Kenmore 70 series washer off balance!!
My washer goes through the cycles fine until it gets to the spin cycle. Once it is there it acts like it is off balance but I rearranged the clothes and that does not seem to be the problem. I tried to do another load and it is doing the same thing, just shaikng like crazy. What could be the problem? It is a newer washer and when it has water in it, it spins fine until the water is all out. Please help me!!!
SOURCE: Kenmore 90 Series Washer has slow spin cycle
Washing machine won't spin, seems locked up, when i turn the spin cycle on you can hear the machine trying to spin but it won't budge....... any suggestions???
Posted on Dec 28, 2007
SOURCE: Computer board shows UL even when very few clothes are in the washer
try to unplug and plug back after 30 seconds.
Posted on May 09, 2008
  • 3361 Answers
SOURCE: kenmore 82372110 70 series heavy duty plus won't spin
If it drains and won't spin you have to replace the direct drive coupling.
Posted on Feb 26, 2009
SOURCE: Kenmore 70 Series washer - agitates and drains but does not spin
my kenmor washes and drains but does not spin, help
Posted on Jun 28, 2009
  • 64 Answers
SOURCE: Kenmore 70 series washer: leaky water pump
Posted on Aug 31, 2009
Washer goes thru cycle ok untill spin cycle gets error code out of balance, but machine not out of balance
That is not to say that the drum is not out of balance. Try running it empty and see if it happens.
Aug 09, 2013 | Kenmore Elite Oasis 27052 Top Load Washer
Washer will not spin
There is a safety switch on the lid ... when it went out of balance perhaps the adjustment changed or it got damaged (loose wire etc.) BE SURE TO PULL THE PLUG BEFORE ATTEMPTING ANY REPAIRS
Oct 02, 2009 | Washing Machines
70 series washer does not spin
this is pretty bad, defenitly you need you need to call a repairman, something is slipping in the transmission
Jun 17, 2009 | Kenmore 22422 Top Load Washer
Kenmore 90 series noise after spin
You need to replace the drive block and basket drive. You can download a tutorial to get you started at The gearcase replacement tutorial will put you in the right direction. Dave
Mar 01, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Timer stops at the end of wash cycle, won't began drain cycle
if it fills and agitates but stops at the drain/spin portion, it sounds like you have a problem with the lid switch. if it thinks the lid is opne, it will not drain or spin.
Dec 29, 2008 | Kenmore Washing Machines
Kenmore 70 Series
check the balance ring on the top of the basket it has either came loose from the basket rim or the fluid inside is not there
might need a new one
Jun 17, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore washer series 70 shakes wildly during spin during cycle
I have the same kenmore and have experience this before. It is unbalanced. Get a spirit level to check for balance. To rebalance, empty the washer (so it's not heavy), lean over the washer and grab the back, tilt it forward and the auto balancing legs should reposition themselves. Re-check for balance using the spirit level. If still out, adjust the front feet of the washer by screwing the legs up or down (using a wrench). This will cure the problem (unless you have a very unbalanced load of towels for instance). Good luck
Mar 30, 2008 | Washing Machines
Kenmore 70 Series Washer
You probably have a bad lid switch.
May 21, 2007 | Kenmore 15864/15862 Top Load Washer
Washing Machines Logo
121 people viewed this question
Top Washing Machines Experts
