Fischer and Paykel EcoSmart top load washing machine
I start the machine, put it on cold/cold option, the water runs in, swishes around, drains, the first green "wash" light goes out, water starts running in from the HOT hose and the machine shuts down and starts beeping. If I press start/pause the red light on the lid lock comes on, and if I press the start/pause again nothing happens. I have to press the power on/off switch and the machine shuts down and comes back on with all three green wash lights on. I manually move it to the second wash button with my arrow button and it starts washing again and finishes all cycles without further problems. Anyone have any idea what is wrong? This is a relatively new machine. I got it about a year ago and I have been happy with it so far, but this is driving me crazy.
  • 288 Answers
SOURCE: washer will not spin
I'm having a little trouble understanding the question because of the spelling, but this sounds like a typical lid switch not making contact either by the depressor on the lit itself or the switch is broken. try depressing the switch with a screwdriver and see what happens. The lid switch will be in a little slot in the top inside where the lid closes.
Posted on Dec 18, 2007
  • 867 Answers
SOURCE: Fisher Paykel Ecosmart washing machine spills water.
sometimes too much detergent, or extra cleaners like oxy clean) will cause lots of foam which will cause the water level sensor to misread, or foam over the top of the drum. if this is not the problem, you will have to tilt the machine on its side and look for loose or damaged hoses. the play in the tub will not cause leaking
Posted on Jul 10, 2009
  • 56 Answers
SOURCE: I have a fisher & paykel ecosmart washer no water
Please make sure that your water supply lines are properly connected and turned on. Also, there are typically small filters at the end of the hoses where they connect to the washer. Check those and clean them if necessary. Since the hoses will be disconnected at that time, flush the lines by running the water into a nearby drain or bucket.
Hope this helps! Rate my solution!
Posted on Jan 05, 2010
  • 713 Answers
SOURCE: MW512AU Fisher and Paykel top load smart touch
Hi Des, just read your posting.Now when you turn on the machine you say that some lights light up and it starts to beep.These lights will be in a row of 8 lights.Starting from left to right which lights are lit when the machine is beeping?Is it he 3rd and 5th or the 2nd and 7th ---etc---?Please reply with additional information on the question and I can help you rectify the fault.Looking forward to your reply.
Posted on Aug 18, 2010
  • 15935 Answers
SOURCE: washing machine errors
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to or and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!!!!!!!!!!!!!!!1
Posted on Sep 15, 2010
My FisherPaykel ecosmart washer will not spin out and drain. What can I do?
small_11_21.jpg For a detailed Washing Machine illustration, click below.
redarrow.gif Top Load Maytag Style
redarrow.gif Top Load Whirlpool Style
redarrow.gif Top Load GE Style
redarrow.gif Front Load Maytag Style
redarrow.gif Front Load Frigidaire/GE/Kenmore Style
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Some problems that can occur with your top-loading washing machine are:
There's an error code on the digital display
It doesn't work at all
It won't drain
It doesn't spin
It doesn't agitate
It's noisy
It leaks
It's off balance
There's no hot water
There's no cold water
It's slow to fill
There's no water at all
The clothes are wet after spinning
The cycle doesn't advance
There's no delicate or regular spin or agitate
It's overfilling
It's underfilling
The water temperature is incorrect
Jul 31, 2008 | Fisher Paykel EcoSmart GWL15
I only have a hose attached to the cold water tap and inlet valve of my Fischer & Paykel top loader washing machine as I only do cold washes, this hadn't been a problem until recently, when th
it could be that the water level got to high and came out of the valve you could try putting a cap on the valve and see if that works and if it does not then it might be a bigger issue.
Dec 23, 2012 | Fisher and Paykel GWL11 Top Load Washer
I put heavy wool items in my ecosmart Fisher & Paykel washing machine (approx 9 yrs old) and after it filled with water and drained the water, it beeped unbalance so i added something else to balance...
You should not continue to run the machine until you rectify the issue with the pump. Check the resistance of the pump's coil. It should be 7 ohms for the model GWL15. If the resistance is different, there is a problem with the pump electrically and it needs to be replaced.
Jan 12, 2011 | Fisher Paykel EcoSmart GWL15
My washer wont drain and when i try to start it over nothing happens. last time i was able to drain the water but when i put in another load, the washer filled with water and wouldnt drain again. Help what...
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
Aug 19, 2010 | Fisher Paykel EcoSmart GWL15
My Fisher and Paykel EcoSmart top load washing machine is slowly filling with water. Help!
I am assuming that you have already made sure that your hot and cold water taps are fully open.
If not, then check those first.
Otherwise try this.
First, turn off the hot and cold water.
Remove the hoses from the back of the machine.
Turn the machine to face you and do a visual inspection of the screens on both the hot and cold water valves.
If there are no screens, your valves may have lime and hard water deposits, or they are simply too weak to fully open. Generic, as well as OEM water valves are available on-line to replace them.
Mar 05, 2010 | Fisher and Paykel WL26CW1 Top Load Washer
Fisher paykel ecosmart washer wont go drain or go to rinse cycle
this is joyce
take hose and siphion the water out of the into pan on floor or outside if you have long enough hose. it will come out just get started by putting one end in water in tub and the other end outside or in tub or whatever and start suction on hose untill water comes out and let run untill all water is out of tub.
Feb 07, 2009 | Fisher Paykel EcoSmart GWL15
Fischer Paykell 7.5kg Smart Drive top load washer
Have you checked the lid micro switch under the motor controller which activates when you close the lid to start the machine?
Jul 24, 2008 | Fisher Paykel EcoSmart GWL15
Maytag washing machine
The lid switch is bad on your washer. Either replace it or bypass it.
Oct 22, 2007 | Fisher Paykel EcoSmart GWL15
Washing Machines Logo
Top Washing Machines Experts
