Question about Jetway (939AGP-OC) Motherboard
Jumper settings need jumper settings to reset cmos on a jetway motherboard
    Scholar:
  • 155 Answers
See the picture here below.
Posted on Oct 04, 2008
Where is the CMOS reset jumper or battery on Jetway JBC600C99352W-BW Mini-top. Can not find CMOS reset or CMOS battery. Any help?
I am not sure you have the exact model I do, but the battery is on the underside of the motherboard - you must undo the four silver screws holding the board down, and also two screws to remove the front plate. Pull the board up and out, and you will see the battery underneath.
Sep 14, 2011 | Jetway Mini-TOP HBJC600C99-52W-BW Intel...
How to remove bios password in laptop dell model no pp19s
BIOS passwordsare used to add some extra security to computers. You can either set a passwordto prevent access to BIOS settings or to prevent PC from booting. But sometimesthis extra security might become a pain when you forget the BIOS password orsomeone changes your system BIOS password intentionally. But there is noneed to worry. There are many known ways to reset / remove / bypass thepassword: · By removing CMOS battery · By using motherboard jumper · By using MS DOS command · By using software · By using Backdoor BIOS password Now I'll try to explain each methodone by one: By Removing CMOS Battery:
Almost allmotherboards use a small coin d CMOS battery to store all BIOS settingsalong with the password. To reset the password, unplug the PC, open the cabinetand remove the CMOS battery for approx. 15-30 minutes and thenput it back. It'll reset all BIOS settings as well as the password and you'llneed to re-enter all settings. If it fails,then try to remove the battery for at least one hour. By Using MotherboardJumper: Almost allmotherboards contain a jumper that can clear all CMOS settings along with theBIOS password. The location of this jumper varies depending upon themotherboard brand. You should read your motherboard manual to check itslocation. If you don't have the manual then look for the jumpers near the CMOSbattery. Most of the manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS,etc. When you findthe jumper, look carefully. There will be 3 pins and the jumper will be joiningthe center pin to either left or right pin. What you need to do, is remove thejumper and join the center pin to the opposite pin. e.g. if the jumper joinscenter pin to left pin, then remove it and join center pin to right pin. Nowwait for a few seconds and then again remove the jumper and join the center pinto left pin. Make sure toturn the PC off before opening the cabinet and resetting the jumper. By UsingMS DOS Command: This methodworks only if you have access to the system when its turned on because thismethod requires MS DOS. Open Command Prompt from Programs menuand provide following commands one bye one: Debug o 70 2E o 71 FF quit NOTE:The first character in the above commands is English alphabet "o"and not the number 0. After providing the above commands, restart your systemand it should reset the CMOS Settings along with the BIOS password. If you arecurious to know how it works? then let me explain the above commands: In this method we are using theDebug tool of MS DOS. The "o" character present atfirst in these commands, outputs the values to IO ports. The number 70and 71 are port numbers which are used to access CMOS memory.By providing FF value we are telling CMOS that there is aninvalid checksum and it resets the CMOS settings as well as BIOS password. By UsingSoftware: There are a few software which canalso reset CMOS settings or BIOS password or both within a few clicks. But asstated above you should have access to a system which is turned on and shouldhave access to MS DOS or MS Windows: CmosPwd By Using Backdoor BIOSPassword: Some BIOSmanufacturer put a backdoor password in BIOS which always works irrespective ofwhat password you have set in BIOS. Its a master password which is used fortesting and troubleshooting purposes. AMI BIOS Passwords: A.M.I.
AAAMMMIII
AMI?SW
AMI_SW
AMI
BIOS
CONDO
HEWITT RAND
LKWPETER
MI
Oder
PASSWORD AWARD BIOS Passwords: 01322222
589589
589721
595595
598598
ALFAROME
ALLy
aLLy
aLLY
ALLY
aPAf
_award
award
AWARD_SW
AWARD?SW
AWARD SW
AWARD PW
AWKWARD
awkward
BIOSTAR
CONCAT
CONDO
Condo
d8on
djonet
HLT
J64
J256
J262
j332
j322
KDD
Lkwpeter
LKWPETER
PINT
pint
SER
SKY_FOX
SYXZ
syxz
shift + syxz
TTPTHA
ZAAADA
ZBAAACA
ZJAAADC PHOENIX BIOSPasswords: BIOS
CMOS
phoenix
PHOENIX Misc Common Passwords: ALFAROME
BIOSTAR
biostar
biosstar
CMOS
cmos
LKWPETER
lkwpeter
setup
SETUP
Syxz
Wodj Other Manufacturer BIOSPasswords: Biostar - Biostar
Compaq - Compaq
Dell - Dell
Enox - xo11nE
Epox - central
Freetech - Posterie
IWill - iwill
Jetway - spooml
Packard Bell - bell9
QDI - QDI
Siemens - SKY_FOX
TMC - BIGO
Toshiba - Toshiba
VOBIS & IBM - merlin NOTE: All thesepasswords are case-sensitive and are changed from time to time bymanufacturers.
