Question about Samsung SGH-D500 Cellular Phone
Cannot get 'w' on phone to enter unlocking code
To get 'p' I press and hold * key but how do I get 'w'?
  • Samsung Master
  • 456 Answers
Just press and hold it till w appears or try the # key
Posted on Oct 06, 2008
My phone is locked....
Unlock Motorola CLIQ (SIM Unlock)
1. Reboot your Motorola CLIQ with an unaccepted SIM card in.
*If the display reads "Enter Special Code", enter the unlock code and press "OK"
*If the display does not read "Enter Special code":
2. Press and hold the * key until an entry box is displayed.
3. Type *, #, 3, 2, # and press "OK"
4. Enter your Motorola CLIQ's unlock code and press "OK."
5. Your Motorola CLIQ should now display either "Completed" or "Deleted"
Jul 16, 2011 | Motorola Mobility CLIQ Cell Phone
Tip
How To Enter Unlock Code Into BlackBerry Mobile Phones Step By Step Instruction...
Model: 6xxx 7xxx: Example; 6230, 7100, and 7290 etc.:
Before you start, you MUST take out the Sim Card & turn OFF ALL wireless radios
1. Press the Menu key
2. Select Options / Settings
3. Select Sim Card
4. Enter MEPD (not case sensitive), Note: When typing in MEPD, the letters will not appear on the screen
5. Then enter MEP Hold Alt Key and type number 2. NOTE: You must use the "alt" key to enable numbers, example: enter MEP hold "ALT key" and enter 2. Note: When typing in MEP2, the letters/number will not appear on the screen, this step open up the "Enter Network MEP" box. If you do not see "Enter Network MEP" box, you didn't type in MEP2 properly.
Model: 7100, 8100, 8110, 8120 & 8220:
2. Scroll to Turn Wireless Off and press the trackball (Will show Turn Wireless ON).
3. Scroll to Options and press the trackball.
4. Scroll to Advanced Options and press the trackball.
5. Scroll to SIM Card and press the trackball.
6. Type MEPD (not case sensitive). Notice: Keep in mind for mepd is meoop on these model. Because oo = p. Note: When typing in MEPD, the letters will not appear on the screen. This step opens up the personalization on the device.
7. Type MEP, then hold ALT key and type number 2. Note: When typing in MEP2 the letters/number will not appear on the screen, this step open up the "Enter Network MEP" box.
8. Enter Unlock Code
9. Press the Enter Key. (Make sure you press the Enter Key within 5 second or you have to enter the unlock code again).
Model: 8700, 8700c, 8700g, 8700r
2. Scroll to and select Manage Connections. Select Turn All Connections Off.
3. Press the red end key or the Escape key to go back to the Home screen.
4. Scroll to and select the Setting icon.
5. Scroll to Options
6. Scroll to and select Advanced Options.
7. Scroll to and select SIM Card.
8. Type MEPD Note: When typing in MEPD the letters will not appear on the screen. This step opens up the personalization on the device.
9. Type MEP then hold 'ALT" key and type number 2. Note: When typing in MEP ATL 2 the letters/number will not appear on the screen, this step open up the "Enter Network MEP" box.
10. Enter the unlock code.
11. Press the Joydial to confirm ("Code Accepted should display)
12. Press and hold the red End key to turn the handheld off and then back on.
13. Once the device has powered on, follow steps 1 & 2 and restore connections.
Model: Curve 8300, 8310, 8320, 8520, 8800, 8820, 8900, Bold 9000,Pearl 3G 9105, 9300 Curve 3G, 9630 Tour, 9650 Bold, 9700 Bold, 9800 Torch.
Before you start, you MUST have a Sim Card (could be Active or Inactive) & turn OFF ALL wireless radios
4. Scroll to and select the Options icon.
5. Scroll to and select Advanced Options.
6. Scroll to and select SIM Card.
7. Type MEPD Note: When typing in MEPD the letters will not appear on the screen. This step opens up the personalization on the device.
