Hi -- I have a H P scanjet G4010 - no response -- have unpluged-reloaded software-checked power cord Help !! charles knierim - ckanary@sbcglobal.net
    President:
  • 2,712 Answers
Are you getting any power at all to the scanner? Or is it just not responding to the scan command?
If it is the former, then check the wall socket if its viable or not. Next check the power cable and try a different cable if available. If these two are OK, then it could be an issue with the scanner's power board, in which case you will have to get it either serviced, or purchase a new scanner (whichever works out cheaper for you..)
If it is the latter case, uninstall the scanner software and driver and do a 'clean boot' as outlined below. First download the latest version of the scanner software for your OS from http://hp.com
1. Open the Windows Control Panel.
2. Open the Add / Remove Programs window.
3. Locate the listing for the software and remove it. When prompted to remove the scanner drivers files, click Yes.
The following is the procedure for a 'clean boot'. I am assuming that you have XP.
1. Click Start --> Run --> Type MSCONFIG --> Click OK
2. On the General tab, choose Selective Startup
3. Uncheck Process SYSTEM.INI file
4. Uncheck Process WIN.INI file
5. Uncheck Load Startup Items
6. Click on the Services tab
7. At the bottom, check Hide All Microsoft Services
8. Uncheck all boxes in the window or click the button labeled Disable All
6. Click OK
7. Click Restart
After restarting, reinstall the downloaded software. Next, do the following:
1. Click Start --> Run --> Type MSCONFIG--> Click OK
2. Replace checkmarks in the items that you previously removed them from.
3. On the General tab, choose Normal Startup
4. Click OK
5. Click YES, when asked to restart your computer
To Boot Clean in Windows Vista:
Accessing the System Configuration Utility
1. Click Start and select ControlPanel
2. Click System and Maintenance
3. Click Administrative Tools
4. Double Click System Configuration
Configure Selective Startup options
1. On the General tab, choose Selective Startup
2. Uncheck Load Startup Items
3. Select the Services tab
4. Check Hide all Microsoftservices
5. Click Disable all
6. Click on OK
7. Click Restart.
Install the downloaded device driver/software.After performing the necessary steps, restore your system by doing thefollowing:
4. Double click System Configuration
5. On the General tab,choose Normal Startup
6. Click Ok
7. Click Yes, whenasked to restart your computer
Hope that helps!
If your issue isnot resolved, please do not assign a rating just yet. Please post back asto what steps you took, results, etc, and I will try to assist you further asbest I can.
P.S. - You can rate asolution with one of four ratings as explained under (remember that at times abit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem. (Positive Rating)
  • "Helpful" - The solution provides useful leads that helps solve the problem. (Positive Rating)
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated. (Negative Rating)
  • "Inappropriate" - The solution has absolutely nothing to do with the problem. (Negative Rating)
Thank you for using FIXYA!
IrishDruid
Posted on Oct 04, 2008
What is meant by PDF as used in scanning?
PDF is the format in which your scanned document will be saved at. In some cases you have options to save either as PDF, Jpeg depending on your scanner and the scanning software. Hope this helps!
Mar 31, 2015 | HP Scanjet G4010 Flatbed Scanner
I want to install my hp scanjet g4010 on ubuntu 11.04
you need a driver to do this, you can see this on the cartoon/box of your scanner or go to the nearest service center of HP. thanks
Jun 24, 2011 | HP Scanjet G4010 Flatbed Scanner
My hp scanjet 4010 sacnner cannot scan to pdf, am having xp pro as my os
Make sure that the driver for your printer has been installed. There is a CD that comes with this scanner. Make sure to use that and install all necessary software.
May 04, 2011 | HP Scanjet G4010 Flatbed Scanner
Hi: I have a 'all in one' HP C6280, and a HP scanjet 4010. They don't want to co-operate. Now I find that I really need to use the G4010. (I had just stopped using it). At first I thought I should...
Go to the Device manager and delete ( not only uninstall ) driver for G4010 .
Now unplug unit . Go to Controm Pannel \ programs and delete the software . You can also and preferably use a cleaning tool such as Revo Uninstaller .
Reboot but do not connect scanner yet . Reinstall software driver .
Reboot and wait for OS to be settled .
Connect your scanner and wait for confirmation of successfull operation It should work now , presuming you haven't changed your OS since before .
Regards .
Dec 29, 2010 | HP Scanjet G4010 Flatbed Scanner
Hp scanjet g4010 and windows 7 professional drivers
Plz chk the manufacture website for drivers.if you cant find then you can try by intalling the win vista driver
Aug 11, 2010 | HP Scanjet G4010 Flatbed Scanner
How can I get a driver for hp scanjet G4010 for vindows 7
Try these, i find hp forum:
1st of all I installed Windows 7 and allowed Windows 7 to install the scanner drivers automatically before I attempted to install the HP software package.
- to do this, make sure the HP G4010 is powered on and the USB is connected to the PC
- Windows 7 will take over and install the drivers
- you can confirm installation by reviewing the "Imaging devices" section of Device Manager and you will see 'HP Scanjet G4010' and driver version 9.0.0.0 from Hewlett-Packard 4/10/2007, the device status should say 'The device is working properly.'
Very basic scanning should be possible even before the complete HP software package is loaded.
Next, retrieve the latest software from HP as below:
.... setup_full_G4000.exe (198,016 kb) ....
Save to your drive, then Right click, choose properties, click tab for 'Compatibility'
Click 'Change settings for all users'
Place checkmark in box next to 'Run this program in compatibility mode for:' and then from drop-down choose, Windows Vista (Service Pack 2), click 'Apply', then OK, OK to close all windows.
Now start the installation by "Double clicking" to run install, be patient, it may take a while to begin!
Also, watch the task bar as UAC message box mentioned above may appear behind the active window!
At the UAC message click 'Yes'
Follow on-screen instructions as usual. I used the default install except as noted below . . .
(Personally, I choose the advanced installation so I could uncheck the "HP Photosmart Essential 1.12" since I prefer to use alternate software for this purpose. It should not matter whether you choose to install or not.)
Once installed, open "HP Solution Center"; go to "Help" then click "Check for updates"
Mine prompted for "Latest Version of HP Update, Version 5.2" ... This update has opt-in/out feature for individual updates, Win 7 compatibility, and minor bug fixes.
Click next to download and install. When you get the 'Installation succeeded message, click Finish"
Jan 14, 2010 | HP Scanjet G4010 Flatbed Scanner
HP F380 not working
Do the following:
  1. Unplug the scanner's USB
  2. Right-click on My Computer and select Properties
  3. In the Hardware tab, click on Device Manager
  4. Under Camera's and Scanners remove any HP scanner items that exist already (right-click and delete)
  5. Restart the computer
  6. Install the latest drivers for the scanner from the HP site (don't go anywhere else)
  7. Plug in the scanner
If this does not work, try plugging the scanner into a different USB port and see if it gets detected.
Jun 29, 2008 | HP Scanjet G4010 Flatbed Scanner
109 people viewed this question
k24674
jasbo
jasbo
