Question about Canon PIXMA MP150 All-In-One InkJet Printer
Canon MP140 paper jam error with no paper jam
I read the posts on this but wasn't really clear on what to do about it. My printer says "paper jam" but there aren't any paper jams in the printer. I tried dusting, but I don't a back panel that can be removed.
  • 5 more comments
  • Anonymous Jan 28, 2009
  • Anonymous Feb 27, 2009
    i really need help with this
  • Anonymous Mar 02, 2009
    its so annoying i have the same problem and have no clue on what to do!!!
    if anyone can offer any help---pleease greatly appreciated!!
  • frannie15 Mar 02, 2009
    ye i understand same ruddy problem here! ugh!!!
    Any HELP offered is greatly appreciated PLEASE!!!
  • Anonymous Apr 22, 2009
    I have the same problem too.. HELP PLEASE!
  • frannie15 May 11, 2010
    I've tried resetting the printer but it still hasnt worked!!! im gonna go crazyyy!!!
  • Anonymous Mar 28, 2014
    mery canon 2900 printer mai baar baar paper fas rha hai
  • Canon Master
  • 13,433 Answers
Try this
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Posted on Jun 03, 2009
Check paper error persists despite no paper in feeder or paper jam. cannot use auto document feeder due to this error. can i reset the sensor or do something else to clear the error?
I had one of these printers claiming there was a paper jam, when there wasn't. As others have suggested, three hard slaps above the paper tray, and hey presto, it works.(This seems to be the resolution to all problems. It will probably refill the cartridge too ... hmmm)
Feb 16, 2011 | Canon imageCLASS MF6550 All-In-One Laser...
My printer is showing E3 and there is no paper jam. How do I correct this so my printer will print
mp140/145 e3 error paper jam but no paper ,in my experience ,nag karoon nga ng paper jam at wala na ang papel pero still E3 pa rin !!!!!! ----na dis align yung sensor padel na tuwing tatamaan ng papel na syang swits on/off (example) sa pag pasok at labas ng papel
Nov 17, 2010 | Canon PIXMA MP160 All-In-One InkJet...
After a paper jam, my canon mp140 does not print at all. It says to clear paper jam, but i have remove paper. Is there a solution?
Is is possible that bits of paper is lodged into the roller or into the sensor area that is showing it as a detect.
The rollers may be jammed and so it will be good to release the motor drive with a manual twist.
So disconnect printer, then open panel and remove motor to turn the rollers.
Once it is free , reset to test
Sep 13, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Error code E3 with no paper jam
it is problem your printer can not feed paper properly or problem paper feed sensor please try to resum button press when occard this E3 signal or clean sensor or claugth
Nov 21, 2009 | Computers & Internet
My Canon MP140 has a paper jam. How to open and remove paper?
Click here. This will take you to the Canon support page for your MP140 printer. Click on the 'Support and Service' tab.
Where it says ask a question type in 'paper jam'.
Next click on the required link, which should give you detailed instructions or a link to help you with your paper jam.
If this helps, click YES below.
Jun 30, 2009 | Canon MP140 PHOTO AIO All-In-One InkJet...
Canon MX860 Rear Paper Jam
I have a small piece of paper jammed in my Canon MX-860 that Cannot be seen from anywhere. Can you help me find so I can clear it
Jun 27, 2009 | Canon Office Equipment & Supplies
Cleared a paper jam but E then 2 and alarm still flashing
Error code 2 is mean no paper present. Just put paper at the Auto Sheet Feeder.
Apr 01, 2009 | Canon MP140 PHOTO AIO All-In-One InkJet...
"Clear paper jam" error, but there is no jam!
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
Sep 18, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Canon PIXMA MP140 error code E 2
error E 2 => The machine is out of paper. / Paper does not feed.
Reload paper in the Auto Sheet Feeder and press the Black or Color button.
Feb 29, 2008 | Canon MP140 PHOTO AIO All-In-One InkJet...
Canon PIXMA MP150 All-In-One InkJet Printer Logo
1,600 people viewed this question
old marine
old marine
