I bought several RCA TVs model # J20010DW. They work well but I can't get to the menus to program the channels. I have an RCA remote, it turns them off and on, and does the channel scrolls. But I can not change the channels with the numbers. It will only go to the channels that are already programed in.
  • 3130 Answers
SOURCE: Non Responsive 35" RCA
You are going to have to check all of the small tact switches behind the push buttons in the front of the TV set. In the past, someone may have cleaned the picture tube and the liquid dripped down onto the switches and corroded them, or one is stuck closed or the remote sensor is bad. The best way to test this would be to replace the entire switch panel in the front of the TV set. Good Luck
Posted on Aug 19, 2007
  • 398 Answers
SOURCE: RCA TV won't change channels
Your set uses the 195 series chassis and you have something set wrong in your guide plus. Go into the TV's menu and do a complete set-up. Take the remote and press MENU, then "8" to enter setup, then press "1" for "begin setup now" and then press "1" for English, and so on. You must enter "set up guide plus+", then press OK on the remote to choose "setup", select "USA", enter your zip code, and then if you choose "yes" for "do you have cable?" you MUST then choose "no" for "do you have a cable box" If you choose "yes" for that choice, your tuner will lock on one channel no matter what channel you try entering. After choosing "no" for "do you have a cable box", choose "no" for "do you have a VCR?", exit the guide plus menu and then skip the rest of the steps by pressing "2", and then exit the main menu by pressing "0". Your channels will then work normally.
Posted on Aug 30, 2007
  • 5138 Answers
SOURCE: pioneer projection tv model sd-p404
In menu go to cable/then press auto programming see if this fixes your set.
Posted on Jan 31, 2008
SOURCE: Sanyo TV stuck on video channel
sanyo ds35590 no remote, tried universial remote still cannot select menu on uvm. What remote do I need? Or can I get into the menu without remote. I am trying to watch a dvd.
Posted on May 25, 2008
SOURCE: Hanspree TV chgs channel w/ cable remote but cant turn on/off
Thanks but I no longer require assistance. I tried to remove my post but it does not seem possible. I no longer need assistance because I sent the TV back. There is no solution as there is no universal remote code --- ridiculous for a brand new TV set that most people are probably going to want to use with cable!
Posted on Jan 14, 2009
How can I use an RCA universal Remote to pull up smart hub on my TV
RCA samsung smart hub Remote Controls Questions ...
RCA remote controls samsung smart hub related questions and answers. ... Pull upprevious . ... Set-up (Programming) procedure is too much to type in here, and is not ... How do i program my rca universal remote to my TCL 55 IN smart tv?
How to Program an RCA universal remote « TVs & Projectors
Mar 26, 2010 - If you just bought a new RCA universal remote and want to program it then this is for you. The first thing you have to do is hold down the TV button and tap and ... So do a little labor, pull out the remote, and kick your feet up on the table ... by step how to set up and work your remote control to enjoy carefree, ...
HOW TO PROGRAM TV Channel Button on CABLE Remote ...
? 3:20
Jan 19, 2016 | RCA Televison & Video
I bought new universal remout control, we have tried to program this and it doesn't work. The frist problem is that it does not trun Off/ON, unable to change the channels (does not respond to any...
Return the tv universal remote where u bought it,u only used a universal remote when u must have too,because universal remotes are very strangely and react differencely each models of tvs u tries to programming it codes to it CPU chip.Norcent tvs are recent tvs in the market,have many spare original remote.Try website like to buy the tv original remote.
Jun 18, 2011 | Norcent Technologies LT-2723 Television
Goodmorning, bought a zenith tv didn't get the remote. Wonndering how i can programme it using just the buttons on the tv. How do i get the menus up. it only catches threes channels as of now.
There are two types Zenith TVs. One type will have "Menu" button on its front panel and other will not. If your Zenith is the first type, you can programme it without a remote control. If it is the second type, you must have a remote control hanset to programme it.
Programming method
First connect the TVs antenna socket at its back with external antenna or cable.
* With the remote control in hand, press the POWER key to
turn on the Presentation TV.
** Press MENU repeatedly until the Setup menu appears.
*** Using the Up/Down arrow on the remote control, highlight
Auto Program on the screen
**** Press the Right or Left arrow to go to the Auto Program
***** Using the Up/Down arrow, choose either Cable TV or Off-
Air Antenna on the screen.
****** Press the Right or Left arrow to begin the Channel Search.
******* Press ENTER when the channel search is done.
Note: Auto Program finds channels being received by the TV
Cable will not work unless you subscribe to a cable service
Jun 17, 2011 | Zenith H27E35DT 27" TV
I have a rca246 remote that came with tv and the volume button is not working. I have purchased 4 remotes -3 of which are rca remotes- and am unable to program any of them to use with the tv. What do I...
Many of the RCA TVs are not compatible with universal remotes. Only the RCA 246 remote works with many of the TVs. I bought a floor model RCA from best buy, at a discount, without a remote. I had to purchase the RCA 246 remote for the tv to work. I found one but I recently cracked the screen of the tv so I have no need for the remote. I listed it on ebay at
Apr 21, 2011 | RCA Televison & Video
Original remote lost. It is a RCA TV
To get full functionality you need to get the oem remote since universals have limited, very basic functions and most do not include menus, input selections, etc. Enter in to ebay the exact model of your rca - very often the sets are there and more often than not remotes are also available!!!!And if you cannot find one, the Harmony line of remotes, not cheap, are very comprehensive in their controls.
Sep 22, 2017 | RCA Televison & Video
RCA XS J25330BL cannot access full setup menu
Your best solution is to get rid of that crappy TV! Having an old tube Tv really makes the rooms look bad.
Sep 02, 2008 | Televison & Video
Lost manual to rca universal remote, lost programing to operate remote
RCA Universal remote codes for the Mitsubishi TVs are...006,011,014,019,022,027,041,056,061,068.
First, turn on TV
Press and hold code search button on remote
Press and release the TV button
Enter the three digit code you want
Release code search
Push channel up, if device responds, that code worked.. If not, repeat steps 1-5 with each code until you find the one that works. This information can be downloaded from
If you want a hard copy with codes for all TVs.
Aug 29, 2008 | RCA Universal Remote Control
Rca tv
1) Buy RCA remote part # 240895 original about $25.00
2) Enter channel 00 for video sometimes works
3) Channel down 4-3-2-Vid 1, Vid 2, etc. sometimes works
4) Try Auto-Program Channels selection ( can be accessed on
front of set buttons or remote
Let me know ...........................................T.
Nov 04, 2007 | RCA F32649 32" TV
RCA DRC230 Remote Programming
The remote for this model only works with RCA, GE and Proscan TVs.
Aug 04, 2007 | RCA DRC230N DVD Player
Televison & Video Logo
47 people viewed this question
Top Televison & Video Experts