8. Type MEP then hold 'ALT" key and type number 2. Note: When typing in MEP ATL 2 the letters/number will not appear on the screen, this step open up the "Enter Network MEP" box.
9. Enter the unlock code.
10. Press the trackball ("Code Accepted should display)
11. Press and hold the red End key to turn the handset off and then back on.
12. Once the device has powered on, follow steps 1 & 2 and restore connections.
Method 1: Model: 9500, 9530 Storm, 9550 Storm 2, Telus, Bell Canada Storm
Before you start, you MUST have an Unauthorized Sim Card inserted. Unauthorized Sim Card is a Sim Card that is NOT belong to the provider of the phone. Example: If you have a Verizon phone, you need to insert a T-Mobile Sim Card inside the phone before turn it on.
1. Power on the phone.
2. Phone will said "MEP check failed. Do you want to enter MEP unlock code". Select Yes.
3. "Enter Network MEP code (# left)". Enter the unlock code.
4. Press Enter, you should see "Code Accepted"
5. You need to check Network Connection is set on GSM/UMTS. Menu>Manage Connection>Mobile Network Options and make sure it GSM/UMTS.
6. Once GSM/UMTS is selected. You can now ready to make phone call.
Notice: If the network not working after your phone is fully charged and unlocking process "Code Accepted". You must change from Verizon CDMA network to GSM Global Network a few times, after change from Verizon CDMA to GSM Global 3 times is completed, leaves it on GSM Global Network. Now it should work. (Verizon 8830 World Edition DOES NOT work in USA)
Method 2: Model: 8830, 9500, 9530 Storm, 9550 Storm 2, Telus, Bell Canada Storm
Before you start, you MUST have Sim Card inserted & turn OFF ALL wireless radios, turn the phone sideways so you get the full QWERTY keypad.
7. Type MEPD Note: When typing in MEPD the letters will not appear on the screen, this step open up the personalization on the device.
10. Press Enter (Press the trackball for 8830), you should see "Code Accepted"
11. Press and hold power key to turn the handset off and then back on.
You can get the unlock code through online..........give your IMEI number and get the unlock code for ur mobile.... i will suggest the website Unlock-Zone.com which is doing good service .....you can approach this website.
on Apr 08, 2011 | Cell Phones
Tip
How to enter unlocked code in BLACKBERRY phone?
<br /><br /><br /> TIPS on HOW to UNLOCK<br />BlackBerry HOW TO ENTER NETWORK UNLOCK CODES<br /><br /><br /><br />Blackberry Curve, 8800, 8300 8520<br /><br />Unlocking can be done without SIM card inserted<br />Turn wireless mode off<br />While on the home screen click the "Settings" icon<br />Go to "Options" menu and select "Advanced options"<br />Select "SIM card"<br />Hold the ALT key while typing MEPE. You will not see text appear on screen while typing<br />You should be presented with a prompt "Enter Network MEP Code"<br />Enter supplied unlock code<br /><br />8700c<br />To enter codes:<br /><br />-Go to options<br />-Advanced options<br />-Simcard<br />-type MEPD<br />-type MEP press"alt tab" type 2<br />-enter readed mep code<br /><br />7290<br /><br />Entering unlocking codes:<br />1 - Using the menu go to Settings Menu -&gt; SIM card press select.<br />2 - While holding the SHIFT key, type "MEPD"kanan<br />3 - You should now see the five locking categories listed.<br />4 - While holding the ALT KEY, type "MEP2" kaliwa<br />5 - Release the alt key.<br />6 - You are now prompted to enter the Network MEP code (will also state how many attempts left)<br />7 - Enter the code<br />8 - Enter Return/Enter<br />9 - The device should then be unlocked<br /><br />7100g<br /><br />go to settings , options , sim card , ten<br />Type 'MEPD' respectively 'MEPPD' in case phone is 7100<br />Usually u should see active NET lock. Now in order to disable this lock type 'MEP2' respectively 'MEPP2' if<br /><br />phone is 7100 and will appear a dialog asking for code<br /><br /><br /><br /><br /><br />Blackberry<br />5xxx, 6xxx, 7xxx Series (except for BB 7100 and 7130)<br />Turn wireless mode off<br />Go to "Options" menu<br />Go to "SIM card"then press the jogdial to select it<br />Type MEPD (not case sensitive). You will not see text