Question about Toshiba (K000006610) for Satellite P25 Series Motherboard
Bluetooth, Driver Satellite P25-S5092
  • 30 Answers
All the toshiba products are her >< just select you model and then the driver you want
Posted on Feb 18, 2009
The monitor on my Toshiba P25-S5093 does not have any display of any kind; all black. I have display using external monitor.
Does the display show anything before you enter windows? If yes, then press the key to transfer video back to your original screen once you enter windows. It should be the function key "Fn" + F5 - F8. looks for the icon which shows a monitor or says "CRT/LCD".
If it doesn't show anything before you enter windows I'm afraid your screen needs to be replaced. Good luck.
Mar 08, 2011 | Toshiba Satellite P25-S5093 Notebook
I recently installed windows seven and now it doesnt give me the option to connect to the internet via wifi,i also looked in device manager as it is not listed.
Hi, the problem here is that your pc was not designed for windows seven. You can try downloading the latest driver for your device, or you may need to use a plug in to usb, to get wifi. Also for windows 7 you will need a minimum of 2Gig of memory.
Aug 29, 2010 | Toshiba Satellite P25-S5092: P25-S5092...
Can't read the SD driver. the Device Manager sees
try updating the card reader drivers or try with another sd card it`s possible that the sdcard to be broken
Mar 11, 2010 | Toshiba P25-S520 Notebook
I updated the bluetooth driver, now the bluetooth isn't recognize
well if you uninstalled it it won't be found! an update relies on the basic software being on the drive and deletes and modifies the files as it installs. reinstall the software and the connect and run the update
You can do this by using DEVICE MANAGER ( after installation) and selecting update driver.. and pointing to the new driver you want to install
Aug 14, 2009 | Toshiba Satellite P25-S5093 Notebook
Own a Toshiba P25-S5092. Will not power up. Goes
Power problems may do this, also if the CPU's heatsink has been loosen or detached, the CPU may me getting to hot and will self shutdown.
Aug 07, 2009 | Toshiba (K000006610) for Satellite P25...
SD card reader problem, Toshiba Satellite P25
Have a look into the device manager, right click my computer, select manage, then on the left side of the management window click on device manager, plug in the sd, do you see any ? or ! or yellow marks or unknown devices that a driver would be missing from or malfunctioning?
Jan 21, 2009 | Toshiba Satellite A105 Notebook
Media Test Failure?
go in to the bios and change ur boot order so the harddrrive is before the network or lan
Nov 23, 2008 | Toshiba Satellite A40 Notebook
Toshiba Satellite P25-S5092-display problems
what you need to do is replace the backlight to solve the display prob and as far as the fan and being that old you should replace the fan
Oct 08, 2008 | Computers & Internet
Toshiba Satellite P25-S5092/ Computer will come on, but screen will not work. Wondering if it is most likely the LCD screen itself, the backlight or something else.
If you have deduced that indeed the Toshiba Satellite P25-S5092 will boot and therefore operational except no display on the screen, you can always verify by connecting an external monitor. You of course would need to press Fn + F? (the F key with the small monitor icon).
As to the LCD screen having no display, often this could either be the CCF lamps (cold cathode florescent) and/or the inverter that powers it. One way to verify this is by shining a flashlight obliquely to the screen and a portion of your desktop would show albeit very very dark. Often, it is the inverter that fails. In some instances it could even just be a cold solder, loose connection or capacitors that have dried up, leaky or blistering.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 18, 2008 | Toshiba Computers & Internet
Toshiba Satellite P25-S5263 monitor problem
It could be a driver problem perhaps. Does the post screen show at all or is there absolutely nothing?
Dec 29, 2007 | Toshiba Satellite P25-S5263 Notebook
Computers & Internet Logo
85 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
