Philips plasma error codes
After reading through quite a few posts, I believe you are the person to ask, hope that is ok.
My plasma is not powering up, just giving the flashing lights on PS and front LED. Both are flashing twice, delay of about 5 seconds and repeating the flashing twice and so on.
Can you explain what the error code is for me please, as I can't seem to find any reference material listing the error codes, and have been informed the manual will take nearly 2 weeks to arrive.
Thanks in advance,
Robert Gray
  • Robert Gray
    Robert Gray Oct 04, 2008
    just thought I should add, the front led, flashes twice, then after 5 seconds, stays on for 2 seconds then blank for a second then flashes twice blank for 5 seconds then repeats above over and over.
  • Robert Gray
    Philips 50PFP5532D/05 just realised this was removed after posting sorry.
mumma_1
  • 903 Answers
SOURCE: doesn't turn on power led flashing blue then light blue then off
http://forums.nvidia.com/lofiversion/index.php?t55653.html
LOTS OF PEOPLE ARE HAVING THE SAME PROBLEM IT IS A FIRMWARE PROBLEM AND THESE MONITORS ARE NOT COMPATIBLE WITH VISTA. VISIT THE SITE TO SEE OTHER PEOPLES SOLUTIONS ETC....
Posted on Oct 25, 2008
  • 138 Answers
SOURCE: philips 42pf7321d/37 blinking power board question
The probleis with one of the maina boards and trouble shooting would have to be done to see which board is bad.
Posted on Aug 19, 2008
kazzandra
  • 16 Answers
SOURCE: Philips 42'' Plasma TV 42PF7320A/37 red led error codes
3 flashes indicates that there is a problem in the power supply circuit. Being that you have experience with this, you might be able to fix it.
Posted on Apr 04, 2009
romsky79
  • 822 Answers
SOURCE: Phillips 42pf5321d/37 No picture Error code D3V3
pls. check the power inverter.
Posted on Jun 28, 2009
  • 8457 Answers
SOURCE: 2005 Philips Plasma 42' TV - Red LED light blinks 7 times
Yes,u know how to solder right?Just use a fillip screw driver,u should able to opne it the back cover all the holes with screws.Here are some website u can buy parts for it.Tv Repair World.com,Shopjimmy.com,Ebay.com or Partstore.com.It a whole big plastic sheet,open all fillips screws it with a fillip screw driver,all holes with
screws ok.
Posted on Sep 26, 2009
PHILIPS 42PF9966/12 error code 003
If you wish to get some details, check the site linked here. http://electronicshelponline.blogspot.com/ Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. Error codes details are given. Try this link too. http://electro-medical.blogspot.com/
Jan 05, 2014 | Philips 42PF9966 42 in. HD-Ready Plasma...
6 slow and 1 fast blink on a Philips 60pp9200d/37 Thanks.
These blink code is fault indication. With Philips brand TVs, we cannot read these blinks as they appear. Means by digits. There is a special procedure to read these blinks. If you wish to get more details about the blinking codes reading procedure to Philips TVs, visit this site. Pull up older posts there. Details are given about how to read these blinks and convert them to numerical digits.
Check the site with patience. It has so many posts, and all are related to electronic equipment repair. Check it in 'Timeslide' option. It will be easy to find brands.
Apr 02, 2013 | Philips 42PF9631D 42 in. Plasma Television
I have a Philips BPU2.3U, 50" plasma. It turns on for about 30 seconds and then goes into protection mode, flashing the 53 error code. The manual says Viper, PNX8550 is at fault. Is this something...
Error 53.
This error will indicate that the VIPER has started to function (by reading his boot script, if this would have failed, error 5 would blink) but initialization was never completed because of hardware peripheral problems (NAND flash, ...) or software initialization problems.
Possible cause could be that there is no valid software loaded
Try to upgrade to the latest main software version
Your service manual can be found at the link below:
http://www.scribd.com/doc/6528782/Philips-42pf7320
Look at section 5.9 for instructions on upgrading your software and this should fix your problem.
Jul 04, 2011 | Philips 42PF7320A 42 in. Plasma HDTV
I have a F & P topload Intuitive Wasing Machine. It has come up with error code 37 which I believe is a blocked pump. do you know how to fix this or do I need to call a service person?
Hi just read your posting.Now if the machine is full of water drain some by hand, enough to lean the machine back so you can look underneath.To the front right you should see a red or black fan.This is your pump.Turn the fan a few times to loosen it.The fan should turn freely.Put the machine back on its feet and select a spin cycle and push start.Hopefully the machine will drain and then spin.Please reply on how you got on or if you have the newer style of pump.Looking forward to your reply.
Sep 22, 2010 | Fisher and Paykel GWL11 Top Load Washer
Philips flat screen 42" flashing red light 7 times it stops for 5 seconds and 7 more flashes if i unplug and plug it a few time it will come on
my 42 inch phillips, i turn it on green light comes on for 10 sec then red light comes on and flashes 4 times then stops for 5 sec then repeats.
Apr 20, 2010 | Philips 42PF9631D 42 in. Plasma Television
There is a problem on my computer.It says "Insufficient system resources does not exist" how do you resolve that?
http://en.kioskea.net/faq/2347-error-codes-in-windows
there isn't such an error . Please look again . There are several over errors with "Insufficient system resources" . you must have an error number (max 4 digits). you may check on microsoft page with that error code you didn't post . Other time please be more specific and try to write all your problem on the paper . Read it and if you consider that a third person fully understand your problem only reading that, post it. ok? :)
Mar 18, 2010 | Microsoft Windows XP Home Edition
42PFL5332D/37 does not turn on red light flashes 6 times.
Don't have a "solution" yet, but found this table that decodes the blinks:
Error Code Table
0 = No error
1 = X-ray protection, E/W protection, and/or Vertical protection active
2 = High beam current protection active
3 = Reserved
4 = +5V protection active
5 = Signal Processor (IC 7150) register corrupted
6 = Signal Processor (IC 7150) error
7 = Total failure
8 = Internal RAM error (Microprocessor IC 7000)
10 = NV memory (IC7088) addressing error
11 = NV memory (IC7088) size error
12 = Histogram (YUV) (IC 7770) error
14 = Sound processor I²C error (TDA9855)
16 = Main Tuner I²C error (IC 1125)
17 = PIP Processor I²C error (IC 7350)
18 = PIP Tuner I²C error (IC 1127)
I, too, have the 6 blinks of a red light. I found another person online that suggested that perhaps the power cord was "defective" as it's a common issue. I replaced the power cord with one from an old computer (they're the same cord) and it seems to be OK now. That's all I can offer you at this time.
Jan 20, 2010 | Philips 42PF7320A 42 in. Plasma HDTV
I have a 42in plasma flat panel philips tv and the menu will not quit popping up on the screen
One person had the same problem as you. He downloaded the latest software at phillips.com for the TV. It fixed the problem for him.
I hope I answered your question. Please rate me. :)
Mar 07, 2009 | Philips 42FD9934 42 in. HD-Ready Plasma...
Picture Problems On 50 Inch Philips Plasma
You plasma still under manufacturers warranty. Most electronic devices have one year warranty.
The failure in your TV can only be corrected by repairing it.
I would suggest to call philips and ask them to find you an authorized repair center near you to get your TV fix under their warranty.
Jul 24, 2008 | Philips 50PFP5332D 50 in. Plasma...
Televison & Video Logo
588 people viewed this question
Top Televison & Video Experts
