Question about Hampton Bay 52 In. San Lorenzo, Rustic with Leather Accents Fan
Ceiling fan my ceiling fan which is not that old where you pull the chain for the fan broke which keeps the fan on always what to do?This fan has gave us nothing but promblems
  • 550 Answers
The ball-chain switch is available at just about any electrical parts store
not radio shack, a commercial parts store
they are common to many items
just ask in the store for the switch that you require
on-off-speed control
or direction
when replacing the switch, just replace one matching wire at a time
Posted on Oct 04, 2008
Hunter ceiling fan pull chain for fan broke
First write down which color wire goes in which slot on switch.Turn power off! Disconnect wires from defective switch by inserting a paper clip or something a little bigger into the wire connection.Then press the spring down and release the wire to insert in new HUNTER switch. DO NOT CUT WIRES!Call 1-888-830-1326 with model # to order the correct switch.
Mar 24, 2013 | Hunter (25417) Ceiling Fan
My ceiling fan has two pull chains The pull chain for the light broke too short. When it broke the light was off. Now I don't have a ceiling light for my kitchen. How can I replace the pull cord?
You will need to replace the pull cord switch. It is inexpensive. You will need to open up the fixture and reemove the old one. Usually it is held on with a nut. If you are not sure of what switch to buy, take out the old one and bring it to a hardware store. Make sure the power is off. Cut the two line to the old switch and splice in the new switch with wire nuts, also use some electrical tape to insulate the connection. Reinstall the nut and close up the fixture. Good luck.
Oct 05, 2011 | Hampton Bay 52 In. White Redington...
My ceiling fan chain broke off from inside the plastic casing inside the hub. How do I open the plastic casing?
The cap on the bottom where the pull chain is located is removable and will give you access to the pull chain's switch, so that you can remove it and replace it. Be sure the wall switch is OFF before removing the cap. You can find a new pull chain switch at any home improvement center, on the ceiling fan isle. Take your old one with you for comparison purposes.
Hope this helped you & thanks for choosing FixYa.
Sep 22, 2011 | Heating & Cooling
The chain came out when i went to turn it off. now i can't start it.
turn power off to fan, and replace the pull chain switch. you can buy a switch at any hardware store. but take old one to get the right one for your fan. sometimes wal-mart may have one. good-day ! maybe the chain just broke. if this is the case, then just replace the chain if need be.MAKE SURE POWER TO FAN IS OFF WHILE CHANGING SWITCH !
Jul 11, 2011 | Monte Carlo Fans Indoor Ceiling Fans
How to attach an on/off chain to a ceiling light- the original broke off somewhere inside. The fan switch is intact. This is one unit.
You need the little coupler thing that connects to the ball that makes up the chain. If you dont have the coupler ... you could get one at your local Ace Hardware store ... or you could just purchase a similar switch which would have the coupler on the chain.
Jun 07, 2010 | Leviton 1689-050 Pull Chain Fixture Switch
Wire diagram for pull chain on ceiling fan hunter original
if you indeed have a 23852 hunter original...
Black goes to L, High is Red, Gray is medium and yellow is low. Make sure you have the right switch.
Mar 21, 2009 | Hunter 23852 Classic Original Ceiling Fan
Hampton Bay ceiling fan with pull chains not working
Whether there is a reset switch on this unit or not would depend on the model. If you no longer have the owners manual you should be able to get it from the hampton web site. Many fans have a thermal fuse inline that probably was blown when the bulb broke. The cheaper models do not and then I would guess you burned out the switch.
Feb 07, 2008 | Hampton Bay 54 In. Flemish Pewter Ceiling...
Troubleshooting for ceiling fan
Pls. check the ff;fuse,thermal fuse maybe wornout...
Jan 19, 2008 | Aloha Housewares (93645) Ceiling Fan
Ceiling fan will not turn off
There is 2way switch attached to this chain you need to replaced it.
Jun 04, 2007 | Hampton Bay 48670 Flemish Pewter Finish...
Hampton Bay 52 In. San Lorenzo, Rustic with Leather Accents Fan Logo
69 people viewed this question
Top Hampton Bay Dryers Experts
Craig Butler
Craig Butler
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
