Question about GE Profile Spectra JGBP90 Gas Kitchen Range
Large burner only sparks for other values to light and won't light by its own switch
On the largest burner, the ignitor will not spark when I turn it on. It will spark when the other burners are turned on. I replaced the ignitor without success. I think it has something to to with this particular values spark switch. Can you help?
    Problem Solver:
  • 15 Answers
Sounds correct, if it didnt spark at all and you had not replaced the igniter I would check that the wire from that igniter be followed to the other end to verify that it had not come unplugged at the other end.
On a new range I bought that igniter would not spark even though the others did and its wire was unplugged
Posted on Oct 07, 2008
Front burner does not light and has no spark. Do I change the ignitor and if so, how is this done?
The spark switch attached to the gas valve is bad, but usually you have to replace the complete switch string. Yes, you are right, all the switches are wired in parallel, and all the ignitors spark at the same time, so if you get 1 burner sparking, they will all spark, and now you can turn on the gas valve with the bad switch, and it will light too. (That's your cheapest and easiest solution!)
Sep 19, 2014 | KitchenAid Kitchen Ranges
Jenn-Air JDG8430 Ignitor won't stop sparking after burner ignites
Test the ignitor first, if the ignitor does not spark should be the ignitor itself.
Oct 12, 2008 | Jenn-Air 30 in. JGD8430A Gas Cooktop
I havef a KitchenAid Gas Range Model KGSS907... and one of the ignitors on one of the burners is not sparking. I tried to take the stove top off to check the wire to the ignitor but don't see how to...
Typically the burner come off by removing the burner caps and inside the burners are 2 screws that hold the burner base to the top..yes you could swap igniters on all burners they will be the same. If by swapping the igniters it still doesnt work the things that could be the problem are;
the spark module espically if the igniter that doesnt work on that burner suddendly work on a different burner
the spark switch on the gas valve for that burner..typically all burners spark when one it turned on but the only one that lights is one that has gas flow to it..so turning on a different burner first and leave it set to light setting by turning on the one that doesnt light it will light if that spark switch is the problem
of course a cracked igniter
a broken wire from the spark module to that igniter taht doesnt work..its not that uncommon that the insulation will sometimes wear off a wire off so the electric that should be going from the spark module to the igniter is instead being grounded by that wire touching the metal on the frame uninsulated
Good luck,i hope i have been able to help you fix your range,
GENE
Aug 27, 2011 | KitchenAid KGSS907SSS Gas Kitchen Range
The ignitor keeps sparking and won't stop.Do not
First of all, the model number is under the cooktop bottom, and secondly, this can happen due to the burner switches got wet somehow. Best thing to do is to unplug unit for 6-12 hours, allow to dry, then re-plug unit back in, this should be enough time to dry out the burner switches.
Good luck
Jul 13, 2011 | Bosch Cooktops
Viking gas stove top ignitors sparking incorrectly
all ignitors spark at the same time no matter which burner is turned on. If you are having trouble with one burner not lighting try cleaning around the ignitor with a small screw driver so the spark has a good path to ground.
Mar 19, 2010 | Viking Kitchen Ranges
Ignitors on all burners are not working . gas is coming to burners , i can lite them with a match. i cannot hear the ignitors clicking when i turn the gas on for each burner either.
Hi, when any of the knobs is turned to the light position, all burners will spark. That being said, if one or more of the knobs is not switching the spark module, the problem is the switch mounted on the shaft of that burner valve. You need to replace the defective switch or you could turn on one of the good burners (to make the clicking occur) and then light the burner you really want.
Jan 24, 2010 | Whirlpool Kitchen Ranges
Ge profile gas range. one burner with no clicking and no ignition
You may have a bad burner switch. If you turn one of the other burner switches to make the spark modules spark look and see if the electrode is sparking at the bad burner. Most of the spark modules send a spark to all 4 burners when activated. If it sparks when another burner is activated open the valve and see if the burner will ignite. If so you probably have a bad burner switch.
Jan 10, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
Kenmore Elite 30" gas cooktop installed. Large right front burner
There are a series of holes in the burner leading down from the main flame area to the pilot tube, ensure the holes are not plugged/restricted.
Feb 11, 2009 | Kenmore 30 in. 42701 / 42702 / 42709...
High performance burner slow to light
Replace that ignitor on that burner only. Not drawing enough amps to spark properly.
Nov 26, 2006 | Jenn-Air JGC8536 Gas Cooktop
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
117 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
