Question about Drills
Bosch Hammer drill GSB 16 RE doesn't work every time I press trigger
This has been in use for 2 years, but doesn't get used much, just putting up blinds, pictures, small shelves, hurricane shutter frames. I thought the problem was with a loose plug connection to an extension cord, renewed that, same problem, then tested drill without an extension. It still works intermittently, the variable speed button, above the trigger, goes through body to other side, has to be pressed very firmly in so the drill starts.
Is this fixable and what parts would I need? I should have returned it to the Ace Hardware shop in St Vincent (West Indies) where I bought it but I live on the next island and don't sail over often.
Would appreciate your help, new drills are expensive here!
  • Corey McConnell
    Corey McConnell May 11, 2010
    The model is correct, it is one of Boschs handyman series drills. Does the drill work intermittently is forward and reverse? Or one direction specifically?
  • David Ford
    David Ford May 11, 2010
    First, yes that would be repairable sounds like the switch is bad but I would also check the cord for a broken wire. Second I tried BOSCH website here and that model number does not come up with anything, tried another site and still nothing. Would recommend trying BOSCHTOOLS.COM from your area and see if there is a difference. Sorry couldn't help further. Dave
    Sniper:
  • 79 Answers
Check the brushes. the switch may have a short. Also, check the wiring from the switch, making sure there is no loose connections to the field. Definitely fixable. Lemme know Please rate me
Posted on Jun 18, 2009
Bosch cordless drill not working.
First The model is pretty new. you need to register your tool on line. this takes you from a one year warranty to a three year warranty. They will give you a pro-vantage number. with that said it sounds like a trigger switch. Yhe trigger switch is the brain of your tool. not only does it do your variable speed but it also controlls the brake and your fuel gauge. Because of the cost I highly recomend taking it to your closes Bosch service center.
Oct 13, 2012 | Bosch Cordless Impact Driver, 18V, 1/4 Dr,...
I have 2 dewalt 18 volt hammer drills. The first one died about 2 years ago. The trigger seemed to mess up. I took it apart several times thinking I could fix it. I finally gave up on it. It's laid...
Hi, Take the drill apart using a star driver. When taking the chuck assembly from the yellow section have the drill chuch down to stop bits falling out. Once handle is apart popout the triggger assembly. Remove the two power leads from the assembly. Try a direct connection to the battery (polarity doesn't matter. If the motor goes it means that the trigger is U/S. Put a tester across the terminals (either set). You may have a short (as I had). It appears to me that the trigger is not user servicable. I used one from a DeWalt recip saw with a mod on the reverse lever. Works well.
Good luck.
Mar 15, 2011 | Dewalt 18v Battery Hammer Drill Dcd950...
I have a very new GMC 1400 Watt hammer dril. when you press the trigger it will not work. I unscrewd the casing had a look couldnt see anything wrong, put it back together and it worked. Drilled a few...
YOU HAVE A LOOSE WIRE OR A BRUSH HANGING UP IN THE BRUSH HOLDER! LOOKE FOR WHERE THE WIRES GO INTO THE SWITCH, ALLOT OF TIMES THEY ARE LOOSE IN THERE, OR IF ITS LIKE THE BOSCH HAMMER DRILL, THE WHITE WIRES GOING INTO THE FIELD ARE FAMOUS FOR GETTING A LITTLE CORROSION ON THEM, OR COME A LITTLE LOOSE. INTERMITENT ELECTRICAL PROBLEMS ARE A NIGHTMARE, ALL IT TAKES IS A LITTLE SPEC OF DEBRIS BETWEEN THE BRUSHES AND THE COMMUTATOR AND THE TOOL WILL NOT RUN, MAKE SURE YOU BLOW IT OUT REALLY GOOD WHILE APART!
Jan 14, 2011 | GMC 65 Amp Hammer Drill
Faulty bosch hammer drill
a bad trigger switch; bosch sells a replacement part
Jul 24, 2010 | Bosch Drills
No power
Check the Cable between the plug and the switch for continuity using the ohmeter or continuity tester part of a cheap multimeter. Place one lead on each of the plug contacts in turn, and the other on the other end of that wire. If this is okay, check the switch for continuity by placing each lead of your tester on the in and out contacts and pressing the trigger. If still no joy, check the brushes. If still no joy, check the motor windings for continuity.
Jun 15, 2009 | Bosch HCBG500, 5 Pc Industrial Hammer...
Exesive sparks on the brushes (Bosch GSB 16RE drill)
If you used the drill any amount with a burned field coil there is a good chance that is has burned the new armature out.
May 30, 2009 | Bosch Drills
Just stoped working
make sure that in the speed selector you are fully on speed 1,2,or 3...sometimes you can fall inbetween and then it will do that...otherwise you may have overheated the drill and will need to deal with Grainger or another auth. Bosch dealer for warranty...if they don't fix you, buy a Hilti
Mar 02, 2009 | Bosch 13624 24V Cordless Hammer Drills
Bosch VSR 1199 hammer drill keeps slipping in hammer mode
Inside there is a little plastic shaft, where the selector hooks to. They have had problems over the years stripping. Replacement part is still plastic. Yay! You may need a bearing puller or find some way to get the clutch off the shaft. Lemme know. Please rate me
Jan 26, 2009 | Bosch 1199VSR 8.5 Amp 1/2 Inch Hammer...
Drills Logo
1,186 people viewed this question
Top Drills Experts
EugenesDIYDen
EugenesDIYDen
Are you a Drill Expert? Answer questions, earn points and help others