appear on screen while typing<br />It will say "Network active"<br />Press and hold the ALT key (half moon looking key on the lower left side)<br />While holding the ALT key type in MEPE (not case sensitive). You will not see text appear on screen while<br /><br />typing<br />When prompted enter supplied unlock code<br />After entering the code press the jog dial<br />Your phone is unlocked<br /><br />Blackberry 7100, 7130<br />Turn wireless mode off<br />While on the home screen click the "Tools" icon<br />Go to "Options" menu<br />Select "Settings"<br />Go to "SIM card" then press the jogdial to select it. You should see the phone number and the SIM ID number<br />Type MEPP2 (not case sensitive). You will not see text appear on screen while typing.<br />Press ALT and 2 simultaneously to get number 2.<br />Enter supplied unlock code<br />After entering the code press the jog dial<br />Your phone is unlocked<br /><br />Blackberry 8100 Pearl<br />Unlocking can be done without SIM card inserted<br />Turn wireless mode off<br />While on the home screen click the "Settings" icon<br />Go to "Options" menu<br />Select "Advanced options"<br />Go to "SIM card" then press the jogdial to select it<br />Type MEPP2. You will not see text appear on screen while typing<br />Press ALT and 2 simultaneously to get number 2.<br />Enter supplied unlock code<br />After entering the code press the trackball once<br />Your phone is unlocked<br />If the unlocking code is entered incorrectly the next attempt to unlock the device will be delayed for 10<br /><br />seconds increments. The number of unlocking attempts is limited. When this number is reached the phone will<br /><br />be permanently blocked.<br /><br />alternative instructions<br /><br />Insert SIM card into the device<br />Power on the phone and turn Wireless Off<br />Go to "Settings" then "Options" menu and select "Advanced options"<br />Go to "SIM card" then press the jogdial to select it<br />Type MEPPD. Please note that you will not see what you type on the screen.<br />Type MEPP2. You will not see text appear on screen while typing<br />Press ALT and 2 simultaneously to get number 2.<br />Enter supplied unlock code<br />After entering the code press the trackball once<br />Your phone is unlocked<br /><br />alternative instructions for some Vodafone Blackberry 8100<br /><br />Insert non original SIM card into the device<br />Power on the phone and turn Wireless Off<br />Go to "Settings" then "Advanced options"<br />Go to "SIM card" then press the jogdial to select it<br />Type MEPP2 while holding Alt, multitap enabled (hold [Alt], type [M] [ER] [OP] [OP] [TY]. Please note that<br /><br />you will not see what you type on the screen.<br />When prompted with "Enter Network MEP code (255 left)" on the screen, enter the 16-digit network unlock code<br /><br />provided for your phone, then press Enter<br />Pull the battery out of the phone<br />Switch the phone on and the phone will be automatically unlocked<br />If the unlocking code is entered incorrectly the next attempt to unlock the device will be delayed for 10<br /><br />seconds increments. The number of unlocking attempts is limited. When this number is reached the phone will<br /><br />be permanently blocked.<br />To unblock such phone, it must be taken to a RIM service centre. No outgoing calls including emergency call<br /><br />is possible when the phone is blocked.<br /><br />Blackberry Curve, 8800, 8300<br /><br />Unlocking can be done without SIM card inserted<br />Turn wireless mode off<br />While on the home screen click the "Settings" icon<br />Go to "Options" menu and select "Advanced options"<br />Select "SIM card"<br />Hold the ALT key while typing MEPE. You will not see text appear on screen while typing<br />You should be presented with a prompt "Enter Network MEP Code"<br />Enter supplied unlock code<br />After entering the code press the trackball once<br />Your phone is unlocked<br />If the unlocking code is entered incorrectly the next attempt to unlock the device will be delayed for 10<br /><br />seconds increments. The number of unlocking attempts is limited. When this number is reached the phone will<br /><br />be permanently blocked.