Question about Cameras
I am trying to download software for quickcam pro 9000 and I get a message saying internal erroe 2738
    President:
  • 2,712 Answers
Vista for some reason doesn'tregister VBScript. What you have to do is first of all find wherevbscript.dll is, mine is in C:WindowsSystem32, but I think itchanges dependent on your version. Next you need to go to start ->accessories and then right click on command prompt and click "run asadministrator", next type "cd C:WindowsSystem32" (replace the directory/path ifits different for you) and then type "regsvr32 vbscript.dll". It shouldthen confirm that vbscript has been registered and everything shouldwork.
If that does not work, try a clean install.
The following instructions willwalk you through this process:
  1. Remove the older software.
a. Unplugthe device from the computer. Later you will be prompted by the softwareto plug in the device; do so at that time only.
b. Openthe Windows Control Panel.
c. Openthe Add / Remove Programs window.
d. Locatethe listing for the device software/driver and remove it. When prompted toremove the device files, click Yes.
e. Locateany other device software/driver and remove it as well.
Now download the latest version of QuickCam for your OS from here:
http://www.logitech.com/index.cfm/435/3056&cl=us,en
To Boot Clean in Windows Vista:
Accessing the System Configuration Utility:
1. Click Start and select ControlPanel
2. Click System and Maintenance
3. Click Administrative Tools
4. Double Click System Configuration
Configure Selective Startup options :
1. On the General tab, choose Selective Startup
2. Uncheck Load Startup Items
3. Select the Services tab
4. Check Hide all Microsoftservices
5. Click Disable all
6. Click on OK
7. Click Restart.
Install the downloaded device driver/software.After performing the necessary steps, restore your system by doing thefollowing:
4. Double click System Configuration
5. On the General tab,choose Normal Startup
6. Click Ok
7. Click Yes, whenasked to restart your computer
FOR WINDOWS XP:
1. Click Start --> Run --> Type MSCONFIG --> Click OK
2. On the General tab, choose Selective Startup
3. Uncheck Process SYSTEM.INI file
4. Uncheck Process WIN.INI file
5. Uncheck Load Startup Items
6. Click on the Services tab
7. At the bottom, check Hide All Microsoft Services
8. Uncheck all boxes in the window or click the button labeled Disable All
6. Click OK
7. Click Restart
After restarting, reinstall the downloaded software. Next, do the following:
1. Click Start --> Run --> Type MSCONFIG--> Click OK
2. Replace checkmarks in the items that you previously removed them from.
3. On the General tab, choose Normal Startup
4. Click OK
5. Click YES, when asked to restart your computer
Hope that helps!
If your issue isnot resolved, please do not assign a rating just yet. Please post back asto what steps you took, results, etc, and I will try to assist you further asbest I can.
Thank you for using FIXYA!
IrishDruid
Posted on Oct 04, 2008
Adobe plugin
For my scanner I bought Silverfast. It is available for Windows and MAC.
Just look for a demo on this site
Silverfast scanner software for Nikon
Nov 09, 2013 | Nikon Super CoolScan 9000 ED Film Scanner...
I have a new HP desktop and cannot download my Quickcam cd..I have windows vista now. Help?
HI
u can download from this
http://www.download.com/Logitech-QuickCam-Pro-Camera-Drivers/3000-2108_4-10028593.html
http://www.logitech.com/index.cfm/support_downloads/downloads/
thank you
Dec 29, 2008 | Cameras
Is this camera also a web cam?
yes it is a webcam too, and the quickcam pro 4000 is completely different.
Dec 27, 2008 | Logitech ClickSmart 310 Digital Camera
400d
This is a very common problem, and usually to do with connection or communication problems between the camera and the speedlight/lense/or other device. Try cleaning the hotshoe contacts and make sure that the speedlight is firmly on the camera. Otherwise it may be an internal fault with the speedligh but this is not likely.
Cheers
Emmanuel
Sep 06, 2008 | Canon Rebel XT / EOS 350D Digital Camera
How do I install a QuickCam Pro 9000 on an iMac OSX running 10.5.2?
I simply plugged it into a USB port, opened Skype, and voila! It worked!
Apr 29, 2008 | Cameras
Purchased QuickCam Pro 9000. Install Disk gets to a point of loading drivers then I get a 1722 error. Have an IBM T60 Laptop running XP.
I had similar problems when installing this camera under XP, so I went to the Logitech website and downloaded the installer program directly from there.
When I ran the downloaded program the camera installed first go.
Mar 13, 2008 | Cameras
I have loaded the software from disc supplied with my webcam 9000 but keep getting told that upgrades are required when I start my computer. If I say yes upgrade deletes software already installed gets...
completely uninstall everything associated with the initial install of the camera, might require going into the registry and looking for any instance of the camera. Before you try reinstalling, make sure you have the most recent version of explorer as new scripts require updated IExplorer.
Mar 06, 2008 | Cameras
Format erroe
Have you tried to check the contents of the memory stick from your PC?
If you can't see the files on your PC, there are a number of file recovery software packages available, some are even free.
Dec 29, 2007 | Sony Cyber-Shot DSC-P72 Digital Camera
Cameras Logo
76 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
