Question about Dryers
Belt broke on GE Dryer model #DDE7500BALWH - Dryers
  • 1,543 Answers
You will need a WE12X82P belt, or just a WE12x82 (the P stands for packaged)
  • Disconnect power
  • Remove screws under the front edge of the dryer top
  • Swing top up and remove one screw from each side panel holding the dryer front, near the top of the dryer.
  • Pull dryer front forward a bit and lift off bottom pegs. Swing to the side. (no need to disconnect wires if you don't want to)
  • Put belt around drum, lifting drum a bit to get belt past drum support slides on the bottom side.
  • Check to make sure drum slides are not worn through, especially the one on the left side.
  • The grooved side of the belt touches the drum
  • Belt runs from drum directly to motor pulley on the left side, then around belt tensioning wheel and back to the drum.
  • Turn the drum a revolution or two (counter clockwise) before reassembly.
Posted on Oct 04, 2008
Can not get belt around drum from the front of dryer or check guides
Posted on Oct 16, 2009
Dryer not running after start turned
do you mean that if you hold in the start button it will run but when you let it go it stops,if so you have a bad belt pulley switch.it's a safety so if the belt breaks the dryer won't run,all it is is a cherry switch,a black switch with a white button sticking out of it,the belt pulley hits it and pushes the button in but the switch fails internally or the belt is broke,if the belt isn't broke replace the belt pulley switch.
Oct 20, 2013 | GE Dryers
Dryer only runs while holding start button in
We have a Maytag Epic dryer with the same problem (Model MED9800TQ0). Pulled out the control board yesterday and saw that the weld had been blown right at the motor relay (burnt marks surrounding the area on the flip side of the board where the relay attaches). Do you suggest we replace the motor relay or just try to re-soder that part on the board? Also - should we be concerned as to how this happened (that it was something elsewhere that caused it to blow)?
Jan 16, 2013 | GE Dryers
Belt broke on dryer where to get them
have you tried contacting the manufacturer or checking their web site on the parts page?
Jul 20, 2012 | GE Dryers
The dryer makes an electrical buzzing sound but the drum doesn't spin. I can spin the drum manually, which I never could before the problem started. Model GE DBVH512EFOWW
michael00256 (that's a great name by the way). several things could be going on. If you can gain access inside the cabinet, you'll need to do that.
http://www.do-it-yourself-washing-machine-and-dryer-repair-help.com/take-apart-GEelectricgasdryer.html here's some video help that should tell you what you need to know.
http://www.do-it-yourself-washing-machine-and-dryer-repair-help.com/GE-HP-dryer-is-not-tumbling.html here is also a link that should tell you exactly what you need to check.
The problem could be in the motor, with the belt, or a few more things.
If you get this far and still have not solve your problem, please contact me. My name is Mike, and I would be more than happy to help you out in solving this problem.
thanks,
mike
PS; if you're even slightly handy, this could be something that you can do yourself.
Jul 19, 2011 | GE DBVH512EFWW Dryer
My dryer's belt broke and I cant find the part
WE12X1001, WE12X1000, WE12M29 are the three different belts used on GE Dryers and if you go to
https://www.geapplianceparts.com/GEApplianceParts/Dispatcher and do a search on these parts you will be able to purchase them directly from GE. You will need to look at your belt and pull the number off if your belt in order to assure you get the right one. If you require further assistance, please do not hesitate to ask.
Jun 14, 2011 | Whirlpool GEQ8858H Dryer
DRUM BELT BROKE
To replace it won't be hard. Just make sure it is back on securely.
Jan 08, 2009 | GE DBSR453EBWW Electric Dryer
Ge Cloths dryer will not stay running or turn drum
probably broken belt some dryers have broken belt switch that shut dryer off if belt broke
Nov 25, 2008 | GE Dryers
GE,Dryer,dbxr463ed1ww,
It sounds like the belt broke off. Unless you have replaced even just the belt before,you need a experienced repairman, trust me.....
May 30, 2008 | GE DBXR463EBWW Electric Dryer
Dryers Logo
391 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
