Question about SMC Barricade g SMC2804WBR Wireless Router
No activety on smc bARACADE WBR ROUTER.
My wireless router smc barracade 2804 wbr was initially working until approx 1 week ago worked ok for 3 years .
Then . The provider sever ws down for a few days.Therafter when the provider server was back online the wireless laptop and desktop worked for one day. After the system was turned off for the evenng I was no longer able to use the router. I am directly connected to the modem which works fine. I have replaced the ethernet cables, All lights on the modem are solid with the exception of the act light (activity) Waht could the problem be. I can no longer use my wireless laptop or connect to the router?
I have ubplugged the router and modem waited 1 minute then turned on the modem another and then turned on the router. Still no success.
Thank-you
5 Suggested Answers
rahul26485
  • 611 Answers
SOURCE: smc289wbr wireless could it be a cable problem
re-configure the router properly and get the right details from your isp.(internet service provider)
Posted on Dec 13, 2008
kamal1984
  • 1383 Answers
SOURCE: dlink wbr-2310 router no wireless working
you have to change your channelk type in your wi fi router.
For that access your router with following link
http://192.168.1.1 or
http://192.168.0.1
if you have belkin router
http://192.168.2.1
type user name as "admin" and password is "admin" or blank or "password"
then go to wi fi ->advanced setup chang channel type 4 ,6 ,11
change chanel type 1 by 1 and check signal strength.
everyt time save settings and restart both computer and router after save settings.
Thanks for using fixya.
Please rate this solution if it helps.
Posted on Jul 23, 2009
govinda123
  • 2260 Answers
SOURCE: windows 7 not connecting with wbr-2310
You will need to check the wireless settings of the router
is there any computer connected to the router ?
If yes then you can open the router set up page on that computer.
Router set up page is the page where you can check all the wireless settings of the router.
Click here for step by step instructions
Posted on Jan 19, 2010
SOURCE: D-link WBR-2310 has serious drop out problems
https://spreadsheets.google.com/viewform?formkey=dGNHT2tRS1RscnI1ZV96THpzRWgxVVE6MQ
Posted on Oct 19, 2010
I have a D Link WBR 1310 router. Is this outdated and would it solve my intermittend internet service if I should upgrade?
The d link wbr 1310 is end of life in the us as of may 1 2011. I have a dir-615 that I stopped using 2 years ago b/c of connection problems and I believe the dir-615 is newer. I think you should upgrade.
Jul 24, 2011 | D-Link DIR-615 Wireless Router
My internet via ethernet works perfect, but got dropped a lot via my 3 years old D-link WBR router. Is this an indication that I should replace my router?
Try changing channels, it could be RF noise from some near by device, you could also try updating the firmware to the latest version, some times moving the router in a different location could help.
Jan 04, 2011 | D-Link RangeBooster G WBR-2310 Wireless...
Hi I have an SMC baracade g wireless router and want to connect my samsung galaxy 580 phone to it wirelessly. My computer connection is working. The phone detects it fine and can see that it has WPA/WPA2...
Hi
Try to unplug the power cable of your router for a minute or 2 to re-establish its connection to server. Then try reconnecting to your home network.
Hope this helps
Dec 09, 2010 | SMC Barricade 7004VWBR Wireless Router
About two months ago, we started noticing our wireless connection cutting in and out. It has gotten worse and now, we can't even get on the internet. It's not our computer because my daughter's computer...
Reset the router to factory settings and test. Please remember that security settings may be restored too here, so you may need to encrypt the signal. You will need to log into the router's configuration page in order to achieve these. Also try changing the channel in terms of broadcasting... and test again. I hope I have helped here. Good luck.
Oct 27, 2010 | D-Link 802.11g Wireless Router WBR-1310...
My WBR-1310 doesn't do wireless to my laptop.
theres a couple of version of this router http://www.dlink.com/products/default.aspx?pid=WBR-1310&tab=3 I'm using the manual from here http://www.dlink.com/products/?tab=3&pid=WBR-1310&rev=WBR-1310
on a working PC download and install this program http://www.xirrus.com/library/wifitools.php this will detect all the wireless signals being broadcast - see if the router is actually broadcasting - if it is detected on your PC then it may be that 1) the firewall is blocking access or 2) the security code is entered wrong - -log into the router and remove the wireless security and see if you can now detect
Mar 18, 2010 | D-Link 802.11g Wireless Router WBR-1310...
Wireless signal stops working after some period of time
The final solution is a factory reset of your router. You can do a factory reset by logging into the router using you browser. Go to the settings and perform a factory reset
If you forgot the router password, you ill have to do a factory reset by locating a small hold on the back of the router and insert the tip of of paper clip for about 10 seconds while the power is on. The router will be reset to out of box status and then you can set-up form scratch.
Sep 26, 2009 | D-Link RangeBooster G WBR-2310 Wireless...
Wireless conection on off on off every 3 second
try the following separately each time:
1) Turn off the power off the router, turn off the PC, turn on the router, turn on the pc after a minute or two.
If this does not work, Try:
2) Remove the Wireless router Definition on your PC and reinstall it. Make sure that you are using the correct Passwords between the router and the PC.
Aug 13, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Dlink wbr-2310 router no wireless working
http://192.168.0.1
http://192.168.2.1
Jul 23, 2009 | D-Link RangeBooster G WBR-2310 Wireless...
D-Link Wireless Router WBR-2310 no reception
There can be a problem with the router, first thing that you can do here is to reset it by pressing the reset button of the router for 30 seconds while the power is ON then after that unplug the power of the router for 10 seconds and if you still have the setup CD you can just run it to your computer to reconfigure the router back but if not you need to manually configure the router and also do a firmware/software update for the router and if you're not familiar that you can contact this number so a tech can wlak you through with the process of checking the router and making it work again, this is the number that you can dial 1-877-787-8749 for help......
Oct 20, 2008 | D-Link RangeBooster G WBR-2310 Wireless...
Smc289wbr wireless could it be a cable problem
Oct 13, 2008 | SMC Barricade g SMC2804WBR Wireless Router
SMC Barricade g SMC2804WBR Wireless Router Logo
71 people viewed this question
Top SMC Computers & Internet Experts
Prashant M
Prashant M
Larry Maranto
Are you a SMC Computer and Internet Expert? Answer questions, earn points and help others
