Question about Canon Cameras
Canon 30D image transfer light is on (along with the LED indicator near the scroll wheel) when camera is powered on. No buttons or other functions will work.
  • Mel Jeffrey
    Mel Jeffrey Oct 04, 2008
    That's what the guy at 1800OKCANON has advised. A hard reset. I'm in the midst of attempting that right now. Thanks for the quick response!
    President:
  • 2,712 Answers
Try a hard reset - Remove batteries and SD card, wait for about 10 minutes and put them back and try again. If the camera still does not work, then you will have to either get it serviceed, or buy a new one (whichever works out cheaper for you ).
Posted on Oct 04, 2008
  • Swilin Sampson
    Swilin Sampson Oct 04, 2008
    Most welcome!
  • Swilin Sampson
    Let me know how it goes..And if it works, please dont forget to rate my solution :)
I am getting this message: WASTE NEAR FULL The waste ink tank* (which holds the ink used for print head cleaning) is nearly full. How can I fix it - the model is a Canon PixaMP110
One of these will reset the message. I reset mine about 2 years ago and have had no need to replace or clean the waste pad.
#1
printer powered off but connected on power source , you must:
1. Press & hold stop/reset button, and then press & hold [ON/OFF] button.
2. When Green power lit, leave stop/reset button & press twice stop/reset (see orange indicator).
3. Leave On/Off button. Printer in actually service mode.
4. Press stop/reset 4 times (see orange indicator) if not blink restart above process from top.
5. After press stop/reset 4 times successful press On/Off button 3 times. printer will off.
6. Press On/Off button.
#2
Waste ink full reset
These are the instructions which worked for me on my Canon pixma mp470:
1) Close the print head cover, and turn off the printer. While pressing the Resume/Cancel button, press the Power button. (Do not release the buttons. The LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (Do not release the Power button.)
3) While holding the Power button, press the Resume/Cancel button three times, and then release the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.) During initialization, the LED blinks in green.
4) When the LED stops blinking and lights in green, press the Resume/Cancel button the 4 times. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.)
5) Press the Power button. The LED lights in green, and the
selected function is performed. (When the operation completes, the printer returns to the menu selection mode automatically.)
6) Power off then back on and test.
Jul 23, 2011 | Canon Office Equipment & Supplies
Ink absorber is nearing full
Jul 12, 2011 | Office Equipment & Supplies
I get a message that says "Waste Ink Near Full".
3 choices are available. Take it in for service(expensive), try to clean waste ink pad yourself(messy) or try this reset yourself. It works on many different models and may be your answer.
I have been running my printer for approximately 2 years since resetting mine without a problem.
Mar 21, 2011 | Canon PIXMA MP780 All-In-One InkJet...
I HAVE A NEW POWER SHOT SX130 IS (CANNON0 I DO NOT KNOW HOW TODELETE THE DOWNLOADED PICTURES FROM THE MEMORY CARD
You can delete photos from your SX130 IS in two ways:
To Delete Photos Individually:
  1. Press Playback Mode button (looks like a play button and is located on the top right on the LCD-side of your camera)
  2. The last image you took will appear on the LCD screen.
  3. Use the Left & Right arrow keys or turn scroll wheel to cycle through your images
  4. Once you find an image you want to delete, press the Trash button. The image will be erased.
  5. Press the Playback Mode button or the FUNC/SET buttons to exit when done
To Delete ALL Photos
  1. Press the MENU button (bottom right button on LCD-side of camera) to bring up the Menu screen
  2. On the Playback tab (Looks like a Play button icon), use the arrow buttons or turn scroll wheel to scroll down to Erase. Press the FUNC/SET button.
  3. You now have three options Select, Select Range, and All images. Select will allow you to delete individual images, Select Range will allow you to select a series of images, and All images will delete all images from memory. This last one is the option we are looking for.
  4. Use the arrow keys or scroll wheel to choose All images
  5. Use the arrow key or scroll wheel to select OK when the Erase confirmation screen pops up.
  6. Your images will be erased!
Mar 14, 2011 | Canon Cameras
Alarm lights keep blinking after I changed my printer ink.
E5 means cartridges error - to fix press the "stop\reset" button for 5-7 seconds and then release it.
You can also try this:
1) With the printer power turned off but connected to a power source, while pressing the Resume/Cancel button, press and hold the Power button.
(DO NOT release the buttons. The Power LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (DO NOT release the Power button.)
3) While holding the Power button, press the Resume/Cancel button 2 times, and then release both the Power and
Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the Alarm and Power LEDs light
alternately, Alarm in orange and Power in green, starting with Alarm LED.)
4) When the Power LED lights in green, press the Resume/Cancel button the specified number of time(s)according to the function listed in the table below. (Each time the Resume/Cancel button is pressed, the Alarm and
Power LEDs light alternately, Alarm in orange and Power in green, starting with Alarm LED.)
4 times----Green (Power)------Waste ink counter resetting
Apr 07, 2010 | Canon PIXMA MP240 All-In-One InkJet...
Waste inki absober is full. The indicator orange
You can remove the top of the printer to remove and clean the pad or reset the printer and continue without cleaning.
These are the instructions which worked for me on my Canon pixma ip470 and has work on many other Canon models:
Feb 15, 2010 | Canon PIXMA iP90 Mobile Printer
Date imprint on photocamera
The EOS range does not automatically "imprint" the date/time on the images. Being digital, most of the information can be found in the EXIF data anyway. If you want to print the photos with the date at the corner, I believe ZoomBrowser EX has that function. ZoomBrowser came with your camera amongst a few other CDs (eg Adobe Photoshop Elements, DPP etc)
Jan 07, 2010 | Canon EOS 30D Digital Camera with 18-55mm...
There is an error message which says: waste ink near full what do I do next?
The printer will still work just fine, but the message will not go away. Changing the tank is a messy job and canon willtell you to take the printer to a service center. The following has worked to remove the message on my pc. Sorry, I'm not aware of the tank or pad cleaning procedure, but this should help with the message removal.
These are the instructions which worked for me on my Canon pixma ip90 bought August 06:
Dec 15, 2009 | Canon Office Equipment & Supplies
Canon 20d raw to pc
Have you ever been able to view the pictures on your pc?
Have you got a card reader that can view the card contents externaly from the camera?
I found the Canon software is quite as happy from a card reader as it is reading from the camera. (I have the next model up, 30D.)
Have you tried upgrading your software, or tried using a third party image program to read the raw files?
Over to you!
Dec 29, 2007 | Canon EOS-20D Digital Camera
Canon 30D
This is not a direct solution, but I find that my image transfers are much faster when I pull out the CompactFlash card and put it in a card reader to pull the imagery off.
With respect to the actual problem, try "rebooting" your camera (switch off, then on) and/or reseating the USB connector.
Oct 25, 2007 | Canon EOS 30D Digital Camera with 18-55mm...
Cameras Logo
56 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
