Question about Sony KP-53HS30 53" Rear Projection HDTV-Ready Television
Possible convergence issues...please advise
Turned my kp-HS5310 tv on last week and the color were off as well as the words on top and bottom - like a wavey line motion. It appears to be a convergence problem but I'm not sure.
I've tried several time to push the "flash focus" button in front of the tv as stated in the manual but it doesn't fix the problem.
I heard that you can manually adjust the convergence with the remote. Does anyone know how to do this or offer any other possible solutions to fix on my own before I have to call a technician?
Thanks in advance!
  • robyn9690 Oct 05, 2008
    My TV set just started the same problem. I've tried the Flash-Focus without any success. I'm wondering if I should call a repair guy or just replace the set. Please advise if anyone else knows how to fix.
  • cwpait Oct 12, 2008
    I have a red shadow on all objects on TV. focus is find except for the red shadows. I covered the red bulb and the shadow is removed but the color red is not seen through out the program.
4 Suggested Answers
ladywinn
  • 5138 Answers
SOURCE: Sony KP-43HT20 convergence problem
Replace STK-392-110s or 150s upgrade with 180s replace both ics.
Posted on Jan 09, 2008
doin12volt
  • 233 Answers
SOURCE: Sony KP 57WV600 Picture with Shadows flash focus not working
Your TV has gone crazy on you because your convergence IC's have gone bad.   These IC's operate at a very high temp, and usually only last 4-5 years.
If you remove the back of the set, you will want to look for the BIGGEST heatsink in there, on that heatsink, you will see 2 lage IC's , probably STK392-110, or STK392-120's or something close...regardless - you can go on ebay to order the new ones, but MAKE SURE they are Genuine SANYO IC's and not counterfiet cheapies. the cheap ones may only last 2 months..
You will also need some "Heat transfer paste" - you can pick this up at radio shack.   Once you remove the old IC's, test all the large resistors near them.. pull one side of the resistor out of the board so you can check it out of circuit. they will usually have the value in Ohms, printed directly on the resistor, but you may have to use the resistor color code to find out what value they are....However, usually if there is any damage, the resistor will look like it has been HOT or fried. replace the IC's and any bad resistors, and you should be good to go. If you need to order a resistor or two,
http://servicemanuals.vstore.ca/index.php/cName/convergence-resistors   If after replacing the IC's and any defective resistors, the convergence is still bad, make sure to use a multimeter to check ALL fuses on the boards, --- sometimes when the IC's go, they will take out a fuse to the convergence power supply. If you find any bad fuses, replace them accordingly!   If this STILL doesnt make it look right, you will need to find out how to get into service mode and do a coarse convergence adjustment. This information can be found in the Service manual for your set. If you dont have one you can download it at manualuniverse.com
Hope that helps!
Posted on Jan 17, 2009
  • 14 Answers
SOURCE: convergence is off on sony (flash focus doesn't help)
which colors are more out of line? This will tell you what convergence amp to replace.
Posted on Jun 23, 2009
Top and bottom of TV screen collapsing.
You may have a convergence problem (I will attach some typical photos).
When it does it go into menu and call up convergence grid--if lines skewed and colors mixed it is convergence. This model I think uses two of the STK-392-560 chips and both would have to be replaced if it is your problem.
I can provide more info if you find this is what you have.
May 29, 2012 | Sony KP-57WV700 57" Rear Projection HDTV
It has double images. The words are doubled even, appearing blurry. We are currently playing a DVD "daddy daycare" The words on the car are unreadable because they overlap. At the bottom of...
Ur tv have a problems known as a convergence pictures problems,it is dead.Tv have any colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?Yes,than the tv have a dead convergence board to causes these problems.The tv convergence board must have to be repair like replacing 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence pictures problems.The tvs shops will cost u like $300-350 for parts and labors.
Aug 28, 2011 | Sony KP-46WT500 46" Rear Projection...
LG Projection TV Model# RT-49NA11T Green color gun shows bent arc on top & bottom.Red & blue guns are ok.How to adjust the green gun to remove the bent arc. This is causing picture shows mix...
This problems ur tv have can't not be fix by adjustment.The tv have a problems known as convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadow pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board,must be replaced to repair the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Jan 10, 2011 | Panasonic PT-53WX53 53" Rear Projection...
Red shadow on images and letting
Check your convergence, Using your original remote go to the Menu, in the settings select convergence, try to align the colors to each other.
Apr 20, 2009 | Sony KP-51WS510 51" Rear Projection...
Sony HD Projection TV - Picture bent and seeing multiple colors
This is due to failure of convergence out ICs that need to be replaced in D board.
If you are comfortable with TV repair let me know to provide you technical info to fix TV.
Apr 17, 2009 | Sony KP-46WT520 46" Rear Projection...
Sony TV rear proj works but color is blue
Problem : Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
Solution :
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
I hope this will solve your issue.
Good Luck.
If my solution proves useful please accept it.
Regards
Arjun
Mar 13, 2009 | Sony KP-51WS500 51" Rear Projection...
Sony model no; KP-E41SN11 rear projection tv.
Is Sony KP-41T65 41 and my sony KP-E41SN11 having same STK-392-150 CONVERGENCE IC CHIPS????
kindly advise please.
Jan 30, 2009 | Sony KP-41T65 41" Rear Projection...
Appearing rainbow colour for sometime and getting off.
There are few cold (dry) solder joints in convergence board of your tv Sony KP-46WT500
Please inspect convergence board and resold dry solder joints.
Oct 18, 2008 | Sony KP-46WT500 46" Rear Projection...
Trouble Aligning Colors
If the convergence is missing in the menu in screens,you have a bad reg ic on the convergence power supply the part number is 215530,the power supply is located on the black plastic above the right module with all the heat sinks
Nov 15, 2007 | RCA P56930BL 56" Rear Projection...
Possible auto convergence board failure
Possible convergence issue.......change STK392-560 IC's....T.
Oct 21, 2007 | Sony KP-57HW40 57" Rear Projection...
Sony KP-53HS30 53" Rear Projection HDTV-Ready Television Logo
49 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
