Question about RCA TruFlat 27F520T 27" TV
Why does my RCA TV cycle through channels on its own?
All of a sudden my tv started going nuts. It cycles through channels and when it finally stops, the volume goes through the roof. I have no control with the remote and the buttons on the tv work but don't get it to stop. Unless I hold the volume down button in, then the channel stops changing until I let go. Any ideas? Model # 27F522T Hi,
I have the exact same problem (without the volume issue). The remote is perfectly fine as it will work with another RCA tv we have. The channels continue to search and the only way I can get it to stop is by pressing and holding the - volume on the front the tv. I can bring the menu up by pressing the - volume button and then pressing menu, but I can't scroll through the menu. I think this does have something to do with some sort of lock feature as it popped up momentarily before this all started.
The model of my tv is a RCA 20" TruFlat 20F420T
  • 3 more comments
  • R4WEnforcer Oct 18, 2008
    my tv does the same thing it'll change channels on its own and volume is there any fix for this?
    I have the same problem
  • Anonymous Apr 28, 2009
    I have the same problem with the same T.V. and I have only used the T.V. for roughly 40 hours as I just bought it to watch some NHL playoff games last year and unplugged it till this year and I watched a total of three and one half games and it went nuts shutting itself off and turning on and would not stop until I unplugged it. I turned the T.V. on the next day and it started going through the channels.
    this all happened ONE WEEK after the warranty (one year warranty) had expired and only because it is a year since last years playoffs.
    RCA told me they would exchange it for $90.00, I paid $100.00 for it on sale. I WILL NEVER BUY RCA JUNK AGAIN,
    POOR CUSTOMER SERVICE AND BAD PRODUCTS.
  • Anonymous May 13, 2009
    electech1 here
    the "IR" sensor , EPROM ( IC101 ) , R033( 1k ohms ) , R102( 150 ohms ) , and crystal ( X001 ) , buttons should also be checked for a connection leak
    electech1 again
    also resolder heated components and or dried looking solder joints
    RCA has always made some good products and some that ended up being bad because of IC chips or other parts that are made in other countrys and are not made in a completely clean environment , thus leading "any product" using that component to failure and repair
  • 905 Answers
This is the same type of problem happening with other rca models and I know it is the EPROM CHIP but why this is failing is either because of design flaw , dirty enviroment that they were made in , to much voltage or current to the chip or too much of a draw from the chip causing it to fail . Or even a random frequency from the IR sensor or its circut I'm still investigating and testing.
leave the tv unplugged for at least 3 weeks durring this time resolder any solder that don't look good , I did this and it lasted for about 6 months(always plugged in to the wall) before it started doing it again. model # 27v412t
Posted on Oct 06, 2008
I know this sounds ridiculous, but my 20F420T did the same thing. TV went on and off at will, and when it was on, the channels changed automatically and wouldn't stop. The remote did nothing.
What I did was to fiddle around with the volume, channel and menu switches on the TV(not the remote) until the channels quit changing. It only took a minute and now it works fine. The remote works fine also. However, this happened six months ago and I thought the TV was infected with bed bugs and took it apart and found no problems.
I think it was just accidental that the fiddling with the volumn, channel and menu on the TV made it work. I wish I could say what the sequence was but I can't. I disconnected my TV from the wall socket, plugged it back in, and hit the channel on the TV and the channels started changing automatically. Then, like the person on this site suggested, I hit the volume switches and the rolling of the channels stopped as long as I kept holding down the volume button on the TV. Then, for some reason, I hit the menu button on the TV and it started working fine. I did nothing on the menu, just pressed the button on the TV.
I wish I could be on more help, but my TV works fine now and if it goes bonkers again, I'm going to do the same thing - hit the volume on the TV until the channels stop then hit the menu button on the TV.
Posted on Jul 15, 2010
I have this ALMOST solved. I have an RCA model #MZADG20743. I started playing with the wires that are connecting the channel buttons on the front of the tv with the circuit board. I turned on the TV and completely removed the wiring cluster (at the circuit board) that comes from those buttons and the channels stopped cycling. Unfortunately that is also where the remote sensor is connected, otherwise I would just leave it disconnected and use the remote.
