Lexmark X1100 printer will not print black
Lexmark X1100
Printer will only print with color cartridge.
When trying to print only black, the printer carrage does not travel back and forth. So it looks like the printer is not either getting the black info or it is ignoring it.
Did try a new black cartridge but that did not work.
Put the black cartridge in color slot and printed a color picture and the cartridge did work, but the color cartridge did not work in the black slot.
Reinstalled software, but that did not help.
Restored the computer to the last saved condition and the printer DID print several black pages, but then stopped printing black again.
Restoring computer after that did not help.
Had someone else try to install it on their computer, but it does not work there either.
If it was not for the time that the printer worked after restoring the computer, I would think that the printer was dead.
But I have heard that the printer might need to be reset.
Any suggestions?
Thanks.
I came up with a work around for printing black.
I changed the black cartridge with the color cartridge.
Then when I have a letter to print, I change change (or write) the letter text to yellow, red or blue.
Then I can print out a letter.
By printing the text as yellow, red or blue the cartridge will try to print with only 1 color, but will print out black.
If you do not use one of these primary printing colors the out put will be unusable.
I can not of course print out pictures.
Posted on Oct 21, 2008
  • 1,218 Answers
You need to take it a couple steps further after your test print. Sounds like your print heads need cleaning or your cartridge may need aligning. It's best to do this each time you install a new cartridge.get more information and help from here .hope this helps you.
Posted on Aug 30, 2010
I just installed two refilled lexmark cartridges color and black yet printer is reading black cartridge missing and color cartridge missing. I am unable to print
Refilled cartridges become unreliable and can damage your printer - you will need to try an original Lexmark cartridge before considering replacing your printer.
Sep 05, 2011 | Lexmark Z2300 InkJet Printer
Lexmark Series X1150 My printer does not recognize the color print cartridge and only prints in Black even though the color cartridge is new. First time this has ever happened. I've had the printer...
Make sure you are inserting the correct color cartridge versions for the Lexmark X1150 (either #26 or #27).
Try to clean the cartridge nozzles. On your computer, open the Lexmark Solution Center, click Start > Programs > Lexmark X1100 Series > Lexmark X1100 Series Solution Center. From the Maintenance tab, click Clean to fix horizontal streaks. Your printer will then print a page that will help clean the nozzles from possible dirt and clogs.
If that doesn't help, try to insert a different known working cartridge (e.g. your old cartridge or another new cartridge). It could be a faulty cartridge issue.
Sep 01, 2011 | Lexmark X1150 All-In-One InkJet Printer
I have a lexmark z2320 inkjet printer the colour cartridge is empty should it still print the black is full
I'm not a computer geek at all, but I find the color cartridges always run out first. Try to change your printer settings so it will only print in black and white and so uses the black cartridge and not the color one. If the the color cartridge is empty, the page will not print correctly. It may print some of the black color only.
Mar 26, 2011 | Lexmark Z2320 InkJet Printer
My lexmark 1150 won't print and I've lost cd and don't have the manual book. Would it have any thing to do with because I put in ink cartridges 17 and 27 and it requires 16 and 26 ink cartridges.
It works with both 16 and 17 for Black and 26 and 27 for Color.
Go to the Panel from Lexmark X1100 series- Series Solution Center and select the new type of cartridges. Allign the cartridges, make an excel test with 4 colors(cyan, magenta, yellow, black) and it should work
If you need further assistance, do not forget to post and don't forget to rate.
Thank you
Feb 27, 2010 | Lexmark X1150 All-In-One InkJet Printer
I have a Lexmark x1100 Series printer and cannot print anything now. This printer has been working but it stopped printing. Do not have the CD.
Need more info. Any error messages? Did it just stop pumping ink on paper. Are you trying to print black text or color picture? If no error, your cartridges may be empty. If black text does not work, try color picture. Usually one cartridge goes empty and the other still has ink. If color pic prints replace black cartridge. If neither black or color prints at all, it may be a toasted printhead
If you need to reinstall the software, uninstall it, then go to lexmark.com and get new drivers from their site. RESTART COMPUTER! Reinstall from the downloaded file.
If all the above fail to make it work, it is hosed, shop for new printer.
Dec 09, 2008 | Lexmark Office Equipment & Supplies
My lexmark X1185 all in one printer will not print color.
did you make sure that you pulled all of the tape off the bottom of the cartridge. next recheck your settings. they will not return to normal themselfs
Jun 09, 2008 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Lexmark All in one printer
looks like you may need to replace the black cartridge.
usually when you open the cover of your printer, cartridge carrier will move to the center. that's where the cartridges are, you can open it buy pushing it down and release it.
you can also checked lexmark site for this
check out this link too.
x1185 and x1100 are most likely the same.
http://www.lexmark.com/publications/pdfs/x1100/eng/ug.pdf
Mar 26, 2008 | Lexmark JetPrinter X1185 All-In-One InkJet
Printing from computer
check the cable connections and re-install the driver/software
go to lexmark website and get the latest driver for your operation system.
Also when you print, make sure you are printing to this printer
print from word-pad or any other program OTHER than internet.
Jan 05, 2008 | Lexmark X1150 All-In-One InkJet Printer
Colored Ink problem
Make sure the printer settings are set properly to print in color on the PC. Even if there is a color cartridge, if the PC only tells it to print black ink it's not going to use the color cartridge.
Jun 08, 2007 | Lexmark Color Z35 InkJet
1,048 people viewed this question
jasbo
jasbo
