1992 Toyota Corolla Logo
Andre Posted on Dec 24, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Which fuse powers the cigarette lighter in a 1992 Toyota Corolla
I don't have an owner's manual, so I need to know which fuse powers the cigarette lighter; as there is no longer a fuse box cover for me to reference.
chargerhp
Level 3:
  • Toyota Master 815 Answers
  • Posted on Dec 31, 2011
chargerhp
Toyota Master
Level 3:
Answers
815
Questions
0
Helped
345178
Points
1241
It is a 15 amp fuse #12Which fuse powers the cigarette lighter in a 1992  - 12_31_2011_9_02_38_pm.gif
I need the fuse box diagram for a 1992 toyota corolla
If you have to pull each one and look at them see witch one is melted shouldn't take More than 15 min
2helpful
1999 corolla cigarette lighter does not work. Looked in the owners manual and the same fuse controls the clock. Since the clock works it can not be the fuse.
I don't have the owner's manual, but I do have the wiring diagrams for your vehicle. According to the wiring diagrams, the information that you have is not correct. The cigarette lighter circuit is protected by the "CIG" fuse in the Instrument Panel Junction Box behind the left side of the dash at the lower finish panel. It is a 15 Amp fuse. The clock circuit is protected by the "DOME" fuse in the Engine Room Junction Block on the left side of the engine compartment.
The cigarette lighter and cd player won't work in my 94 Toyota Corolla; do you know which fuse this is related to? I don't have the owner's manual.
it is a fuse inside the car. it is located on the drivers side right beside where your left foot would be... it is one of those fuses... ive blown that fuse twice so far
1helpful
2answers
Toyota corolla 2000 cigarette lighter no working
Check your fuse boxes - your drivers manual should show you where the fuse is located - there are several fuses that work with the cigarette lighter, one located inside the vehicle, left of the steering wheel, the other 2 located under the hood.
No need to pay a mechanic to do this, your owner's manual lists fuse replacements under "do it yourself maintenance" - My Toyota dealership quoted me $70+ to do this, when it cost me $5 to buy 5 fuses, now I have 4 spare.
Hope this helps.
What fuse is connected to the radio
yes you sure did ! check in the owners manual for fuse location . the safest way to use those inflators are with a cigarette lighter adapter with alligator clips right to the battery hope this helps
No power in my cigarette lighter in my 2008 camry
Probably a fuse. Check owner's manual for location fo fuse box. Might be 2 fuse boxes. If you don;t have the owners manual, a stop at the Toyota service dept. should be able to answer your question on where the fuse is.Good Luck
1999 toyota solara cigarette lighter and 12v are not working need to know what fuse to replace? is there a fuse box inside there is 2 of them under hood but nothing about car lighter or clock lights
Check your owner's manual if you have one. It will tell you the locations of your fuse boxes.
On my '03 corolla, there is a small enclosed one to the left of my steering wheel, under the dash. Maybe yours is in the same location. hope this helps...
1helpful
2answers
Any special tools needed to change serpentine belt on 1992 Toyota Corolla. Also cigarette lighter not working any help appreciated
you should be able to loosen the alternator and get the belt off and then put the new one on and tighten the alternator back up. check the fuses for the cigarette lighter
Top Toyota Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
ROBERT GARCIA
ROBERT GARCIA
Are you a Toyota Expert? Answer questions, earn points and help others