<br />To unblock such phone, it must be taken to a RIM service centre. No outgoing calls including emergency call<br /><br />is possible when the phone is blocked.<br /><br />alternative instructions<br /><br />Turn wireless mode off<br />While on the home screen click the "Settings" icon<br />Go to "Options" menu and select "Advanced options"<br />Select "SIM card"<br />While holding the ALT key type MEPD. You will not see text appear on screen while typing<br />While holding the ALT key type MEPE. You will not see text appear on screen while typing<br />You should be presented with a prompt "Enter Network MEP Code"<br />Enter supplied unlock code<br />After entering the code press the trackball once<br />Your phone is unlocked<br /><br />Blackberry 8700, 8700c, 8707<br /><br />Unlocking of these models requires a SIM card inserted (active or inactive)<br />Turn wireless mode off<br />While on the home screen click the "Settings" icon<br />Go to "Options" menu and select "Advanced options"<br />Select "SIM card"<br />Hold the ALT key while typing MEPE. You will not see text appear on screen while typing<br />You should be presented with a prompt "Enter Network MEP Code"<br />Enter supplied unlock code<br />After entering the code press the trackball once<br />Your phone is unlocked<br /><br />Blackberry 8230 Curve<br />Press the "menu" key<br />Scroll and select "Manage connections"<br />Select "Turn all connections off"<br />Press "Escape" to go back to the "Home" screen<br />Go to "Options" menu and select "Advanced options"<br />Select "SIM card"<br />Hold the ALT key while typing MEPD. You will not see text appear on screen while typing. This opens up a<br /><br />personalization menu<br />Hold the ALT key while typing MEP2. You will not see text appear on screen while typing<br />Press ALT and 2 simultaneously to get number 2.<br />You should be presented with a prompt "Enter Network MEP Code"<br />Enter supplied unlock code<br />After entering the code press the trackball once<br />Restart your phone and restore connections by following the first two steps<br />Your phone is unlocked<br /><br />Blackberry 9000, 9500, 9530 Storm<br /><br />Insert any sim card<br />Scroll and select "Manage connections"<br />Select "Turn all connections off"<br />Press "Escape" to go back to the "Home" screen<br />Go to "Options" menu and select "Advanced options"<br />Select "SIM card"<br />Select "Show keyboard"<br />Hold the ALT key while typing MEPD. You will not see text appear on screen while typing. This opens up a<br /><br />personalization menu<br />Hold the ALT key while typing MEP2. You will not see text appear on screen while typing<br />Press ALT and 2 simultaneously to get number 2.<br />You should be presented with a prompt "Enter Network MEP Code"<br />Enter supplied unlock code<br />After entering the code press the trackball once<br />Restart your phone and restore connections by following the first two steps<br />Your phone is unlocked<br /><br /><br /><br /><br /><br /><br />8310<br /><br />how<br /><br />Go to "Options" menu and select "Advanced options"<br />Select "SIM card"<br />While holding the ALT key type MEPD. You will not see text appear on screen while typing<br />While holding the ALT key type MEPE. You will not see text appear on screen while typing<br /><br /><br />8830<br />How to enter codes in BlackBerry<br />1. Insert any sim card<br />2. Turn off all of the wireless connections<br />3. Go to Options<br />4. Select Advanced Options<br />5. Select SIM Card<br />6. Hit menu select show keyboard (where needed)<br />7. Type MEPPD or MEPD (you will not be able to see the typed info)<br />8. Enter ALT MEP2 or MEPP2<br />9. Now it will say enter network mep code<br /><br />
on Feb 12, 2011 | Cell Phones
How to unlock my motorola milestone for free
You must have a Motorola unlock code to unlock your phone. If you have it:
1. Reboot your phone with an unaccepted SIM card in.
4. Enter your Motorola unlock code and press "OK."
5. Your Motorola phone should now display either "Completed" or
"Deleted"
Mar 15, 2011 | Google Android
How to open line motorola quench cellphone?
