Question about Kenmore 24032\24036 Top Load Washer
Kenmore 110 How do I drain the water from the machine so it won't be heavy to move it?
  • Jeff Rockwell
    Jeff Rockwell May 11, 2010
    Why is the tub full of water? Do you have a malfunction the washer that will not let it drain by using the drain pump?
  • 943 Answers
Hi to drain the water completely put hose on the floor in a bucket . thanks the appliance doc
Posted on Oct 08, 2008
    Novelist:
    Champion:
  • 261 Answers
First lets put the machine on a spin cycle to see if it will drain.
Kenmore heavy duty 60 series model 110 91566210 won't drain- what now?
Not draining could be blocked or faulty pump, If you could hear the pump, probably blocked check filters, check pipe work, including the external drain hose. If you cannot hear a pump run, could be faulty pump, or could be totally blocked with something, jamming the impellar, would need the pump taken out or pipes disconnected from it to clear
Mar 05, 2013 | Washing Machines
I have the kenmore heavey Duty 70 series 92273100 Model 110 that we just moved. Was working fine before. Now it won't stop filling, overflows, and doesn't go into wash cycle. It will only s
either the pressure switch is bad or the pressure switch hose from the wash tub to the pressure switch is kinked or plugged so air pressure cant reach switch and operate switch,remove hose at tub and blow into it and see if machine now operates,if not the switch is bad
Feb 19, 2012 | Washing Machines
My kenmore washer model number 110. 92573210 washer seems fine it just will not drain, is this the water pump?
HI,
Check back of washe with a flashlight for a bent or clogged drain hose. Do not move washer to check it. When you move it , it will straighten out and you will never know if it was bent
Also while it is pumping , pick up end of drain hose at drain and observe the volume of water being pumped.
If no water then the Pump may need replaced
Thank you for using fixya
Leo Ponder
Please rate me if this helped
Aug 12, 2011 | Kenmore 22422 Top Load Washer
Kenmore heavy duty 70 series model 110-8237012
probably your drain pump leaking it has a seal right where it attaches to motor,,,,mine is leaking there but haven't replaced it yet! lol
Feb 27, 2010 | Kenmore Washing Machines
No spin cycle
Something simple. Plug off the wall mains. Find your pump, dismantle to locate block. Before that you could check out your filter to clean out.
Mar 12, 2009 | Kenmore Washing Machines
Washer won't drain
Dear cbringer,
I have the same washer. I have had the same problem with it. It's the timer module. You can get additional help from http://www.repairclinic.com.
Hope This Helps,
Jay
Won't spin or drain
Check to make sure your lid switch is working.
Nov 17, 2008 | Kenmore 22422 Top Load Washer
Drain old water
hi thanks for the question. to drain washer.put hose on floor in bucket. this will drain your washer thanks. for the question the appliance doc
Oct 04, 2008 | Kenmore 22062 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
48 people viewed this question
Sal De
fordexpert
Robert Rankin
