Question about Microwave Ovens
The electricity went out at my house and now my microave only flashes "8's", no matter what i try to program. is it broke forever?
  • Microwave Ovens Master
  • 8,872 Answers
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for maybe an hour.
Then let us know if the hard reset does not fix it and please reply back with your brand and model number so we can help you.
Otherwise, you may have a bad keypad or circuit board, which can usually be reasonably repaired.
Posted on Oct 04, 2008
Why is it taking so long for an answer to my question re the flashing colon on my new Hamilton Beach Microwave. Thank you.
there is a problem in the program board of the unit
take it to a repair shop for an exact diagnosis and quote
get the quote as most microwave oven repairs cost more than a new unit
Sep 10, 2016 | Hamilton Beach Microwave Ovens
It will not stop buzzing
No matter what you try the buzzing will not shut off? The only way to get it off is to unplug it? Otherwise it will go forever?
Oh and what is the model Frigidaire is it?
Feb 13, 2012 | Frigidaire Microwave Ovens
Handle broke off microwave
lLAST TIME MY GE MICRO HANDLE BROKE IT WAS 179 FOR REPAIR
IT BROKE AGAIN AT THE TOP
AS ITS TEN YEARS OLD I JUST PUT CRAZY GLUE AT THE TOP AND THEN TOOK AN OLD RUBBER HANDLE FROM A CAN OPENER AND TAPED IT WITH ELECTRICAL TAPE TO THE INSIDE TOP OF THE HANDLE THIS WAY THE HANDLE CAN ONLY BE OPENED FROM THE BOTTOM NEXT I WILL TRY TO GLUE THE CAN OPENER HANDLE TO THE BACK OF THE MICRO HANDLE AND REMOVE THE TAPE
Jan 28, 2012 | GE Advantium 120 Convection/Microwave Oven
The microwave display shows "--SE--" I have not
This fixed mine.
The problem lies with the mylar ribbon cable that connects the Keypad to the circuit board. The Mylar ribbon cable folds back onto itself and are touching. Over time the mylar 'breaks down' electrically and the wire traces in the mylar will 'arc' onto the other mylar ribbon cable. The solution is to separate the two mylar ribbon cables using paper and electrical tape. I've done this on several microwaves (not just Samsung) and it has worked every time. Patience and about 20 minutes is all it should take to fix it. I've described below how I did it for the SMH9187ST Microwave Good luck to all.
1. UNPLUG THE MICROWAVE !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
2. 1. Remove the top front cover by removing the (2) screws that are along the top edge (phillips).
3. 2. Slide the cover to the left about a half inch (there are tabs holding the cover in place) and remove.
4. 3. Remove (1) screw from the top of the Keypad Housing (phillips). Lift the Keypad Housing upwards about half an inch (there are tabs holding the Keypad Housing in place) and remove. Be careful of the metal grille that is just above the Keypad Housing as this may fall out since it is being held in place by the Housing.
5. 4. Be careful not to pull on the wiring harnesses that are attached to the Housing. Carefully unplug the wiring harness that has the RED connector on it from the circuit board. Carefully unplug the small white connector that has the mylar ribbon cable on it (this cable is see-through and you can see thin, flat wires in it).
6. 5. Remove (4) screws that are holding the circuit board onto the Housing.
7. The Housing should now be free of the circuit board and wiring harnesses. It's safe to let the wiring harness/circuit board hang free, but caution should be used anyway.
8. 6. Remove the thin metal frame from the Housing. There are (4) plastic tabs holding the frame in place. Using a small screw driver pry one side of the frame away from the housing (try to do this to the side that has smaller plastic tabs). When this side of the frame is free of the Housing you have to lift the frame out at an angle to remove. It might put up a fuss, but be patient and be gentle with it since the frame is thin and fragile.
9. 7. With the frame out of the way you will see the mylar ribbon cable that is coming out from underneath the Keypad assembly. You will notice that the mylar ribbon cable folds back onto itself as it re-enters the Keypad assembly. This 'touching of the two ribbon cables' is where the trouble lies. The ribbon cables may be stuck together. Carefully separate these two and then insert a small piece of paper between them (paper can be 1/2 x 1/2 ) and work the paper all the way down into the Keypad assembly as far as it will go.
10. 8. Using electrical tape, apply a small piece between the ribbon cables to hold the paper in place. Next, use more electrical tape and put it between the mylar ribbon cables enough so as to keep the ribbon cables separated.
11. 9. Re-attached the thin metal frame making sure to press it into the Keypad assembly enough so that the (4) tabs click into place.
12. 10. Use electrical tape and apply it to the raw metal edge of the thin metal frame to prevent the mylar ribbon cables from rubbing on the metal edge.
13. 11. That's it. A final word of caution. Be careful when inserting the ribbon cable connector back on to the circuit board. The connector is loose and you need to gently place the ribbon cable into the circuit board connector.
14. 12. Reverse the order of assembly from above.
15. 13. Plug in the microwave and then it should reset and ask you to set the time.
16. Hope this works for you !!
Jun 11, 2011 | Samsung SMH9187ST Microwave Oven
MICROAVE JUST SHUT DOWN, REPLACED FUSE, MICROWAVE WORKED FOR ABOUIT A MINUTE THEN SHUT DOWN AGAIN, ITS KEEPS BLOWING THE FUSE. IS THIS SOMETHING THAT IS REPAIRABLE OR JUST NEEDS TO BE REPLACED?
It is one of three things, the magnetron "heats food" or the high voltage capacitor, and diode. If the magnetron is gone, cheaper to replace the microwave, as far as the other parts go, it will approach the price of a new one.
Feb 02, 2011 | Microwave Ovens
I need user Manual For my microave sharp model R4A53
goto the sharp website and down load it
Dec 26, 2010 | Microwave Ovens
Oven made a "growling" noise
The magnetron may have either failed or is not being supplied with the extremely high voltage required to run it.
Make sure the !!!!capacitor is discharged!!!!! before attempting any sort of repair.
Check the door interlock switches first then the high voltage diode with either an AVO model 8 on high resistance range for short circuit, the feed fuse on the primary of the high voltage transformer and then finally, the magnetron is best checked by substitution. I suspect the magnetron and diode.
Hope that helps.
Nov 04, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Microave does not turn and heat. the light comes
Replace the magnatron assy and the high voltage fuse.
Jul 10, 2009 | Microwave Ovens
I need to replace the glass turntable tray on my Emerson MW8626W microave oven
I looked up the right reference nº on the internet site which sells glass turntable trays. Thanks for your response!
Jun 13, 2009 | Emerson MW8626W Microwave Oven
Electric went out to the house, it came back on, and the microwave inside light works, the display panel reads just a " : ", and none of the buttons work. I have tried resetting the breaker with same
Hi cschnur,
     It seems that you might need to replace circuit board.
All the above mentioned conditions refers to a faulty circuit board. You might have blown few Ic's.
Take a voltmeter, check the continuity. If you are aware of the Ic's, replace them.
Unless, look for a tech, a used board ( On http;//www.ebay.com ) or purchase a new one.
Thanks for using Fixya.
Do rate the solution as "Fixya" if 100% satisfied.
Apr 17, 2009 | Kenmore 63682 / 63684 / 63689 Microwave...
Microwave Ovens Logo
22 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
