Question about Intel Motherboard
How can I repair my acer 5310 power system
Please I mistakenly connected my HP printer adapter to my laptop and itgot spoil. It do not power on anymore even when I connect it adapter. I am in an area where there is nocomputer repair shop. Please what can I do to get it to work, I really need to use it.
  • 136 Answers
You problably burned it. The printer works with 30 volt current, and the laptop works at 18 volt.
If there is a floppy drive, remove it and try to boot.
Best of luck.
Posted on Oct 11, 2008
Acer a500 repair
When you connect the power adapter into the laptop, does the power LED light up? If not then -
The battery adapter or the adapter's power lead or the laptop's power socket could be faulty.
Check power adapter's DC plug that connects into the laptop power socket with a multimeter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced.
If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard.
This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
May 18, 2013 | Acer Iconia A50010S16u Tablet Computer
HP Pavilion dv6-3007tu
what exactly is your problem? will it not start?
Jul 25, 2011 | HP Pavilion dv6-1122us Notebook
I have an older HP DeskJet 722C printer and an Acer Aspire 5050 3242 laptop. Is it possible to hook up this printer?
I would say, it quite possible. If, the printer is a USB connection then it is only the matter of assuring the drivers for the printer will work properly with the operating system. You may obtain the latest drivers here HP DeskJet 722C printer
If the Printer happens to use the outdated parallel port, I would suggest to use an adapter, you can review the ones currently available online here Parallel to USB printer cable
It is always possible to use old peripherals on newer machines, it is only the matter of researching the internet to rather any available adapters are on the market to maintain older printers.
I hope this is helpful!
Jul 13, 2011 | Acer Aspire One Netbook 8.9" Notebook
My laptop was damaged in power...i cannot open it and i cant charge it... how much your board?
if your laptop at guarantee period, bring it to acer service center and all service will free
Mar 11, 2011 | Lifetime Acer Aspire 5310 Replacement...
I have a hp 6735s laptop. Its just out of warranty. When plugged into the mains adapter it is no longer charging the battery. This means it only works when plugged in. Have i inadvertantly set the...
best way is to just try out the battery on another laptop, or try another battery on yours. If the laptop is not very old, and I suppose yours isn't more than 2 years old, your battery shouldn't be dead.
Aug 16, 2010 | HP Compaq 6735s Notebook
Repair manual for HP Pavilion dv6 1245 dx
Go to Click on support and drivers tab. Select "See Support & Troubleshooting Information." Enter your laptop model number. dv6-1245dx. Click on "GO". See: "What Type Of Support Do You Need?" Choose MANUALS. Scroll down the page and select "HP PAVILION DV6 ENTERTAINMENT PC - MAINTENANCE AND SERVICE GUIDE". Download that PDF format. It is relatively easy to get to the ribbon cable that connects the touchpad to the motherboard. It is connected via a ZIF connector. I had a dv1331se and the touchpad stopped working. I just reseated the cable in the connector and all was well. Hope your solution is as easy as mine was. You'll have to remove the trimplate just in front of the keyboard. Be careful with the connectors there. The manual is well laid out and the diagrams easy to follow. Good luck. HP Pavilion dv6 Entertainment PC - Maintenance and Service Guide
Mar 16, 2010 | HP Pavilion dv6000z Notebook
HP Printer Usb port in my Acer Laptop , shortcircuits my house
Try using external USB HUB (POWERED) Adapter. It might fix this issue.
Use an other USB cable and see.
If the problem still exist do not plug in the printer again, you may damage your USB port or even burn your laptop motherboard.
hope this helped
Aug 26, 2009 | Acer Aspire 6930-6941 Notebook
You either have a bad adapter or a broken power jack in the laptop. To check the adapter use a multimeter set to voltage and connect one lead to the center in and the other to the outside metal contact. You should get a reading from 18 to about 26 volts. If you get no reading then the adapter needs to be replaced. If you get the correct reading then the power jack in the laptop will need to be replaced. If yo are ok with electronics repair you can get the jacks from if not your local computer repair shop should be able to do it for you.
I hope this helps, If so please rate my solution,
Corporate Computer
Over 21 years of PC and printer support/repair.
Jul 08, 2009 | HP Pavilion zd7000 zx5000 zv5000 presario...
How to turn on wireless on Acer Aspire 4520 laptop
At the top of your key board right below the power button, there is a row of hotkeys the far left one is the wireless button.
Sep 04, 2008 | Computers & Internet
Intel Motherboard Logo
Top Intel Computers & Internet Experts
Alun Cox
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
