Question about Acer AL2416W 24 in. LCD Television
Is there a known issue w/the signal processor on this model?
I'm getting intermittent display black-outs. The power indicator remains green, so that means it's getting power, and valid video signal. Most of the time, powering down to reset the monitor will resolve the issue; - but sometimes I'll need to leave it off for 1/2 hour before it'll start working properly again. A real BIG annoyance!!!
PS. Its not a backlighting issue, since I don't see any 'shadow pictures' during the black-outs, just no display.
5 Suggested Answers
Benimur
  • 6966 Answers
SOURCE: Acer AL1716 (black) - Drops to No Signal -
Hi Eric,
Your post/description of "No Signal" and power LED changing from green to amber is indicative of just that - the monitor is not receiving any signal from the video card of the computer or the signal it is receiving is beyond its capability.
Just to verify that it is indeed the PC;'s setting that is the root of the problem and not an internal fault within the monitor, pls:
1. lower the screen resolution of your desktop's properties.
2. it may also be of help if you likewise lower the screen refresh rate.
Both of the above may be adjusted through the appropriate settings in your Display Properties.
If your concern has not been corrected after completion of the above procedures, pls post back details of your video card (brand/model), display properties settings: a) screen resolution, color quality and Advanced/Monitor screen refresh rate.
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FIXYA.
Posted on Feb 15, 2008
  • 63 Answers
SOURCE: Monitor receiving signal, but no image
Hello!
I see many monitor with that trouble.
When you turn on comp., you can have a picture on monitor about 10-30 min. and that go in black screen, or If you change resolution again go in black screen.
You must repair monitor or bay another.
Posted on Nov 02, 2009
budmrtn
  • 11361 Answers
SOURCE: picture only comes on for a second than goes off.
The problem can be the 18 or 24vdc power supply is bad or the backlight inverter board is bad. You need to open it up.
Service manual: http://elektrotanya.com/?q=showresult&megnev=Acer&megnev2=AL2416W%20&kategoria=&kat2=all
If you are going to DIY and have proper tools and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Posted on Jul 08, 2010
Idahoodini
  • 82 Answers
SOURCE: I use Acer AL1912 19inch
Sounds like the monitor is dying, if it starts to die more and more often you will likely have to replace your monitor before it goes completely out. There are not many ways for a user to repair a monitor, unless the problem is with the computer, which you could test by connecting a different monitor to the computer for a while (if available). Hope this helps!
Posted on Mar 15, 2011
When i turn on my Dell Inspiron 2400 Desktop Computer why won`t it start.
Is the computer plugged in to a known good power source with a known good power cord? Also, make sure the power is fully seated on both ends. When you press the power button are you getting any indicator lights? The power button itself has an LED that will be either solid green, blinking green, solid amber, blinking amber, or off. Do you hear any beeps?
May 19, 2014 | Dell Inspiron 530s Desktop Computer...
Lcd tv troubleshooting
Check for power supply trouble. The green LED on the front panel should light if power is getting to your TV. The "no signal" indication may mean no antenna or cable input is detected
Aug 21, 2013 | Televison & Video
The screen reads no signal
eMachines flat-screen monitors offer high quality at low cost.
eMachines flat-screen monitors are compatible with most brands of PCs.
Issues with eMachines flat-screen monitors can arise from faulty power sources, cable problems and incompatible settings.
These issues can be resolved by testing step-by-step each possible cause.
Plug the computer's power cable firmly into a working AC outlet.
Press the computer's power button.
Check the LEDs on the front of the computer case to confirm that the computer receives power.
Plug the eMachines monitor's power cable into a working AC outlet.
Press the monitor's power button.
Check the LEDs on the front bezel or power button of the eMachines monitor to confirm that the monitor receives power.
Orange or blinking LEDs indicate low power or no signal.
Green LEDs denote a working connection..
Perform a monitor self-test.
Switch off the monitor.
Unplug the video cable from the monitor.
Press the eMachines monitor's power button.
An eMachines logo, Windows logo or "no signal" message indicates that the monitor is working properly.
Plug the eMachines monitor's video cable into the video port on the computer.
Attach the monitor's included DVI-to-VGA adapter to the monitor's VGA cable if your computer has a DVI port (15 or 25 pin-slots with 1 side slot) in place of a VGA port (15 pin-slots, no side slot).
Press the eMachines monitor's input button to change the monitor's setting to match the computer port used.
Set your monitor to DVI if connected to your computer's DVI port.
Set your monitor to VGA if connected to your computer's VGA port.
