Question about Microsoft Office Standard for PC
Creating a table in Ms-Access
I am creating a table through query builder.Here the table name contains blank space It is showing syntax error
eg:-
create table Tiny tots(no text(30),name text(30))
Here Tiny tots contains blank space
  • sreedevi_ven Oct 04, 2008
    I have a urgent requirement on creating a table
  • 345 Answers
Have you tried to name the table Tiny_tots? it might make it work. Sometimes programs are funny about letting you have spaces in the name.
Posted on Dec 17, 2008
What is the syntax for search in mysql database?
1.select * from tab;
will display all tables in database
2.if u know tablename then
select * from tablename;
It will display all data in the table
3.if u want specific information
eg : TableName:Students
Contains Fields: id , name.
select name from Students where id=1;
it will display name of student id=1
contact me for more information bhushan.softwaredeveloper@gmail.com
Rate It
Have a nice day
Mar 03, 2011 | Computers & Internet
How to invoke a ms.access using parser
To parse a Text field that contains two words separated by a comma, follow these steps:
  1. Open any existing database.
  2. Create a table with the following structure: Table: Parse2Words
    Field Name: Empl
    Data Type: Text
  3. View the Parse2Words table in Datasheet view and type the following three records in the Empl field: Smith, John
    Callahan, Laura
    Fuller, Andrew
  4. Create the following query based on the Parse2Words table: Query: QueryTest
    Field: FirstName: Right$([Empl],Len([Empl])- InStr(1,[Empl],",")-1)
    Show: True
    Field: LastName: Left$([Empl],InStr(1,[Empl],",")-1)
    Show: True
    NOTE: You can modify the QueryTest query to account for spaces between the two parts in the Empl field. For example, if the text in the Empl field is "Smith,John" without spaces, remove the -1 from the FirstName field expression.
  5. Run the query. Note that the QueryTest query separates the text in the Empl field into the two fields below: FirstName LastName
    John Smith
    Laura Callahan
    Andrew Fuller
Jan 08, 2011 | Microsoft Office Access 2003 (077-02871)...
SYntax error in from clause
Hi
Try to run the record set query (the one rs.open uses ) directly in the db you are using .
If you are not sure what is the query concatenate it into variable and get the full query just before you open the record set.
once you do that you will get better idea of what is wrong with the query .
Jul 20, 2009 | Microsoft Visual Basic 6.0 for PC
How to create a multiple access query and put altogether into 1 SQL Scrip(.sql file)
Suggest using Union Query. Thus, you can add more queries from many table and the output will be in one (1) query. Bear in mind that all fields must have same Field Name.
For example:
tblOne contains dtDate1 fieldname. Your query will select [tblOne].[dtDate1] As myDate.
tblTwo contains dtDate2 fieldname. Your query will have the following SQL:
Select [tblOne].[dtDate1] As myDate
UNION Select [tblTwo].[dtDate2] as myDate
Thus the output will result dates from tblOne and tblTwo in a column called myDate.
Regards,
Maha
Feb 05, 2009 | Microsoft Computers & Internet
Time based triggers or procedures
Syntax to create Triggers in SQL are :
Create Trigger trigger_name // "trigger_name" : Give name to the trigger
on
table_name // "table_name" : name of the table on which trigger has to created
for Update
as
Begin
// Here Query has to be written here
End
Dec 18, 2008 | Microsoft Computers & Internet
How to print only selected fields in ms access.
open your table in query, follow steps to do this...
1. open new query in access
2. locate the table
3. once table selected, select field name in selected table you only want to include in query
3. once finished selecting the field save the query
4. you can now view selected field in your table and print as well
5. you can edit the query anytime if you want to add or remove field
6. query will not affect your table since this is only query.
hope this will help you....
Oct 22, 2008 | Microsoft Access 2002 for PC
Table Repair MySQL
MySQL offers Check Table syntax that checks a table or tables for errors. It works for several storage engines like MyISAM, InnoDB, & Archive. If you run this syntax then you can the cause of problem & reported tables.
If Check Table finds errors then you can repair reported tables by Repair MySQL Table syntax.
Aug 06, 2008 | Sun MySQL
Problem in MS ACCESS
you need to upgrade first your operating system.. the new version of office 2003, is no compatible to your windows 2k.
Dec 13, 2007 | Computers & Internet
Viewing ms Sql Server database on Access
Are you familiar with "Linking" tables in Access? In Access: File --> Get External Data --> Link Tables. This will bring up a dialog box which allows you to browse to your SQL server and select the table you want.
Aug 23, 2007 | Microsoft SQL Server Standard Edition for...
Microsoft Office Standard for PC Logo
87 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