So I reconnected the wiring to the circuit board and took an educated guess as to which wire would be the channel controller and severed it. At first I thought I screwed up because the TV didn't turn on but when I reconnected the wire, the TV turned on but the channels were still cycling. Leaving the TV on I disconnected the same wire and it stopped the cycling!
The remote works for all functions and turns the TV off, but it cannot turn the TV back on unless that wire is connected again... arghhh
Does anyone know wiring enough to give me advice on how to connect this wire so that it will bypass the faulty switch and still allow the on/off function to work?
Posted on Oct 24, 2008
Have Aiwa TV MODEL No. TV-A209 The problem that I am suddenly facing is that I can't change channels or volume or use any other function. I can't even turn it off with remote control. Its stuck...
have Aiwa TV MODEL No. TV-A209
Its stuck randomly on a particular channel that I was watching at that point of time.
Along with that channel it now shows a message in flashing red color that reads :-
AGING
O6895H
Now when I press ''Display'' button on remote control volume goes off and this code is shown :-
S123 K234 Y
000 001 1
The numbers in the second line can be navigated by ''CH+'' button and changed between 0 and 1 by ''Vol+'' button.
I really don't know anything about this. So, please help me out of this problem.
Nov 08, 2010 | Televison & Video
I have a toshiba 32a32 32" tv, the problem im having is all of a sudden the channels started switching by itself and the volume keeps going up to 100. when i set a channel it stays there for a minute then...
The problem is either from the remote or the television, there has been so much heat on the control panel of the television, so it has melted some lead off a part of the control panel and bridging it to another part, so it is increasing both the volume and changing the channel in an upward direction.
The solution is to change the control panel of the television or correct it by using a soldering iron to melt off the lead from where leads meet.
If you remove the battery from the remote and it still does the same, then it is confirmed that it is the televisions control panel. But if after removing the battery it stops scrolling up, then the problem is from the remote and the solution is for you to replace the remote with a new one.
Take care and good luck
Oct 23, 2010 | Toshiba 32A32 32" TV
My tv channels surfs on its own wont stop. have to unplug to stop
What you got here is common. The issue is the controller under the volume and channel and power butoons, This is defective!! your going to need to have the tv serviced. this part cost $75-90 bucks the labor may vary in your area. Please do be considerate as you recieved this info FREE when leaving feedback and ratings today.
Apr 28, 2010 | Vizio VW37L 37 in. LCD HDTV
The volume goes up by itself - SABA M5115GT
This is due to the signal reception. Some channels are broad casted with strong signal strength. Therefor you will find the audio is louder than other channels. Also, if there is voltage fluctuation/surges/spikes that is also responsible for suddenly increasing the volume. Best is to put a voltage stablizer
Jan 22, 2010 | Televison & Video
Tv channel is automatically changing
sounds like it need some cleaning , or main board might be disaligned , open it and take a look at the plastic buttons that touches the main board switches , good luck , AJ
Oct 24, 2009 | Televison & Video
Aiwa TV MODEL No. TV-A149 AGING
I have Aiwa TV MODEL No. TV-A149
AGING
6EDEH
S123 K234 Y
100 000 0
Sep 14, 2009 | Aiwa TV-S2011 20"
TV turns itself on, keeps changing it's own channel
the problem is with the control panel of your tv...make sure your remote doesnt have any part in this...just remove and the batteries and check if the channels still are changing.....see if the onboard switch for channel changing is stuck ?..if stuck u can use homemade tools to pull it back......if your tv is within your gurantee period...just giv a call to customer care....if not u can take it to a local repair shop...there is nothin that u can urself do to make it right ...sorry....for further info contact at
Jul 06, 2008 | Televison & Video
Hi there!
I think your remote may be at fault. Liquid spill or sweat from the hand accumelates on the inside over some time and then becomes sticky. Some of the buttons may be permanently activated. Then other functions won't work. Have someone check it for you or if familiar yourself. Regards, JUS004
Mar 12, 2008 | RCA TruFlat 27F520T 27" TV
RCA TruFlat  27F520T 27" TV Logo
1,052 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