Connect the eMachines monitor to a known working computer with a known working video cable if the problem persists. Contact Gateway, eMachines manufacturer, if the monitor issue is not resolved.
Jul 15, 2013 | Acer eMachines Black EL1850G-42w Desktop...
Black screen at startup
It sounds like the graphics card or on board graphics is causing the issue, as the external monitor is not working either. Hopefully its a graphics card which can be replaced easily, or there is an expansion slot for a graphics card to be added.
One thing you could try is resetting the CMOS by removing the battery from the motherboard and leaving for ten minutes. Replace the battery and try booting.
Mar 14, 2012 | ASUS Computers & Internet
I have a 46" Sanyo
In most cases the standby light might blink with different rapidity to indicate a fault relevant to the processor. It is possible that most of these indicate that there are errors in the processing section . Since there is a possible short or leak in the circuit the output driver section can take in huge current to trip the SMPS or from advice from the micro processor. Remove the power plugs and make sure that high voltage sections are discharged of the potential stored in capacitors. Look for visible signs of leak or of busted capacitors. Look for bulged capacitors or damaged components- burnt or busted. Use a multimeter to check the continuity or shorting in components, if so detach from circuit and test . If the voltage builds up and the set power ON and then shuts up then the suspected section must be checked in detail.
The processor must have the +5 voltage to the function properly , the +B and secondary voltages also must be checked to infer the fault. Trace with caution and in running through the signal path , circuit trail.
Jul 08, 2011 | Sanyo DP46849 46 in. HDTV
Monitor is on but screen is black. green light for switching it off/on does not do anything when pressed
Your monitor power supply has several capacitors going bad. You’ll need to have these replaced by a reputable repair person or check my website www.micromendllc.com. Thanks
Mar 01, 2010 | Dell E173FP 17" LCD Monitor
Monitor shows picture for 1/2 second then goes black, 22" display. also will not show display menus. have hooked another monitor up and works fine. also have hooked up to another computor and problem...
When you switch the monitors, do you still use the very same vga cable? If you don't, then it's time to change the monitor. When it turns on and off inmediately it means that it's receiving the signal, but that's it. If it's brand new, exchange it.
Sep 01, 2009 | X2Gen MW22U Monitor
SGI F180 Flat Panel Display no longer turns on.
If the power button does not stay on, the monitor might be burned out.
Aug 20, 2009 | SGI Silicon Graphics Silicon Graphics F180...
Vizio P50HDM No Picture/No Sound
this is most likely the sustainer board(s) problem. Replacing the sustainer boards should correct this problem for you. you can get the parts at vancebaldwin.com
May 29, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Green Display Problem
Hello vinodquilon,
The problem you described is more then likely related to the video processor. Possibly also some power supply issue, since the audio section is being effected also. Or this may be two unrelated problems in that case the video processor and the audio processor and amplifier should be suspect. This is how I would handle this problem:
1) Get the schematic for this TV
2) Tackle the video problem first
a) Locate the video processor connect a known video source generator (I use the Sencore VA62A) and take voltage measurements and compare them to the schematic values (For red, green, and blue), if the values are not as they should be, use and oscilloscope to look at the waveforms of the video section and compare them to the schematic values if they are not as they should be, change out the video processor. Retest the TV, this should take care of the video problem.
3) Tackle the audio problem
a) Using the audio section on the VA62A inject a 1000Hz tone into the TV and using an oscilloscope check the input to the audio processor and the output of the audio processor if you do not see a 1KHz sine wave on the output check the voltage levels and compare them to the schematic, if they do nor match change out the processor, if they do match and you see a 1KHz sine wave at the output of the processor, then check the input and output of the audio amplifier stage in the TV if there is no audio at the output change out the amplifier.
This is a good starting point, now I must be frank with you, I run a TV repair business and I do understand that you may not have , Video Signal Analyzer or Oscilloscope, and Video/Audio Signal generator, or even a multimeter to do this job correctly, so since I have told you how I would do this job and you can follow the instructions given and solve your problem, Let me advise you on what you should do,
If I were you and did not have the above equipment nor experience in electronics, I would take the TV to a qualified TV repair center and have it fixed there since they would have the necessary equipment to do the job properly.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Jan 21, 2009 | Televison & Video
Acer AL2416W 24 in. LCD Television Logo
112 people viewed this question
Top Acer Televison & Video Experts
Rommel Balcita
Martin Murray
Jaime Hernandez
Are you an Acer Televison and Video Expert? Answer questions, earn points and help others
