Question about Uniden Lands Phones
Recording message I have misplaced my instsruction book and somehow it now picks up after 2 rings and a man's viuce guves nessage, How do I record a new message? Thanks.
I downloaded the instruction book from Uniden and then was able to solve my problem.
Posted on Oct 05, 2008
My Vtech phone answering machine no longer records incoming messages on its base. Help
From the sound of it it I think its either: your mailbox is full or the feature has been turn off accidentally.
Vtech's support recommend the following (I've removed things like 'make sure its plugged in' and 'is your answering system is turned on' etc..)
1 Some answering systems have an announce only option, which plays your greeting but won't record messages. Make sure your system is set to record messages.
2 Your answering system's message capacity may be full. You must erase old messages to make room for new ones.
3 If you have voicemail service in addition to your answering system, your caller's message may be going into voicemail before your answering system picks up the call. Program your voicemail to pick up at least 2 rings after your answering system is set to answer the call.
May 05, 2014 | Vtech 5.8GHz Cordless Phone with Digital...
I am having trouble putting a new message on my answering machine
Select the type and model from the list beginning here.
Jan 18, 2012 | Uniden Lands Phones
Answering system records message after hang up
One thing to try and take note of is when the message does pick up on the "two ring" message present part do you hear on your side two full rings before the pick up?
It may be that the primary ring starts on the home side as does happen sometimes with VOIP service. If you are only hearing 1 or 1 1/2 rings before the message picks up then you might try hanging up after the second full ring thus knowing no messages are present and it should overcome your problem.
Dec 12, 2009 | Uniden Cordless Phone
I have misplaced my manual for my ntl d5100. Could
make sure you turn your answer button on after some will turn off when you change options
Oct 06, 2009 | Lands Phones
Instruction Manual
GE Digital Messaging System ~ Voice/Time/Day stamp
1a] press and hold down STOP/set button and wait for promps.....
ie. press NEXT to change Day stamp and then SET to pick.
ie. press NEXT to change Hour and SET to pick.
ie. press NEXT to change Minute and SET to pick.
1b] press NEXT to pick 1minute allowance recording for recieving messages coming in, or 2 minutes or 3 minutes or 4 minutes. This machine only has 1/2 hour of recording time, so maybe you can 'tell' -record- that and let incoming callers know they have only minutes and machine will automatically shut off and cut them off [hang-up] on them.
2] press and hold down Greeting button and follow promps to change the answering machine voice promps to your own voice. Machine will automatically PLAY BACK your voice, if you don't like what you hear, press and hold down Greeting button again and try again.
~ hope all above helps.
May 10, 2008 | GE 29888GE1 Digital Answering Machine
Phone rings many times with no answering message coming on and no messages recorded
I can't seem to get the security code entered.  It won't change.  None of the numbers will change when I try to set it up.
Jan 28, 2008 | GE 29878GE1 Digital Answering Machine
GE Telephone answering machine will not work
I'm assuming this is a digital recorder and does not use a tape. Any chance the memory is full and you need to erase messages to free up space for new recordings?
Jul 01, 2007 | GE 29897GE1 Corded Phone
How to change Flash timing
The only reference to flash timing I can find in the manual is shown below for you, also here is link to manual :
I hope it helps !
http://www.uniden.com/products/productdetail.cfm?product=TRU8885-2
If you have Call Waiting service and a call waiting
tone sounds while you are on a call, press talk/flash
on the handset or flash/find hs on the base to accept
the waiting call. There is a short pause, and then you
will hear the new caller. To return to the original
caller, press talk/flash on the handset or flash/find
hs
on the base again.
Setting the Ring Time
Ring Time allows you to set the number of rings the caller hears before your
answering system plays the outgoing message. You can set the ring time to answer
after two, four, or six rings. If you enable the Toll Saver (TS), the answering system
picks up after two rings if you have new messages and after four rings if there are
none.
1) Enter the Answ. Setup menu, and then the Ring Time
submenu (see "Entering the Menu" on page 16).
2) Press volume up/down to select a Ring Time (Toll
Saver, 2 Times, 4 Times, or 6 Times).
3) Press the OK soft key. You will hear a confirmation tone.
Setting the Record Time
Record Time sets the duration for recording the incoming messages. You have three
record time options. The options "1 minute" or "4 minutes" set the duration for
recording the incoming messages. "Announce only" answers the call but prevents
the caller from leaving a message.
1) Enter the Answ. Setup menu, and then the Record
Time submenu (see "Entering the Menu" on page 16).
2) Press volume up/down to select Record Time
(1 Minute, 4 Minutes, or Announce Only).
May 03, 2007 | Uniden TRU8885-2 Cordless Phone
Lands Phones Logo
109 people viewed this question
Top Uniden Lands Phones Experts
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
