Question about Cameras
I have a D-80 Nikon with a small spot that always looks darker than the rest of the picture. It is roughly round and about the size of a quarter viewed at arms length compared to the picture it is on. It is only slightly darker than the rest of the picture and is usually only noticeable on a landscape or similar picture where the sky has a spot that looks like slightly darker blue sky. I am guessing there has been a spot of water on the CCD that left behind some residue when it dried.
  • 3 Answers
Sounds to me like you're on the right track.
There are plenty of places that can clean your CCD for you if you can be without the camera for a little bit, but there is also the solution of cleaning the CCD yourself. This is a scary topic, however, because a) if you do it, it will void your manuf. warranty, if applicable and b) if you do it and mess it up, your CCD can be damaged.
There are products out there - swabs and solutions - to clean the CCD if you choose to do so yourself. Personally, to make certain that nothing goes wrong, I would send it to Nikon or take it to your local dealer and have them take a look at it.
Posted on Oct 04, 2008
Basketball game pictures are blurry
basketball game is a fast moving object which is hard to take the picture perfectly sometimes
always using a flash, or external flash for more lighting support, set the shutter at about 1/80 or faster, ISO setting is 400 to avoid darker result, the Aperture should be set at the biggest number such as f 1,4
hope this advice help you
Dec 20, 2010 | Nikon D60 Digital Camera
Can't locate the oil drain plug to change oil.
Around the base of the motor there should be small round cap about the size of a quarter with two small round quarter inch high posts on it - that is for finger leverage.. Unscrew it and tip the mower so all the oil comes out.. Replace oil and cap.
Sep 23, 2009 | Poulan Pro 22" Self Propelled High Wheel...
Welding breaker keeps popping on my Hobart Champion 10,000.
look for short inside unit,start at breaker and work your way back.
May 24, 2009 | Hobart Welders Champion 500433A Factory...
Screen display for nikon d80
Hi kathryn i also have a Nikon d-80 that i just purcased, and i too would like to know how to use that feature I din't even know that it had this feature so i called Nikon and they told me that the Nikon D-80 doesn't have what is called "live View." so i hope this answers your question. FOSHEEZY.
Jan 11, 2009 | Nikon D80 Digital Camera with 18-135mm...
Photosmart pictures have random white circles
It sounds like you have a photosensor that is going bad. If it happens 80% of the time, it is time to fix it or repair it. I have a friend who can fix cameras, he is cheaper and faster than the manufacturer.
http://www.cameradr.com/
Nate
Dec 21, 2008 | Nikon Coolpix S51c Digital Camera
Prints have darker same color circles are the same size.
The ccd sensor is dirty. Have it cleaned at a camera shop. You can do yourself with sensor swabs and eclipse fluid but it a is very delicate operation. Local shop here cleaning is $45 and no spots, well worth it.
May 12, 2008 | Nikon D80 Digital Camera with 18-135mm...
Nikon d80
It might be caused by some dirt on your lens (either front or rear element) but is more likely to be dust on the cameras sensor.
There are a couple of sample images of what this looks like here and here.
Dust spots typically have a softish edge to them and affect more than 1 pixel. (if it is just the 1 pixel affected, which a very sharp edge, this could be a defective sensor).
Following the instructions in the manual for cleaning the sensor. Avoid touching the sensor (unless it is with a specialist sensor cleaning brush) and avoid cans of compressed air; use a hand-blower brush instead.
Matt
Mar 03, 2008 | Nikon D80 Digital Camera with 18-135mm...
Black spot on lower part of screen.
Sounds like the LCD is damaged, it's commonly called a bruise. It can only happen when too much force is applied to the screen causing irreparable damage to the LCD crystals, causing them appear darker than the rest.
There is a picture here on the second post down.
Feb 23, 2008 | Emerson EWL20D6 Television
Cameras Logo
85 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