"Deleted"
Note: The free unlock instructions provided on this site only work with GSM or SIM card versions of the Motorola Quench. As always there may be already unlocked versions of this mobile phone, but generally cost a lot more then unlocking it yourself.
http://www.globalunlock.com/phones/home..YOU CAN TRY ALSO.........
Mar 02, 2011 | Computers & Internet
Tip
Unlock NOKIA without unlock code
If you forgot your phone password and you are not getting it and you also don't want to reset your phone, then you should try following steps to unlock it without entering password:
  1. Press Right Selection Key to enter unlock screen where you are asked to put pass code.
  2. Press Left Selection Key to go back to stand by screen
  3. .Press Red Button.
  4. Again Press and hold Right Selection key till you are prompted [Now press *].
  5. Press [*] immediately as you are prompted while releasing Right Selection Key.
  6. Your cell is unlocked.
Watch this video for more detail. This trick works on many other Nokia phones too like NOKIA 1110,1110i,1600 etc
on Dec 10, 2009 | Cell Phones
Need unlock code for Sidekick 3
1. Press and hold the * key until an entry box is displayed, then let go
2. Enter *, #, 3, 2, # and press "OK"
3. Enter the unlock code and press "OK." The display should read "Completed" or
"Deleted" Source(s): http://www.radwin.org/michael/blog/2004/… Good Luck and please rate
Sep 18, 2009 | T-Mobile Sidekick® 3 Cellular Phone
How do you send a text to all the people in a category?
  1. Insert the SIM card you wish to use.
  2. Turn the handset on.
  3. The phone will show "Enter Subsidy Code".
  4. Enter the unlock code we provided.
  5. If the phone does not ask for the code then try the following:
    • Insert the new SIM card.
    • Turn on your handset.
    • Press and hold the * key until a box appears.
    • Enter *#32#
    • Press OK
    • Enter the unlock code
    • The handset is then successfully unlocked.
    If you have a Motorola V10 and your phone is saying "subsidy lock enabled", please follow the instrucrtions below:
    When the message appears press continue. Then enter **057* and the phone will then ask you to enter the unlock code.
Jul 07, 2009 | Motorola Mobility RAZR2 V8 Cellular Phone
Need to unlock a Nokia 6103b
Unlock your phone
  • Press Menu, enter the lock code, then press OK.
Answering a call when the phone is locked
  • Press Answer.
To change the lock code of your phone
Your phone's lock code is used to lock and unlock your phone.
The default lock code is 1234.
  1. Use Menu 4-3-2-3 (Settings - Security settings - Access Codes - Change lock code) to change the lock code.
  2. When the phone requires the lock code, it displays "Enter lock code:".
  3. Enter the code, then press OK.
If you enter a wrong lock code five times in succession, your phone prompts you for the security code.
Saving the unlocked phone number
Use Menu 4-3-2-2 (Settings - Security - Settings - Unlocked phone number) to save a number that may be called even when your phone is locked. You will be required to enter the lock code.
  1. Calling the unlocked phone number.
  2. Press the Up or Down arrow keys or or manually enter the number exactly as it is saved, then press Call.
Note: The More key will pause the automatic scrolling of the help text. Pressing the More key or the Up or Down arrow keys will toggle through the pages. The More key is only displayed when the help text is displayed.
Jan 26, 2009 | Nokia 6103 Cellular Phone
How to unlock my firefly
With ATT sim in phone, Power on & wait to initialize.
Then, press & hold the green key until the "Enter Pin Screen".
Then, press red button 5 times until the exit is displayed.
Then press & hold the phonebook key til the "unlock code screen".
Press the phonebook key once then. To enter the code you use the green & red keys to scroll to the proper numbers to enter 6 digit code.
You scroll to the proper number and press the phonebook key at the number you select until the entire code is entered.
Once done, you will scroll to the "done" and press the phonebook key once.
Jan 10, 2009 | FireFly Cellular Phone
Samsung SGH-D500 Cellular Phone Logo
19 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
