Question about Sony Playstation 3 (PS3) Console
Connecting x rocker chair to ps3
I have a x rocker gaming chair, i have no wires to connect it to my ps3, can you tell me what i need please
  • 6 more comments
  • lala0490 Nov 13, 2008
    i have the same problem but i have a v rocker chair. tho box says it connects via bluetooth. but i cant seem to figure it out
  • Anonymous Nov 28, 2008
    i have same problem with v rocker cant figure out how to connect wires and instructions are terrible.
  • Anonymous Dec 26, 2008
    we have a chair but no instructions no cables so no sound. we bought it from argos
  • jacquewebb Dec 26, 2008
    I have the same problem
  • Anonymous Dec 27, 2008
    my x rocker came with green and white av cables where am i ment to plug these into the playstation 3, can only find hd and usb ports?? Bought from Argos, states that it is playstation 3 compatible, how?
  • Anonymous Feb 01, 2009
    i have exactly same problem the instructions are terrible and the staff at helpline are useless they just say that they will get someone to call you back and dont bother
  • Anonymous Feb 21, 2009
    same here i cant get it to work either
  • sheldon Dec 25, 2012
    i have the new ps3 console and not a clue how to set up the x rocker pro x chair ........help !!!!!!!!!!!!
I HAVE THE SOLUTION for all ps3 and ps3 slim gamers with the x rocker chair. it took my 2 long hours of frustration but i finally figured out how to make it work with ps3 slim. okay, forget about the red and white audio output plugs, those aren't needed. (my tv has no audio output jacks so i had to find a different solution) find the cable with the green headphone plugs on both sides. plug one end into the tx box and the other into the headphone jack on your tv. make sure your sound settings on your ps3 are set normally so that the sound is coming out of the tv. turn on the tx box, turn up the chair volume (and volume on the tv) and there you have it. enjoy!
Posted on Sep 16, 2009
  • mar5hl Mar 03, 2011
    Far more simple than all that faffing with different coloured plugs! Thanks very much for taking the time to post this - I trawled through several sites in vain until I found your post! Gaming chair is now up and running, and I have a very delighted boyfriend.
  • needtoride66 Jun 23, 2011
    great saved me some time - thanks a lot
The way i get my x rocker chair to work with my ps3 is to connect the chair to the my television not the ps3. Firstly you have to connect your ps3 to your TV by using the red, white and yellow cables but you only plug in the yellow! My x rocker came with two little two-way plugs, you place these on the red and white cables. Then the green ended wire which came with the x rocker chair is used, you place it in the green slot on the chair ovbiously and the other ends of the wire which should be red and white ends go into the other end of the two-way plugs.
Posted on Jul 11, 2009
  • janemiller99 Jun 13, 2011
    OMG! thank you so much! it works perfectly. You are the best...you stated it simple and direct.
Just alter settings on PS3 to allow multiple outputs.Check under Sound menu.
Posted on Dec 27, 2010
Only problem with the red white and blue cable is that once your 10 year old has had ps3 on HD there is no way he even thought about going back !!!! i am going `to try a usb to audio adapter and hope it works as the tv in sons room is lacking audio out and headphone socket but it has a usb port so i hope to get his chair to work thru that or the port on ps3 also it is the x rocker that i have and i cant see any indication that it is wireless other than a small bit in the instruction book that mentions a wireless connection but no instruction on how to connect it!!! i will let you all know how the usb plan works out
Posted on Feb 15, 2010
Are you sure it is the x rocker model you have, and not the x rocker V Rocker? the X Rocker is a wireless gaming chair, and the V Rocker is one with the wires (power wire and audio inputs)
Posted on Oct 27, 2008
Power plug on chair losing power
The problem may be that the power cord's internals were broken by keeping the wire plugged into the chair at a bad angle That damaged the connection. If this is the case, you may need to purchase a new power cord.
Try shopping online for a replacement or calling the manufacturer.
Jun 01, 2012 | Pyramat Sound Rocker Gaming Chair
Ive brought a pyramat llc sound rocker s2500 and would like to know how i connect it to my ps3 thanks
Here is a PDF version of the Owner's Manual for your gaming chair:
http://www.pyramats.com/manuals/s2500w.pdf
This will instruct you on how to properly connect the chair to your Playstation 3 console.
Mar 01, 2011 | Pyramat Sound Rocker Gaming Chair
I have my PS3 connected with an HDMI cable and my TV has no audio output as I can get it to work without disconnecting my HDMI cable
you have to set the audio to something other than hdmi if you are using the chair for the sound so choose a different sound option
Aug 11, 2010 | Pyramat Sound Rocker Gaming Chair
X rocker wireless chair how do i connect to ps3 please any help ta
yea i had the same problem so after 3 days i took it back 2 wal mart an the said sometimes it wont connect srry this is no help but they gave me my money back. my ps3 turns blue green amber then red blinking any suggestions?
Feb 18, 2009 | Sony Playstation 3 (PS3) Console
X rtocker pro gaming chair no instruction
there should be either wires to connect to xbox or theres a wireless reader that you insert into tv or xbox, if not, try to see if the chair has a syncing mechanism to the xbox wirelessly, like the xbox controllers have.
Feb 03, 2009 | Pyramat Sound Rocker Gaming Chair
No sound from cyber rocker gaming chair
Make sure it is hooked up to the audio OUT on the tv not the IN
Dec 31, 2008 | Activision Guitar Hero World Tour Guitar...
Ps3 connection
connect using the old ps3 lead and put the yellow end into the tv, then connect the white and red leads to your gaming chair. On the ps3 menu go to sound settings and change the sound settings to Av the only way for it to work hope this helps
Dec 26, 2008 | Pyramat Sound Rocker Gaming Chair
No sound through gaming chair
well maybe there is a miss connect in the wires in the chair. or you need to turn up the volume
Dec 25, 2008 | Pyramat Sound Rocker Gaming Chair
Sony Playstation 3 (PS3) Console Logo
14,122 people viewed this question
Top Sony Video Game Consoles & Games Experts
Iron
Iron
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
