Question about Panasonic Microwave Ovens
I just changed the light bulbs in the microwave and now I have no power to anywhere else but the lights?
  • 2 more comments
  • badavy13 Oct 05, 2008
    Hi
    The microwave is the Panasoninc Genius Prestige inverter 1100 watt model NN-P295.
    I did not unplug the microwave and I was changing the lights that shine on the cook top.
    The bulbs I purchased were 20 watt and the book says 30W max?
    Can you help Please!
    It is amazing how much a person misses a working microwave.
    Thanks
    Blaine
    I am in Canada so likely a US model
  • William Miller
    William Miller May 11, 2010
    The parts list only shows one fuse, so I'd say the circuit board is damaged, as often happens when the lights are changed with power still on.
    I'm still not sure if this is a US model, or an Australian model or both.
    Are you in the US?
  • William Miller
    Please reply back with your brand and model number so we can help you.
    Was the oven unplugged when you changed the bulbs?
    Which bulbs did you change, the internal lights or the lights that shine on the cook top?
  • Panasonic Master
  • 9,086 Answers
Okay, it may be the US model. It seems there is also an Australian version.
I've worked on a few of these Panasonic control boards. The solid state relay for the lights will short, and often this failure also takes other components with it, such as the regulator that runs the microprocessor. This makes the microwave in essence, dead, yet the lights stay on.
It can take a couple of weeks to get the parts, but if you'd like to get it repaired, we can usually do it for about $59.95. Since you're in Canada, there would be a little extra charge for shipping as well. About $15 is typical.
Feel free to contact me directly for more information & help if you're interested.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Oct 06, 2008
How do I change the light bulb in a magic chef microwave?
  1. Unplug the Magic Chef microwave from the wall outlet.
  2. Remove the screw from the light cover located on the left side of the underside of the microwave. ...
  3. Unscrew the light bulb, then screw in the new light bulb.
  4. Raise the light cover, then secure the cover with the screw that was originally removed.
More items...
How to Replace a Magic Chef Microwave Light Bulb ' Hunker
https://www.hunker.com/13407988/how-to-replace-a-magic-chef-microwave-light-bulb How do change the light bulb in magic chef microwave Google Search
Oct 24, 2017 | Magic Chef Microwave Ovens
How to change a light bulb in microwave
Things You'll Need
30-watt incandescent light bulb
Screwdriver
Light
Remove the screw from the light cover located on the left side of the underside of the microwave. The light cover is connected to a hinge and will lower, but cannot be removed from the microwave.
Unscrew the light bulb, then screw in the new light bulb. hope this helps
Oct 08, 2016 | Magic Chef Microwave Ovens
Change interior light In my ge pvm1870sm3ss microwave
have to take the outer shell off to access the light .
Mar 09, 2016 | GE Microwave Ovens
FGMV205K cover removal
Good Afternoon Friend,
I understand that you want to know how to remove the cover on your Frigidaire microwave, model# FGMV205K. There are two different covers that you are able to remove for access to two different light bulbs.
If you are trying to change the Microwave Oven Light for inside your microwave:
    1)To replace light bulb, first disconnect power to your microwave oven at the circuit breaker panel or by unplugging it.
    2)Remove the louver by removing the three Hood Louver Screws.
    3)Push in the upper tabs and pull the louver away from your appliance.
    4)Remove the light bulb and replace with a new 20 watt light bulb. DO NOT USE BULB LARGER THAN 20 WATTS.
    5)Close the Oven Light Cover by carefully pushing into place. Push the louver back into place (engaging both the bottom and top tabs) and change to hood Louver Screws.
    If you are trying to change the light bulbs underneath your Microwave:
      1)To replace light bulbs, first disconnect power to your microwave oven at the circuit breaker panel or by unplugging it.
      2)To open Light Cover, remove the screw on the light cover.
      3)Replace the light bulbs with new 20 watt light bulbs. DO NOT USE BULBS LARGER THAN 20 WATTS.
      4)Close the Light Cover and secure with screw removed at step 2.
      If further troubleshooting is needed, I ask that you please let me know the error codes displayed on your appliance. Hope this is helpful.
      -Best Regards-
      WP
Jun 07, 2014 | Frigidaire Gallery FGMV205K 2.0 cu. ft....
When the microwave is cooking the light inside dims. When done cooking the light returns to full brightness. Is that normal or is there a problem with the microwave?
I've seen this with most microwave ovens I've had. When the microwave emitter kicks in to cook, the unit uses much more power, providing less to the internal bulb, which dims a bit. Unless it's very dramatic, for example the bulb turning off or going almost out, it's normal behavior. If the bulb is going very dim or out, it could be that the circuit it's connected to isn't providing enough amperage to adequately run the oven. In the case of your microwave, it's rated at 15 amps, so should have adequate power on a standard household circuit by itself.
Apr 09, 2014 | GE Profile Spacemaker 1.8 Cu. Ft....
I need to change the interior light bulb in my Frigidaire over the counter microwave. The model # is FMV156DCA.
Good Morning Evelyn, thank you for allowing me to assist you!
Here are some simple troubleshooting tips to help replace the light bulb on your Frigidaire microwave, FMV156DCA.
    ·First, disconnect power to your microwave. This can be done by either unplugging it or at the circuit breaker panel.
    ·To release cover, remove the screw on the light cover (light cover may become very hot, do not touch glass when light is on).
    ·Remove old light bulb and replace only with equivalent watt bulb available from parts distributor or the manufacturer directly. Bulbs are also available at most hardware stores or lighting centers. Bulbs larger than 30 watts are NOT recommended.
    ·Close light cover and secure with screw removed in step 2.
    I hope this information proves to be helpful. If you have further questions, please do not hesitate to reconnect.
Nov 25, 2013 | Frigidaire FMV156DC Microwave Oven
I have power to the microwave but the microwave does not work
Check magnetone is workin or not and also check guider in microwave compartment
Oct 03, 2009 | Microwave Ovens
Bulbs UNDER the microwave burned out; new bulbs don't work
i know this is going to make no sense . but in my samsung service cd it is in BOLD PRINT YOU MUST DISCONECT POWER BEFORE REPLACEING BULBS , OR DAMAGE TO TIMER WILL RESULT ! the first time you changed them did you disconect power ? if not , your board might be toast , $$$$$$$$$
Jan 24, 2009 | Samsung SMH7174BC Microwave Oven
GE Spacemaker Microwave
yes there is. the fuse should be located behind the vent grill on the right side above the control panel. there may be a metal "grate" covering the access to it
Dec 24, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Hood lights
first remove mains cord from main power. and remove the microwave oven top cover and check the bulb and crefully remove the old bulb and put new bulb. at high voltagae section dont touch any thing ,that area very dangerous ,thats why very carefully work inside the microwave oven ..
Sep 09, 2007 | Goldstar MV-1320W/B Microwave Oven
Microwave Ovens Logo
114 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