Mar 03, 2011 | Dell Inspiron Mini 10 10v 1010 1011 PP19S...
"Reset you're cmos/bios jumper to
HI,
No need to worry. There are many known ways to reset / remove / bypass the password:
  • By removing the CMOS battery
  • By using the motherboard jumper
  • By using MS DOS command
  • By using software
  • By using Backdoor BIOS password
Now I'll try to explain each method one by one:
A. By Removing the CMOS Battery:
Almost all motherboards use a small coin sized CMOS battery to store all BIOS settings along with the password. To reset the password, unplug the PC, open the cabinet and remove the CMOS battery for approx. 15-30 minutes and then put it back. It'll reset all BIOS settings as well as the password and you'll need to re-enter all settings.
If it fails, then try to remove the battery for at least one hour.
B. By Using the Motherboard Jumper:
Almost all motherboards contain a jumper that can clear all CMOS settings along with the BIOS password. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don't have the manual then look for the jumpers near the CMOS battery. Most of the manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS, etc.
When you find the jumper, look carefully. There will be 3 pins and the jumper will be joining the center pin to either left or right pin. What you need to do, is remove the jumper and join the center pin to the opposite pin. e.g. if the jumper joins center pin to left pin, then remove it and join center pin to right pin. Now wait for a few seconds and then again remove the jumper and join the center pin to left pin.
Make sure to turn the PC off before opening the cabinet and resetting the jumper.
C. By Using MS DOS Command:
This method works only if you have access to the system when its turned on because this method requires MS DOS. Open Command Prompt from Programs menu and provide following commands one bye one:
debug
o 70 2E
o 71 FF
quit
NOTE: The first character in the above commands is "O" and not the number 0.
After providing the above commands, restart your system and it should reset the CMOS Settings along with the BIOS password.
If you are curious to know how it works? then let me explain the above commands:
In this method we are using the Debug tool of MS DOS. The "O" character present at first in these commands, outputs the values to IO ports. The number 70 and 71 are port numbers which are used to access CMOS memory. By providing FF value we are telling CMOS that there is an invalid checksum and it resets the CMOS settings as well as BIOS password.
Jan 08, 2011 | Intel DG31PR Motherboard
How can i reset my bios password ,logged out/dell computer
You can call Dell and they can reset the bios password for you. But if it doesn't have a warranty anymore you can simple open the casing of your computer and there's pin(jumper) on the motherboard that you can pull out and then put it back in. The password will be reset.
Oct 27, 2010 | Dell Dimension 4600 PC Desktop
I have laptop Dell Inspiron 6400 and i forgot the Bios Admin password. can you help me please
WARNING: Some BIOS configurations will lock you out of the system completely if you type in an incorrect password more than 3 times. Read your manufacturers documentation for the BIOS setting before you begin typing in passwords.
Award BIOS backdoor passwords:ALFAROME BIOSTAR KDD ZAAADA
ALLy CONCAT Lkwpeter ZBAAACA
aLLy CONDO LKWPETER ZJAAADC
aLLY Condo PINT 01322222
ALLY d8on pint 589589
aPAf djonet SER 589721
_award HLT SKY_FOX 595595
AWARD_SW J64 SYXZ 598598
AWARD?SW J256 syxz
AWARD SW J262 shift + syxz
AWARD PW j332 TTPTHA
AWKWARD j322
awkward
AMI BIOS Backdoor Passwords:AMI BIOS PASSWORD HEWITT RAND
AMI?SW AMI_SW LKWPETER CONDO
Phoenix BIOS Backdoor Passwords:phoenix PHOENIX CMOS BIOS
Misc. Common PasswordsALFAROME BIOSTAR biostar biosstar
CMOS cmos LKWPETER lkwpeter
setup SETUP Syxz Wodj
Other BIOS Passwords by ManufacturerManufacturer Password
VOBIS & IBM merlin
Dell Dell
Biostar Biostar
Compaq Compaq
Enox xo11nE
Epox central
Freetech Posterie
IWill iwill
Jetway spooml
Packard Bell bell9
QDI QDI
Siemens SKY_FOX
TMC BIGO
Toshiba Toshiba
Toshiba BIOS
Most Toshiba laptops and some desktop systems will bypass the BIOS password if the left shift key is held down during boot
IBM Aptiva BIOS
Press both mouse buttons repeatedly during the boot
Using the Motherboard "Clear CMOS" Jumper or Dipswitch settings
Many motherboards feature a set of jumpers or dipswitches that will clear the CMOS and wipe all of the custom settings including BIOS passwords. The locations of these jumpers / dipswitches will vary depending on the motherboard manufacturer and ideally you should always refer to the motherboard or computer manufacturers documentation. If the documentation is unavailable, the jumpers/dipswitches can sometimes be found along the edge of the motherboard, next to the CMOS battery, or near the processor. Some manufacturers may label the jumper / dipswitch CLEAR - CLEAR CMOS - CLR - CLRPWD - PASSWD - PASSWORD - PWD. On laptop computers, the dipswitches are usually found under the keyboard or within a compartment at the bottom of the laptop.
