Question about Toshiba 36A50 36" TV
Picture only in middle of screen
About 3-4 inches of picture in middle of screen -top & bottom of screen is black
  • 3 Answers
Sounds like vertical problems on your circuit board. Unless you have some electronics experience you'd better take it in for repair.
The inside of a tube TV contains high voltages even when off and unplugged.
GL
Posted on Oct 04, 2008
I bought an LCD Samsung 3 years ago and about a year ago a thick black line appeared in the middle of the screen. Can this be fixed at home?
check if the lines appear on different inputs or source like hdmi,av,pc, if it happens on a different source then theres a problem with the lcd screen it needs to be fix.
Dec 26, 2014 | Samsung Televison & Video
Vertical blanking
CHECK C2C52 10 UFD @ 50 V OFF THE BASE OF Q2C51 ON THE SIGNAL PCB. 2. CHECK C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01 AND IC2P01 PART # 270P466020 (9-VOLT REGULATOR). BOTH ARE ON THE SIGNAL PCB.
Dec 06, 2007 | Mitsubishi VS-60705 60" Rear Projection...
Samsung TSL2793HF - Slight Right Side Pincushion and Horz Line Bottom to Top Until the TV Warms up
Yes, this is rare but I have seen it before--not fixable if it is what I think it is----It is what is called a Dome effect---the shadow mask in the picture tube is actually contracting and or expanding depending on temperature---
Directly behind the phosphor coating (the stripes that you see on the screen) is a metal screen--the holes or perforations in it line up with the stripes on the phosphor screen.
Some masks either have a material or a defect causing the dome effect----Not likely to be anything else---a Pin amp problem will not usually act the way you describe but a shadow mask inside the picture tube will act exactly that way.
Dec 02, 2012 | Televison & Video
Big black square in middle of screen picture top to bottom about 36 " wide good audio and picture 6" on right and left side displaying.
If you have tried using different input devices, looked for loose contacts
in power outlet, RC Jack, cable and connectors, the TV might need service.
Aug 26, 2012 | Hitachi 55HDS69 55 in. Plasma Television
My screen is black at da top and bottom but its a pic in the middle.its just not showing the whole picture
it sounds like you have a widescreen video on your 4:3 tv. the black bars on top and bottom widen the screen picture.
Nov 05, 2011 | Symphonic ST419E TV
A black line running verticall down the middle of
There is no invertor board on a plasma tv. The fault is the X address buffer board. This is located on the bottom of the screen and runs horizontally the whole width of the screen. If you remove the heatsink plate that covers the x address boards and you need to look at the screen ribbon at the same position as where the bar is (in the middle).Vary gently lift the Xbuffer ribbon lock and gently take out the ribbon.Clean the contacts very carefully with a fibre pen or an electrical cleaning fluid.Insert ribbon back and heatsink and check.Here is a picture of the board and ribbon
a 1 inch bar is associates with 1 ribbon fault. So if the bar was 3 inches in from the left of the screen, the faulty ribbon will be 3 inches in from the right working from behind the TV. If cleaning dont cure the fault, then the Buffer IC will be blown and order a new centre buffer board (you can buy off Ebay)
Feb 17, 2010 | LG 42PG20 42 in. Plasma HDTV
Mitsubishi VS-60111 picture distorted
how do I manually switch my t.v. from 480i to 1080i on dtv with remote.
Dec 31, 2007 | Mitsubishi VS-70707 70" Rear Projection...
Picture is off kilter on Samsung HLM5065W
It is a setting in menu just play with it you will get it wright.
Oct 25, 2007 | Samsung HLM5065W 50" Rear Projection...
Panasonic pt51hx40b
If the bottom 8 inches of the screen is black then you likely have a failed part in the vertical output circuits. If you can still see video clear to the bottom, then your convergence IC's (IC7001 and 7002) may have taken a dump on you. Worst case would be a failure in one or more of the 3 yokes in the set that attach to the CRT's. If the sets less than 10 years old, it may be worth repairing. Otherwise, a nice NEW HDTV would be in order.
Jan 02, 2007 | Panasonic PT-51HX40 51" Rear Projection...
Toshiba 36A50 36" TV Logo
115 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
