Question about Sony Playstation 3 (PS3) Console
NO SYTEM SOFTWARE ON CONSOLE GETING MESSAGE SAYING "THE SYSTEM SOFTWARE CON NOT RUN PROPERLY. IF THE SYSTEM CAN NOT BE RESTARTED, THE SYSTEM PARTITION OF THE HARD DISK MUST BE REFORMATTED AND YOU MUST REINSTAL THE SOFTWARE...."
  • Anonymous Mar 16, 2014
    it tells me to connect to the storage media and update version 4.55
    Problem Solver:
  • 7 Answers
Do not reformat the drive, In all likely hood you will have to call Sony and describe this to them. They may be able to send you some kind of disk to install the software but more than likely you will have to send them the system and they will do it there and send it back. (They don't really want people getting a hold of the source software) Hopefully you are within your warranty period but they should be able to work with you weather you are or not.
Posted on Oct 04, 2008
My Garmin Nuvi 255w no longer works. It just shows a message saying "System Software Missing". I use a MacBook. I don't know if that will change what I might need to do to fix this but so far...
Hello there,
The solution to this problem simply requires you to connect the nuvi to a computer. The start up files are corrupt, therefore causing it not to run properly.
You will have to download the web updater of garmin on your computer, then you connect the nuvi using the usb cable to the computer, then you update the software of the device using the webupdater.
That is how to solve the problem. Other than that, nothing else. Just try to get a friend with a PC to do this for you.
Hope this information helped. Goodluck Elect_Comp
Sep 02, 2011 | Garmin nuvi 255W GPS Receiver
Downloaded TriJix. Installed it. When I try to run it, I get a Windows message saying "TriJinx has stopped working..."
what operating system are you using? try right clicking on it and going to
properties>compatibility>run as
and select windows XP
Mar 03, 2011 | Brighter Child Trijinx for Windows
Acer orbicam 3690-2710 stop working after install. Initially worked upon setup, but when I try to reopen after closing it a message appears saying: "A webcam was not found or is not working...
Access Camera Assistant Software:
a. On the taskbar double-click the Camera Assistant Software icon , or from the Windows® Start menu, point to All Programs, Camera Assistant Software, and then click Camera Assistant Software. The Camera Assistant Toolbar location briefly displays on the desktop.
b. On the Camera Assistant Toolbar, click the Start Camera button and click on the icons on the software.
If the the above steps are not working, then follow the below steps:
You can reinstall the WebCam drivers from the Acer recovery management, to do so:
Start Menu> All Programs> Acer erecovery management> Restore> Restore Application & Drivers> Contents> Select Acer Crystal Eye and install it
OR
Got to http://gd.panam.acer.com/home/
Select the computer model
Select Operating System
Click Drivers
Select Camera (Orbicam) and download it.
Once downloaded install it on your computer.
If still facing the issue, then you may need to perform full system recovery, to do so please follow the steps mentioned below
You can restore the computer back to factory default,to do so, follow the below steps: Turn OFF the computer, now as soon as you hit the power button, keep on holding "Alt" key
& keep on tapping "F10" key, i.e Alt+f10, it will open the recovery console, select full factory restore and follow onscreen instruction.
NOTE: This will erase all the datas on the computer
Dec 06, 2010 | Acer Aspire 3690-2710 Notebook
PS3 Update successful,install failed,systemrebooted,error8002F14E
On the playstation 3 site error code tool says this code is an issue updating the PS3 sytem software. Try to start with the hard drive uninstalled then try again installed. If that dont help i would format the hard drive in a laptop and see if it helps. worst casr scenario you could dissasemble the PS3 and unplug tha battery on the main board and see if that helps. Good Luck
Nov 24, 2009 | Sony Playstation 3 (PS3) Console
Vedio driver
If you have the driver try to reinstall it.
if you dont have it identified your mainborad model.
(to identified your mainboar model click start>run and type "dxdiag" without quote.) look at sytem model and system manufacturer.
find the driver on the net or post the driver model here.
if you have graphic card identified the model
Jan 24, 2009 | Microsoft Windows XP Professional With...
I have a recording software called Sonar 6 and every time i try to start it, i get an error message saying "sonar has stopped working". I have had the software for a few months and it's only just...
HAI,SONAR 6 SOAFTWARE WORKING PROPERLY IN THE MIDDLE IT'S NOT WORK OR FIRST YOU HAVE INSTALL THE SOAFWARE THAT TIME WILL NOT WORK.ANY WAY UNINSTAL SONAR AND REINSTAL IT'S WORK FINE.
UNINSTAL :
START>CONTROL PANNEL>ADD REMOVE PROGRAMS>SONAR>REMOVE.
RE-INSTAL :
DOUBLE CLICK FOR EXE SETUP PROGRAM FOR SONAR>SELECT TARGET AREA(DEFAULT C:\)>FINISH.
RESTART SYSTEM AND USE SONAR.
Jul 05, 2008 | Computers & Internet
EasyShare Application.
What operating system are you running on the 2nd computer. If it is new and you are using Windows Vista there is a good chance your software is not working.
try downloading another program to help you with your photography. You can still hook up the camera but you may have to use another program to work with the photos.
Jun 25, 2008 | Kodak EasyShare C663 Digital Camera
Socrates3001@msn.com
pls u check and clean ur front door interlock switch.. its geting any loose contact or cheeting problem..
May 07, 2008 | Xerox DocuColor 12 Color Copier
Sony Playstation 3 (PS3) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
