Question about Reddy Heater RLP100 Portable Forced Air Propane Heater with Variable Heat Ouput
Empire corcho ventless propane wall heater 15000 btu
This heater was run of a 20lb tank most of last winter, the regulator and lines are new, last winter... I ran the tank out the other night and it was working fine on all 3 settings but when I switched over to a 100lb tank the heater will only run on the minimum setting (and the cermic tile glows orange with a tint of blue... it should be completely orange) when it is switched over to medium it tries to light but flickers constantly (cermic tiles only flicker blue and will not completley ignite) and the pilot light gets much smaller... on the high setting it barely flickers and none of the ceramic tiles glow. On the the medium and high settings the smell of propane (mercaptan) becomes more evident. I have a carbon monoxide detector which has not gone off... in the same room and there is adequate ventilation as the windows are open. Any suggestions?
    Problem Solver:
  • 5 Answers
LOL.... your fuel is not boiling.... the closer propane gets to its vaporization point (-44%F) the less vapor it produces. clean the snow off of the 100# or lay it on its side to give it more surface area for vaporization.
David Lawrence the propane dude
Posted on Dec 10, 2009
Hey I'm not as smart as the rest of these guys but i have a Empire 3 burner.
Change Thermocoupler and oyxgen depletion sensor (its behind the pilot -screws in-or clean-do not use a pinor sharp item to clean)then look up at a lite to see if its clear.
That should cure the problem.
poorman
Posted on Dec 07, 2009
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 13 Answers
Either you don't have enough propane in the tank to run the heater, or your regulator is set to a pressure too low to run the heater.
Posted on Feb 28, 2009
I suspect that this problem may have to do with your regulator. Only a guess though.
Posted on Oct 31, 2008
We have a EMPIRE CONCHO WALL HEATER 15000 BTU..we had our 100lb tank removed. Can we hook up a 20lb tank to the outside line coming into the house ? And how ?
they use the same couplings . it the hose is too short sit the small tank on an upside down garbage can tho a 20 pounder will probably not last a day or two
Jan 04, 2016 | Empire Heating & Cooling
Burner for corcho wall moont heater model number ck30t3lt
Search Results
    SunStar Corcho Vent-Free Natural Gas Infrared Heater with ...
    www.efireplacestore.com > ... > SunStar Heating Products Space Heaters
    SunStar Corcho Vent-Free Natural Gas Infrared Heater with Manual Controls ... For added convenience, you can mount this heater on a wall or have it stand on ...
    Tech Video: Wall Heater Maintenance - YouTube
    ? 3:33
    https://www.youtube.com/watch?v=8eglHvyNV3U
    Oct 19, 2010 - Uploaded by FMIPRODUCTS
    How to clean the Vent-Free Wall Heater burner's & pilot. ... Fix Mr Heater Vent Free Pilot Problems - Part ...
    EMPIRE CORCHO UNVENTED GAS HEAT
Dec 14, 2015 | Heating & Cooling
What regulator does a empire model 115 15000 btu take?
The regulator on the heater probably is not but is probably a device to prevent the heater being used unless the gas pressure is high enough and also serves to prevent air entering the gas line and also serves to arrest flashbacks.
The standard propane low pressure regulator is 14" water gauge but the heater might need a high pressure regulator. The best way to decide which type of high pressure regulator to use, because there are several, is to use an adjustable regulator.
After installing the adjustable regulator the pressure is increased until gas can be heard to be flowing and the heater lit. The regulator should then be adjusted to produce a clean flame of the correct length and then the regulator adjustment locknut should be tightened.
If the heater is to be used indoors it is important to ensure there is plenty of ventilation and the emissions are checked by a gas engineer.
Sep 06, 2017 | Empire Heating & Cooling
Lights while holding primer/pilot button then runs out of propane within seconds. If you wait a minute it builds up then does the same thing like the propane tank is empty but it is full.
Turn off the propane tank and disconnect the heater hose from the tank. Wait 5 minutes and reconnect the heater hose/regulator to the propane t. Turn the tank valve on very, very slowly until it's completely open again. Now, try lighting the heater. If you are using a 20lb LP grill type tank, that should solve your problem.
Hope that helped.
Feb 12, 2011 | Reddy Heater-30-55,000 BTU Variable
I just bought a 30K ventless wall mount heater and have a 24X30 insulated garage. I set it on 2 and it keeps it about 60 degress but the smell burns my eyes and stains my clothes. It's brand new. I have it...
You need to ventilate this area while the units running! This is potentially a lethal situation!
You are competing with a flame for oxygen and breathing the carbon monoxide gasses
from the heater! Both unacceptable scenarios! you can easily die in this environment!
I cannot stress this enough! You need to open a window or crack the door enough to allow air to circulte and gasses to vent out and escape, If the burning of eyes is really bad your unit may not have sufficient combustion air, I can t tell you without seeing it precisely, you better vent that room though!
Dec 24, 2010 | Reddy Heater RLP100 Portable Forced Air...
Dear sir i have a empire/corcho 1500 btu heater and i have a 70 gallon tank of propane tank but the heater says natural gas can i do this or do i have to use a conversion kit and do i do that and where do...
First off, yes you can convert it to propane. The difference is that the orifice, which should be in the conversion kit, has a smaller hole for the gas to pass through and needs to be changed. Secondly, the air consumption on propane is greater than that of natural gas and for that reason you need to open the air venturi, usually to the max to allow the largest amount of air to enter. Don't overlook the pilot light as well, it also needs to have a different orifice installed. You can find new orifices and/or conversion kits at the store where you buy your propane, assuming it's not a big box retailer. Go to a local propane supply location for the parts. Another option is to go directly to the manufacturers home page and order the propane orifices.
Oct 04, 2010 | Reddy Heater RLP100 Portable Forced Air...
HOW TO LIGHT PILOT ON EMPIRE CORCHO WALL HEATER MODEL R 15
I have tried to light my empire wall furnace by pressing the button and I have the gas on and it won't light
Oct 17, 2009 | Reddy Heater RLP100 Portable Forced Air...
Can not get the bricks to light on my empire corcho
I have the same htr in Mich. & have worked on gas htrs.for many years.
Does the flame go out when you let go of the button to lite it?
If it does, then the thermocouple is bad.
If the flame stays on, but goes out when you turn the dial,
the gas regulator is bad.
Probably a little more expensive to buy new then to fix it.
Michael.
Nov 20, 2008 | Reddy Heater RLP100 Portable Forced Air...
Heating & Cooling Logo
3,044 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