Please remember to unplug your PC and use a grounding strip before reaching into your PC and touching the motherboard. Once you locate and rest the jumper switches, turn the computer on and check if the password has been cleared. If it has, turn the computer off and return the jumpers or dipswitches to its original position.
The CMOS settings on most systems are buffered by a small battery that is attached to the motherboard. (It looks like a small watch battery). If you unplug the PC and remove the battery for 10-15 minutes, the CMOS may reset itself and the password should be blank. (Along with any other machine specific settings, so be sure you are familiar with manually reconfiguring the BIOS settings before you do this.) Some manufacturers backup the power to the CMOS chipset by using a capacitor, so if your first attempt fails, leave the battery out (with the system unplugged) for at least 24 hours. Some batteries are actually soldered onto the motherboard making this task more difficult. Unsoldering the battery incorrectly may damage your motherboard and other components, so please don't attempt this if you are inexperienced. Another option may be to remove the CMOS chip from the motherboard for a period of time.
Note: Removing the battery to reset the CMOS will not work for all PC's, and almost all of the newer laptops store their BIOS passwords in a manner which does not require continuous power, so removing the CMOS battery may not work at all. IBM Thinkpad laptops lock the hard drive as well as the BIOS when the supervisor password is set. If you reset the BIOS password, but cannot reset the hard drive password, you may not be able to access the drive and it will remain locked, even if you place it in a new laptop. IBM Thinkpads have special jumper switches on the motherboard, and these should be used to reset the system. Also, Hirens Bot CD has Bios password crackers too. Good luck.
If this helps you resolve your problem, please
consider giving a good rating and a quick thanks
or good job.It will help me as well Thank you.
Oct 26, 2010 | Dell Inspiron 6400 Notebook
My laptop is asking for PhoenixBIOS Setup Utility password. Can you please help me out with da password?
tRY THIS LIST AND OTHER ALTERNATIVES THAT FOLLOW...GOOD LUCK
AWARD?SW J256 syxz
AWKWARD j322
awkward
VOBIS & IBM merlin
Dell Dell
Biostar Biostar
Compaq Compaq
Enox xo11nE
Epox central
Freetech Posterie
IWill iwill
Jetway spooml
Packard Bell bell9
QDI QDI
Siemens SKY_FOX
TMC BIGO
Toshiba Toshiba
Toshiba BIOS
IBM Aptiva BIOS
ALSO, HIREN'S BOOT CD HAS SOME BIOS PASSWORD CRACKERS ON IT IF THIS DOESN'T WORK.
Oct 21, 2010 | Toshiba Computers & Internet
I need a pasword.when i enter the bois there need a pasword.so help me how 2 break the pasword
Hi Good day!! turn off your PC Remove your CMOS battery (2032 3volts) within 1minute and then put it back, turn on your PC now your bios password should be remove.
Oct 19, 2010 | MSI Microstar KT6 Delta (MS-6590)...
Removing bios password of toshiba portege 4010
HOPE THIS HELPS...BE SURE AND READ ALL BEFORE STARTING...GOOD LUCK
AWARD?SW J256 syxz
AWKWARD j322
awkward
VOBIS & IBM merlin
Dell Dell
Biostar Biostar
Compaq Compaq
Enox xo11nE
Epox central
Freetech Posterie
IWill iwill
Jetway spooml
Packard Bell bell9
QDI QDI
Siemens SKY_FOX
TMC BIGO
Toshiba Toshiba
Toshiba BIOS
IBM Aptiva BIOS
Oct 16, 2010 | Toshiba Computers & Internet
How can i remov the hp compaq nx6310 laptop bois password
If you didn't set it or do not know it then the entire laptop will have to be dismantled to remove the cmos battery for one hour to cancel that password.There is no easier way.
Oct 16, 2010 | HP Compaq nx6310 Notebook
Jumper settings
There is no jumper settings, it is just a small bridge aside the bios Chip. you bridge the two pins and power to reset cmos.
A much easier way is removing the Cmos coin shaped battery from motherboar for few seconds, and put it back, this will reset Cmos the same .
Oct 05, 2008 | Toshiba Satellite A135-S4527 Notebook
Jetway (939AGP-OC) Motherboard Logo
172 people viewed this question
Top Jetway Computers & Internet Experts
john smith
Tony
Iqbal Husain
Iqbal Husain
Are you a Jetway Computer and Internet Expert? Answer questions, earn points and help others
