I have a 1996 honda accord with manual crank up windows. The back passenger side window is open about 2 inches. I cannot crank it up or down. The window crank handle is stuck as is the window in it's 2 inch open position. I'm afraid to force it. What may be wrong and how can I fix it myself? Mike
Mike hi open the door agar pull the window winder towords urself not with force just gently the surroundin panal is just clipped together with plastic clips so put ur hand at the edge and pull gently and u will find it will come off easally then use a vice crips to close the window fully and then put wd40 on all the movin parts ok
SOURCE: interior door handle replacement 1992 honda accord
Do u mean the door latch, which u pull to open the door, or the plastic molded handle u grab to shut the door? If it's the latch, there are two small round plugs in the plastic area of the door lock and locking switch. Use a small flat end screwdriver to pry them out , exposing two philips head screws. If this isn't what u needed, let me know, I'll get more info for u. countrycurt0
SOURCE: Need 1996 Honda Accord radio code, please
you may have to involve the dealer. inside the glove box on right side may have some code #'s they will ask for to determine your security code.
SOURCE: i need 1996 honda accord speed sensor plug wiring diagram
Diagram is courtesy of honda
[IMG]http://i34.tinypic.com/10wjogi.jpg[/IMG]
SOURCE: 1996 HONDA ACCORD CRANKSHAFT SENSOR AND CAMSHAFT SENSOR.
befor in the ealier models of accords they use to be both the cam and crank sensors in the distibutor but they separated them !!!So no they are not together on your car tha cam sensor is in the distributor and the crank sensor is in front of engine or in the lower timing belt cover if it is in the timing cover you can see a wire going dow the timing cover way to the bottom on the rear side off it
hope it will help you if you have any question just wright back !!!!
Denis
SOURCE: Maintenance required light is on. 1996 Honda Accord
Simple way to check if anything goes wrong is to go to Autozone store (if you are in US) and scan for trouble codes (if there are any of them). They do it free of charge. If you get any codes you can get the explanation of them here
http://www.troublecodes.net/honda/
Good Luck
