Question about Denon AVR-3802 Receiver
AVR-3802 Won't reset, won't go to Setup Menu
I need to setup for 2 zone opeeration and the setup screen will not appear. I tried to reset the microprocessor and it did not work, it would not start up with the buttons held. Please help.
  • 3 more comments
  • Anonymous Oct 23, 2008
    Same here with 2802
  • jake2005 Oct 24, 2008
    I have the same problem...everything works fine...just cannot get into setup.
  • Anonymous Jan 25, 2009
    I see no post to this problem, does anyone know how to get the on screen display to work?
    same problem can anyone help
  • hato2 May 11, 2010
    How exactly do you do the processor reset?
tech48
  • 624 Answers
SOURCE: wiring speakers to denon avr 3802
Those are not compatible speakers for this unit. The Denon receiver does not have any speaker outputs for that type of speaker.
The Denon speaker outputs are full range outputs. Your speakers are not designed for that, they need an amplifier that has seperate outputs for the highs and lows.
By using these speakers you will probably damage them and they will not sound very good as well. The tweeters will end up fried and it is also likely that if one of the speakers goes bad, it will blow one of the channels in the amplifier.
If you really want to do it anyways, and don't say I didn't warn you, you could connect them using the "A" and "B" speaker outputs. Connect the woofers on one set, lets say "A", and the tweeters on the other, lets say "B". Right channel "A" would be the woofer and right channel "B" would be the tweeter for one speaker.
When listening to the unit you would need to engage both the "A" and "B" speaker to hear anything from both speakers, there are buttons on the display for the speakers marked "A" and "B" and in the display you would see little icons that light up when the speakers are engaged.
I can not stress it to you enough that this is not a good idea to use these speakers with this type of receiver. Do this at your own risk and be prepared to pay about $150 to $200 for the repair bill after the amp blows a channel.
Posted on Jun 22, 2008
  • 151 Answers
SOURCE: Denon AVR-3802 Problem
Check that your speaker cables are not touching each other at the amp end and also at the speakers as this will cause the amp to shut down.
hope this helps.
CABLE GUY.
Posted on Jul 12, 2008
SOURCE: Unable to view setup menu on TV screen
I had this same experience and after hours of attepts to fix it (including the suggestions on this site) I found that the company that installed and set up my system literally disabled the "set up" on the remote so that it could not be changed. To fix this (and/or confirm that this may be your problem) reference page 39, "all reset functions" to reset your remote back to factory settings. As soon as I did this and hit "set-up" -- the set up menu popped up and worked appropriately. Hope this works for you!
Posted on Sep 28, 2008
lynchms
  • 93 Answers
SOURCE: Cant Access System Setup on Denon AVR-588
Are you connected with video cables to a tv or "monitor" this is more than likely were the setup is visible for speaker configuration, input assignment etc, most denon receivers work this way so I would suspect you need to re-check the video connection until a set-up picture appears.
Posted on Feb 07, 2009
  • 19 Answers
SOURCE: Have Denon AVR-3802 AV surround receiver
Was it put into standy from the remote control and then just turned off at the wall? This can be a common cause, as it will be stuck in standby
Posted on Jan 02, 2011
I can't get a menu screen up on my Denon AVR 2803.
Did someone turn the OSD off on the menu? You might try a reset of the receiver. This would be in your manual.
Aug 23, 2012 | Denon Avr 2803 7.1 Channel 875 Watt...
RE: Denon AVR 3300 - I cannot get the system setup menu to display on Phillips P50PFP5332D tv screen? All connected components work and sound great, but I cannot see Denon's Setup menu on tv to a
I understand, it's something I've misunderstood on my denon avr-790 as well when connected to a samsung 8000 series led tv.
The answer isn't in the receiver's settings (you can be on whatever source you want on the receiver end when toggling the menu). You need to toggle through the tv's sources to find the menu (usually found on hdmi 1). I've spent towards an hour recently troubleshooting only to find that it was the tv's source that wasn't set properly and I was trying to change the receiver's settings instead of the tv's source.
Hope that helps!
Jan 16, 2012 | Denon AVR-485 Receiver
Denon AVR-3805 zone 2 no longer working
time to reset the microprocessor. See page 87 in manual.
1) switch off the unit using the main unit's power operation (small power button)
2) hold the PURE DIRECT button and DIRECT button at same time and turn the main unit's power operation on.
3) wait for entire display to flash in 1 second intervals
now the speakers need to be set up again but zone 2 will be working. i suspect a power surge causes the microprocesser to be corrupted. i put a power surge protector and have not had problems (lately).
Dec 29, 2008 | Denon AVR-3805 Receiver
Set up
You don't need to fake it with a VCR - on the back left side near the bottom there is a Monitor section with an RCA connection and an S-Video connection. Connect one of these to an input connection on your tv and switch your tv to show that input. Select the AMP setting of your remote and press Setup.
Mar 01, 2008 | Denon AVR-3802 Receiver
Dec 16, 2007 | Denon AVR-3802 Receiver
No system setup menu on screen
its related to the control AVI switch inside on the right side with the contact and 7 Ri sisters.
about 200.00 something to repair.
I can help with some money do you have the reciever still???
Jan 04, 2007 | Denon AVR-1706 Receiver
Denon AVR-3802 Receiver Logo
75 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
