Question about Lexmark Office Equipment & Supplies
Can`t Rinstall with original disc in new computer
    President:
  • 2,712 Answers
Probably you are installing the wrong version for your OS. Go to http://lexmark.com and select your model and OS and download the software. That should work. If you are not sure where to download, please reply with the model of your printer and the OS you have and I will try to find the download for you.
Hope that helps! Should you have any further questions,please feel free to post them here.
P.S. - If you find that the solution/answerI provided led you to, or resulted in a fix, please close the ticket with a FixYa!rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Posted on Oct 04, 2008
  • Lexmark Master
  • 1,879 Answers
Then go to www.lexmark.com to get all the software for free. yes it's free.
Windows XP will not open on e-machine gl1300g
you can downlaod a xp fixer disc that you burn to a cd or downlaod windows xp and burn to a disc to rinstall if you do i suggest using power iso to burn it
Feb 17, 2010 | E-Machines eMachines Desktop PC
Tip
Reset your Apple's Original Admin Password.
Resetting the original administrator account password Follow these steps to reset a password when there is only one administrator account on the computer, or if the original administrator account needs a password reset. "Original" administrator account refers to the one that was created immediately after installing Mac OS X. If the original administrator password is known, that administrator account may be used to reset the passwords of other administrator accounts using the steps described above. These steps require an optical drive; if your Mac does not have an optical drive and you have a Mac OS X v10.6 Install disc, see below.
  1. Start up from a Mac OS X Install disc (one whose version is closest to the version of Mac OS X installed). Usually, you can start from the disc by putting it in your computer, restarting, and holding the C key. Or, put it in the computer and click the Install or Restore icon you see in the disc's main window (after which the computer will start from the disc without you needing to hold C). Or, you can use Startup Manager or the Startup Disk preference pane to select the Install disc.
    Choose a language, click the arrow button to continue,
  2. Mac OS X v10.6 or later: Choose Password Reset from the Utilities menu.
    Mac OS X v10.5 or v10.4: Choose Reset Password from the Utilities menu.
    Mac OS X v10.3: Choose Reset Password from the Installer menu.
    Tip: If you don't see this menu or menu choice, you're probably not started from the disc yet.
    Note: The default keyboard layout is U.S. English while started from the installation disc. If you use a keyboard layout other than U.S English, use the Input menu (the flag icon on the right side of the menu bar) to select the desired layout before typing a new password.
    Select your Mac OS X hard disk volume.
  3. Select the user name of your original administrator account.
    Important: Do not select "System Administrator (root)". This is actually the root user. You should not confuse it with a normal administrator account.
  4. Enter a new password.
  5. Click Save.
  6. Click the red button in the upper left corner to quit the application.
  7. Choose Quit Mac OS X Installer... from the Mac OS X Installer menu.
  8. Click Restart.
After following these steps, you'll want to also follow the steps in this article.
Mac OS X v10.6: Resetting the original administrator account password on a Mac that has no optical drive
These steps require a second computer that has an optical drive.
Note: If the second computer is a Mac, make sure Mac OS X v10.5.3 or later is installed. If the second computer is a PC, make sure the DVD or CD Sharing Update 1.0 for Windows is installed.
  1. Open "Remote Install Mac OS X" from the Utilities folder.
  2. Follow the onscreen instructions.
on Feb 10, 2010 | Computers & Internet
How can I find the admin password on my mac. I had a new hard drive put in my pc. I want to change some of the admin settings but I need the password. How can I find it or change it without knowing the...
  5. Click Save.
  8. Click Restart.
  9. After following these steps, you'll want to also follow the steps in this article.
Feb 10, 2010 | Apple MacBook PC Notebook
I dont have sound of my cpu k8m800-m7a
According to your User Manual your motherboard uses a Realtek ALC655 chip. The driver for this can be obtained at:
Realtek ALC655 Download
(There are some links there also to aid you in installing the driver.)
You must enter the letters in the verification box and then click on Download.
Thanks for using Fixya.
Nov 18, 2009 | Biostar K8M800-M7A Motherboard
I forget username and passowrd in my MAC OS X Version 10.4.11,please findout the solution to restore my username and password.....
Did you lost the administrator password? There is a way to reset it. You will need the install disk in the resetting process. Please make sure you follow the steps accordingly.
From Mac OS knowledgebase:
  2. Choose a language, click the arrow button to continue, then choose Reset Password from the Utilities menu (or from the Installer menu, if using Mac OS X 10.3.9 or earlier). Tip: If you don't see this menu or menu choice, you're probably not started from the CD yet.
    Note
  3. Select your Mac OS X hard disk volume.
  4. Select the user name of your original administrator account.
  5. Enter a new password.
  6. Click Save.
Sep 04, 2009 | Apple Mac OS X 10.4
How to put song in the disc of mini disc amplifier?
You need a mini disc recorder to load songs to the disc. it's similar to burning a cdrw disc in your computer.I have a Pioneer PMD-R55-S portable mini disc recorder which been use once or twice and then stored back to its original box for years. if interested $ 160 + 6pcs new blank disc free. you can contact me at chaoyoc@gmail.com
Aug 15, 2009 | Kenwood KMD-673R MiniDisc Player
Not getting photo clerity
The software you are using to go to the internet is not working properly. Rinstall it.
Feb 26, 2009 | Compaq Presario 700 470024-192 Notebook
My computer says theres a phlishing problm why wont norton fix it
Rinstall Norton or Boot with the CD to perform a scan of your system.
Jan 10, 2009 | Computers & Internet
I have changed my computer and ive lost my set up disc for my all in one printer PIXMA MP510 can i get a replacment disc from canon.
If you have Windows Vista on your new computer, the original setup disc is not going to do you any good, as it did not have Windows Vista drivers on it. You can download drivers (for any Windows OS) from this link, as well as the software that was on your original disc (Easy Photo Print, etc.). Be sure and download the MP Navigator also.
Oct 08, 2008 | Canon Office Equipment & Supplies
Using roxio creator basic v9 when i burn disc its writing to the disc (700MB) without giving free space,i just made a copy of original cd which has 162MB,after writing to new disc,showing 700MB used..
Burned CDs always show as being fully used. That is so users don't think they can just copy files onto it. The way to find out how much free space is to subtract the amt. of space used from the capacity of the CD. Also most CDs are burn-once so after you burn it you can't add or delete files anyway. Only CD or DVD "RW" (read-write) discs allow you to re-use them.
Mar 08, 2008 | Computers & Internet
22 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
