Scratched screen - Televison & Video
    President:
  • 2,712 Answers
Well, unfortunately, there isn't much you can do about it. The cost of a new screen and installation would be almost as much as a new TV itself, so if the scratch doesnt deter you from watching TV, then I suggest just leave it be. There are a couple of scratch removing products (abrasives) on the market, but if you have no experience in this, then you'd only make the scratch worse...
Posted on Oct 04, 2008
How to remove scratches from iPhone screen?
its not recondmended its a screen /lens not like regular glass where you can buff out fine scratch with toothpaste the following links show how to remove scuffs or very very fine scratches but on some creens trying to remove a scratch may cause malufunctions
I5 Phone Screen Scratch Remover Yahoo Video Search Results http://mashable.com/2014/06/28/phone-screen-scratches/#8C596Bi36aqt How To Clean and Remove Scratches on the iPhone 5 5S 6 6 Plus
Aug 11, 2016 | Apple iPhone 6
Scratched computor screen
How deep of a scratch is it on the screen? Just on the plastic/glass protective coating over the monitor?
If it is not in the LCD then you could just remove the plastic/glass and replace it if you want.
If the scratch is deep then your LCD is probably scratched. Sadly the cost of replacing the LCD screen within an LCD monitor is more expensive than buying an entirely new screen. Your best bet is either dealing with the scratch or getting an entirely new monitor. I would recommend visiting www.newegg.com where there are many cheap monitors there.
please rate my solution
Jul 20, 2010 | Acer AL2016W 20" LCD Monitor
Right side of screen scratched how can I fix it
If the screen does not have deep scratches, then you can polish the scratches out using a car polish cutting compound.
Mar 05, 2010 | LG Xenon GR500 Cell Phone
MY 3 YEAR OLD DAUGHTER HAS JUST SCRATCHED MY SONY BRAVIA TV WITH A MAGNA DOODLE PEN. HOW CAN I GET RID OF THE SCRATCHES?
Clean the surface of the LCD screen with a barely damp cloth.
  • Step 2 Dry the screen with a soft, clean cloth.
  • Step 3 Rub a generous amount of petroleum jelly into the scratch using a cotton swab. The petroleum jelly should fill in the scratch and remain there.
  • Step 4 Immediately wipe the excess petroleum jelly off of the screen with a soft cloth being careful to leave some petroleum jelly inside the scratch to act as a patch or filler.
  • This scratch repair method is effective because of optical density. The optical density of petroleum jelly matches the plastic, LCD screen coating more closely than that of air.
  • To avoid future scratches or gouges, you might consider purchasing a LCD screen protector. These screen protectors are generally made of a thin, plastic film and affix to the screen without adhesives. Not only can they protect against scratches, but they also keep the screen free of dirt, oil and dust while simultaneously reducing glare.
  • When wiping the screen as described Step 4, avoid pressing too hard or you will inadvertently remove the petroleum jelly from inside the scratch.
  • Using petroleum jelly to fill a scratch on your LCD screen could void your screen's warranty. If you are concerned about warranty issues, consult your user's manual for more information.
  • Sep 16, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
    Scratch on plasma screen
    You should be able to make the scratch become invisible using a white eraser. A pink one will work, but the white one works better. Just simply erase the scratch, it may take awhile, but your basically buffing the surface down even again making the scratch un-noticeable.
    Jun 21, 2009 | Panasonic TC-P50S1 50 in. Plasma LCD HDTV
    Scratched screen problem
    http://www.buy.com/retail/product.asp?sku=207655663&listingid=21231455&dcaid=17902 is an link to faceplates that will protect the screen from scratches. there is another solution,http://www.rpstore.com/cellphone-cleaner.html is a scratch remover
    good luck hope these work for you
    Jan 29, 2009 | Sony Ericsson W910i Cellular Phone
    Scratch in sreen
    By the looks of that picture, it's hard for me to believe that the scratch is not on the outside of the protective plexiglass screen. However, you can remove the protective screen w/o negative effect of the picture. In fact, it will probably reduce the glare from light on the screen. If, in fact, the scratch is still seen w/o the protective screen installed, then it is the lenticular screen that is scratched.
    The lenticular screen is the one with the vertical grooves from top to bottom in it. The fresnal is the back screen that appears to have been lathed in a circular pattern.
    Jan 07, 2009 | Toshiba 61HX70 61" Rear Projection...
    My screen on my lg kg800 is scratched how can i replace it with a new one
    is the actual screen inside scratched or is the outer phone housing screen cover scratched? There is a difference. The actual LCD screen is inside the phone housing and is protected by the phones housing. If the actual LCD screen somehow was scratched it can be replaced very easily and usually inexpensively. Try Ebay for the LCD. If the phones outer clear housing is scratched you can also replace the housing either by purchasing the same phone used and using its housing or some "dummy" phones can be used for there housings also. If the scratch is not really bad I have used rubbing compound to remove fine scratches, good luck!
    Sep 03, 2008 | Cell Phones
    Polaroid FLM-2601 flat screen
    It has a protective outer screen and depending on the depth of the scratch you might be able to restore it. You'll need to look on-line at a few aircraft site for a kit that is meant to polish scratches from the plexi in an aircraft windshield. There is a company in Oregon http://www.chiefaircraft.com/airsec/Aircraft/Windshields/ScratchRemoval.html
    that sells the kit for 34.95....
    It is time consuming but I have restored many this way!
    Bill
    Mar 27, 2008 | Polaroid FLM-2601 Television
    Televison & Video Logo
    85 people viewed this question
    Top Televison & Video Experts
    Electro Med Services...
