Question about Compaq Presario 5000 PC Desktop
2 NICs connecting to 2 different networks
How can I connect a PC to two different networks ? One is mi local office network, the other one is intranet that connects my to the coporate office (fixed IP). The two networks are in different subnets.
Right now I am only connected to the corporate office, and I am installing a second NIC on thos PC to connect it also to my local office (for printing, file sharing and Internet).
How should this second NIC be configured ?
Thanks !
  • 661 Answers
You need to speak to your network administrator, for printers you get network enabled printers ( your network admin will assign an IP address and sharenames for your printers,
your network admin can create shared volumes on the network and can sort out internet routing that complies with the corporate domain.
sorry no easy way to do this
Posted on Oct 04, 2008
Most times this is because the computers have differing sub-net masks and/or IP addresses have differing roots. A simple solution is to set all computers to use DHCP to get their network addresses.
If you post the IP addesses and sub network fields for each machine I can be more precise.
Nov 19, 2013 | Computers & Internet
Can i connect 2 a wireless network?
Actually it is an office with 2 different networks. Currently there are two wireless routers (router A connect to network A; and router B connect to network B), then router A with a server set for internet access. The two network somehow link together already, but all nodes in both networks can't see each other(cant share files thru "My Network Place"). All nodes equipe with Windows XP.
It’s help u.
And Thanks.
Mar 03, 2010 | HP 285527-001 - Compaq Presario...
Networking with two different ISP's
Hi there
Even if you 2 different ISP that doesn't matter. If you need to connect all the computers together i'd suggest you to buy ROUTER and connect wireless.....
For further clarification please revert
Jan 23, 2010 | Network Computing Devices (NSH800S/A)...
Windows server 2003 routing
i would say use your server as dhcp or set your pcs with a default gateway that is your server.
Dec 28, 2009 | Microsoft Windows Server 2003 Enterprise...
What are the two ethernet for? Does it let you plug in both and you can use both at the same time, therefore downloading faster than one or something?
No you can't download any faster with 2 NIC ports.
In a typical setup where a PC has 2 NICs, one is setup as the connection to the internet and the other can be used to interface with any device that is Ethernet capable (home video cameras, alarm systems, home control systems, etc). However, the other NIC can be connected to another network.
You can even share an internet connection though a wall NIC throughout the home.
This means 1 for the internet and the other for networking to another hub/server or computer.
Nov 13, 2009 | ASUS A8N-SLI Premium Motherboard
Nokia IP 260, allowing a remote office having a direct connection
You should disable NAT between your local networks in the Checkpoint NAT policy (Create a NAT rule above all and put all your networks in the source and destination - as a group)the leave Original in the translation column.
Jan 12, 2009 | Nokia IP 260 (2 Pack) (NBC0260000)...
PPPoE over Edimax BR-6104K without a modem
I am not sure if I understand you well.
You say:
My Internet is a PPPoE broadband connection but I don't have a modem installed.
What do you mean ?
You have a Broadband/ADSL modem, but you didn't install any software for it ?
(It is probably not necessary.)
So, I assume you do have a modem. You connect your modem to the wall outlet with a telephone cable.
Then then modem is connected with LAN cable to one of your PC with two NICs, you make Internet Connection Sharing, and ten from the second NIC of that PC, you connect (again) with LAN cable, your second PC.
If it is an ADSL or Cable modem connected with LAN cable, please follow this steps.
First RESET your Edimax router and disconnect all LAN cables if connected.
Connect your PC (the one with one NIC) to one of the 4 LAN ports of your Router wit a LAN cable.
Open My Network Places and then View network connections, or go to Control Panel and open Network Connections.
Right-Click on your LAN adapter and choose Properties, then double-click on Internet Protocol (TCP/IP)
Set to 'Obtain IP address automatically' and 'Obtain DNS server addres automatically' (click OK). Now you are back to the previous window. Click and check (if it is not) 'Show icon notification when connected' and once again click OK.
After a fiew seconds you should get (near to the clock in the the right bottom of your desktop), a Network icon and a baloon message that your NIC is connected.
Right-click on the network icon and click STATUS, a window will open
and then click on SUPPORT tab.
You should see:
IP Addres:
Subnet Mask:
Default Gateway:
Open your browser and type
Now login as:
admin (default)
and password is: 1234 (default)
Click on GENERAL SETUP on Top-Left, and then on WAN (on the right side) and choose
Click on 'More configuration'
Type your User Name and Password you have from your ISP.
Now Click on APLY, and again APLY !
