Question about GE Washing Machines
Washer filling and draining at same time
Model # wlsr2200j5ww on the super load it fills and drains at the same time ,what can be the problem as the other cycles work ok
it is a ge model # wlsr2200j5ww ad serial # is rr191692g
we have not had this washer for a week yet,it is new out of the box..
    Genius:
  • 1,028 Answers
Ckd to be sure drain hose end is 30-36 ins from floor also be sure hose is not tight in standpipe need slight air gap around it..sounds like siphoning
Posted on Oct 05, 2008
White westinghouse 8cycle washer will not spin or drain now it wont do anything model number WW5833ES1 i thought it might have been circuit related so i reset the fuse box and removed the clothes from the...
does it fill with water yet?if so then its the lid safety switch that gone bad under the top lid,this will kill all cycles other than fill,if it doesn't fill with water either then the timers defective
Jan 01, 2011 | Westinghouse WWS833ES Super Capacity Top...
Does not fill to wash
If draining is occurring at the same time as it is filling you have siphoning happening. There could be 2 reasons for this.
#1 the drain hose must be higher than the washer tub before it connects to the drain pipe in the house.
#2 the drain hose from the machine must not stick into the house drain more than 6" - if it is pushed down the drain too far it will siphon out the water in the machine.
Apr 21, 2010 | Whirlpool LSQ8000 Top Load Washer
Kenmore 90 Series Heavy Duty Top Load Washer Model 110.28922790 water fills in tub and it's draining at the same time. Won't go through the normal cycle just keeps filling and draining. Any help...
You may have a condition known as "siphoning". This is caused by the drain hose not being high enough off the floor, or not having a proper air gap at the standpipe in order to drain properly. This creates a suction and the washer will constantly drain as it tries to fill. The following link explains:
http://www.fixya.com/support/r3575830-how_to_prevent_washer_siphoning
In the majority of the cases, this problem is attributed to improper installation, rather than an actual problem with the washer. If you have any questions, please post back and let me know. I hope this helps you.
Apr 17, 2010 | Kenmore 22442 Top Load Washer
Frigidaire Front Load washer Model FWT645RHS1 wont fill with Water
The drain hose might be too low. Make sure the drain hose is at least three feet above the floor.
May 31, 2009 | Frigidaire Washing Machines
Washer fills and drains at the same time. doesn't change cycles
check the washer drain hose, it is probably sipening the water back out, try pulling it out of the drain a few inches
Apr 07, 2009 | Kenmore 24032\24036 Top Load Washer
Water fill control
it overflows from the tub then:
This can either be a fault in the fill sense tube( small tube connected to the bottom on the outer tub from the sensor at or near the top of the washer housing ) becoming blocked or broken or a fault with the sensor itself. There is a mechanical adjustment for the level but it is a little fiddly to get the adjustment just right.
If it overfills from the drain hose:
then either the drain hose is too low and the water siphons out before it reaches the maximum or there is a tight seal at the drain hose to house drain port which will cause all the water to siphon out, this can also be caused by a drain hose being pushed too far down the house drain port.
Jul 28, 2008 | GE WDSR2080D Top Load Washer
My washer will not fill during the cycle for high agitation
You may have a siphoning problem. Double check your drain hose and make sure it's not shoved down in the standpipe too far. The standpipe is the drain line at the wall. If your drain hose is placed too deep into the standpipe, or if you have the top of the standpipe sealed off, the washer will begin to fill and continue to drain at the same time. The symptom will appear as if the washer is constantly filling. You need to leave an air gap opening around the rim of the standpipe, and the drain hose should only be placed about 4 to 6 inches into the drain line. I hope this helps you. Post back if this is not the problem you are experiencing and I will try to provide you with a better solution. Let me know if you have any questions.
Apr 22, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Washer will not fill
Triple, sounds like you are siphoning. Pull the drain hose out from the drain hole. Make sure you have a air gap where the drain hose goes in. Try this first. Catriver..post back
Mar 12, 2007 | Roper RAS8244KQ Top Load Washer
Washing Machines Logo
299 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
