22, 2008 | Dell Inspiron 1300 Notebook
Video card
PCI Three (two available) PCI Express One (available) you can use a compatible pci or pci xpress video card to upgrade your system to a better video card check compatibility with yur media center PC.
hope it helps..
Jun 20, 2008 | HP Pavilion a1240n (EG136AA) PC Desktop
Too slow
the only way to improve graphics is to upgrade your graphics card and ensure that you have enough system memory and proccesor power to run the game as it should do. If you have a 32MB or 64MB card then maybe you should go for atleast 128MB
Oct 02, 2007 | Microsoft Windows XP Professional With...
Computers & Internet Logo
327 people viewed this question
David Payne
David Payne
