Screen problem Hi, since i fixed my laptop and put xp on the display is about an inch in on the right hand side, im not missing the time or anything its just in about an inch, i've tried reinstalling it but still the same. can you help? Thanks Paul
Dell sx2210 how do I change the size of the screen?
  1. Navigate to the Control Panel in Windows by left-clicking on Start, followed by Settings and then choosing Control Panel.
  2. In the Control Panel window, open Display. Note: In Microsoft Windows , depending on how your operating system is setup, you may not see the Display icon. To correct this, click on the link on the left-hand side of the Control Panel window that saysSwitch to Classic View.
  3. In the Display Properties window, click on theSettings tab.
  4. Locate the Screen resolution slider on the left-hand side of the window. Under most circumstances, the best choice is 800 by 600 pixels or 1024 by 768 pixels, possibly higher if you're using a 19" or larger monitor. The "best" setting is highly subjective to your personal preferences.
Aug 03, 2014 | Dell SX2210 21 inch Monitor
How to get rid of vertical lines on a packard belleasynote laptop
That's typical of a loose connection or faulty LCD cable, thankfully both options are cheap *IF* you know what your doing. I'd have an experienced person re-seat the cable on both the motherboard and LCD panel, if you still notice the issue it may be time to replace the LCD screen (which could/would be very costly if done at a professionals)
Apr 18, 2013 | Packard Bell Computers & Internet
I have just had a new screen fitted to my toshiba c660-10t but now about 2 inches on the right hand side is black like the screen is ended and half the tool bar at the bottom is missing
Go to control panel, select display, click on settings top right, go to resolutions and highlight your mouse over the arrow move one notch to the right and click apply, another window will pop up asking do you want to save these changes, click ok, repeat process until the desired results are reached.
Jun 16, 2012 | Toshiba Computers & Internet
Hi everyone,Ive got a dell cpx 650Mhz s600gt.os is window xp.my problem is the screen did not display anything after booting,it comes black.but the system is opperating,no welcome screen.plese help and im...
Wow what an oldie!
Unfortunately XP is no longer supported. This machine was designed for Win98 and 98SE. I expect there is a display driver missing, along with a few more perhaps.
Try loading 98SE and if it is OK, XP is your issue.
Jan 23, 2011 | Dell Computers & Internet
Turned back light down on my polaroid 4GB pmp280-4 touch screen now i cant see to turn it back up
settings is in the lower right hand side of the screen, tap there.
display is in the middle of the screen on the left hand side about one(1) inch down from the top of the screen.
the slider for brightness is down one and one-forth inches down from the top of the screen, tap about 1 inch from the left hand side of the screen, remember it is 1 1/4 inches down the screen.
NCMB
Jan 22, 2011 | Audio Players & Recorders
I turned on my laptop and its on but the screen doesnt dispaly anything, how should i fix that
hi, im nathaniel.
Im going to display the troubleshooting image of the black screen display,
Apr 29, 2010 | Toshiba Satellite Pro A210-EZ2203X...
Screen kept saying right side ink cartridge missing
If contact missing, then buy another ink cartige. It's probably too old.
Sep 05, 2009 | Lexmark X75 All-In-One InkJet Printer
Black striped down left hand side of display
Hi Danny, you haven't been very clear I will assume you pushed the auto configure on the monitor,
I would go into the menu on the monitor and reset the size of the screen if it has a setting for that 1024x768 should fix the problem
let me know what you find as I have never worked with a hp W19 monitor, if nothing else set the monitor to defaults again in the menu and that may get you back to having normal screens.
L8r
Nov 13, 2008 | HP w19 19" LCD Monitor
Installed xp upgrade it won't use the whole screen
Hi ABIDJAN,
Upgrade the video drivers or adjust the setting on the monitor.
Good luck.
Jul 27, 2008 | HP Compaq 6510b Notebook PC
Computers & Internet Logo
62 people viewed this question
David Payne
David Payne