The Router will restart in 30 Sec, and your NIC will reconnect.
Now connect your Modem to a WAN port of your Router with LAN cable. (***)
if you've typed your User Name and Password correctly in PPPoE fields,
if everything is OK with the service from your provider,
you should now be on Internet.
If not, then please check your User Name and Password with your Internet Service Provider, and ask them if they can see your router.
Now, get to the PC with two NICs.
Go to Control Pannel, and go to Network Connections.
Right-click on one of your NICs and click 'Disable'.
Check the other NIC if 'Internet Protocol (TCP/IP)' settings are set to Obtain IP addres and DNS - Automatically, and 'Show icon notification when connected' and once again click OK.
Connect the (enabled) NIC with LAN cable to another port of your router.
The second PC should be on Internet, too.
If you (somehow) realy don't have a modem, but you have a cable only, follow the above instructions to the point (***) and connect the cable to the WAN port of your router.
That's it!
Aug 28, 2008 | Edimax BR-6104K Router (br6104k)
Help mi out plzzzz(wireless problem)
what you can see on your network connections? If you can see some icon of internet connection or local network connection you can right click and then point to properties after that you can see the local area connections properties. double click the Internet protocol (TCP/IP) click it and then click obtain automatically ip address. Some wireless network, you can see the network provider which you can see on your network locations. Sometimes you can put specific ip adress of your provider. If not? you can make your own network connection, right click the internet connection and then click properties follow the instruction and go to network connection and sign up your username and password so that you can access through internet connections.
Jun 25, 2008 | HP Pavilion dv6000z Notebook
2 ethernet cards can't work together
If in your network you are connecting computers directly to a PC thru multiple nics and not a router or hub leaving one as server and the others as clients and that server is NT 4,0
NT 4,0 can not auto configure the cat5 cable and would need at least 1 cable to be a cross-over and not a patch.
Apr 01, 2008 | IBM NetVista A40 PC Desktop
This example will demonstrate how to create a Virtual private Network (VPN) between two remote locations through the Internet. The VPN policy will use 3DES IPSec to securely send/receive encrypted data over the Internet. When the VPN tunnel is enabled, the two offices will virtually appear to be on the same local network. This example will consist of two DI-804V VPN Routers with a simple setup. The two remote offices in this example will be known as Office A and Office B. Both VPN Routers must already be set up and able to access each other. This is only an example, your setup will vary using the WAN IP address provided by your ISP. Please note the differences in the IP addresses for each office. We will begin by configuring the DI-804V at Office A. Start by going into VPN Settings under the Basic Setup menu. Step 1. In the Connection Name field, type in OfficeA. Click ADD. Step 2. A properties screen will appear for the new connection you have made. Fill in the appropriate information for Office A: Connection Name: OfficeA Local IPSEC Identifier: Local Remote IPSEC Identifier: Remote Remote IP Network: Remote IP Netmask: Remote Gateway IP: Network Interface: WAN ETHERNET Secure Association: IKE Perfect Forward Secure: Enabled PreShared Key: 123456 Key Life: 28800 IKE Life Time: 3600 Step 3 Click SAVE. There should now be a VPN policy created for Office A. Now you will want to Save & Restart the DI-804V. Note: 123456 is an example of a preshared key, please fill in any secret preshared key you desire. Keep in mind that both sites require the same preshared key. Office A setup is now complete, we will now configure Office B with the other DI-804V, Follow the same steps previously with Ofice A to create a VPN policy. Step 1 Please change the appropriate information. Connection Name: OfficeB Local IPSEC Identifier: Local Remote IPSEC Identifier: Remote Remote IP Network: Remote IP Netmask: Remote Gateway IP: Network Interface: WAN ETHERNET Secure Association: IKE Perfect Forward Secure: Enabled PreShared Key: 123456 Key Life: 28800 IKE Life Time: 3600 Step 2 Click SAVE. There should now be a VPN policy created for Office B. Now you will want to Save & Restart the DI-804V. After the VPN policies have been created for the two Offices, the two remote locations should authenticate and connect. To view the status of the VPN connection, go to the Device Status menu. On the bottom-left side of the menu, click on the VPN Status icon. A VPN Status pop-up screen will appear showing VPN connection status. If a VPN tunnel is active, the State should indicate Q-Estab. Go to a DOS prompt and ping the internal IP address of the remote network.
Feb 16, 2006 | D-Link DI 804V (DI-804V) Router
Compaq Presario 5000 PC Desktop Logo
95 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
