Question about Brother DCP-110C All-In-One InkJet Printer
Brother DCP 110C
When I go to print the printer says it is unable to clean and requests that I look at the maintenance booklet which I seem to have misplaced
  • allyas32 Feb 03, 2009
    I have the same problem, it says look up in the manual troubleshooting and maintainance. I have cleaned what it says, but still the same message.
    Can anyone help?
    Thanks.
    Ally,Kent.
  • Brother Master
  • 4,338 Answers
Here is your user manual:
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_DCP_110C_EN_2.PDF
Please remember to rate all Techs who assist you for free :)
Posted on Oct 04, 2008
PROBLEM IS MY PRINTER SHOW ERROR CLEAN UNABLE 46
Hi
This is the counter inside the printer which stops the printer unless it is reset. Follow the below steps to do the reset on your printer.
How to Reset Brother DCP 110C, 115C, 120C, 130C, 135C, 145C, 150C, 165C, 185C, DCP 195C Printer
May 25th, 2011 • Printer
How to Reset Brother DCP 110C, 115C, 120C, 130C, 135C, 145C, 150C, 165C, 185C, DCP 195C Printer:
1. Press the Menu, then Mono Start key then press the UP arrow key 4 times to make the machine enter the maintenance mode and "ERROR 46′ pops-up in the display.
2. Enter maintenance mode 80: Select 8 by pressing the UP/DOWN arrow key and push OK key and select 0 and push OK key
3. Now Press MONO arrow key several times until you see PURGE:XXXXX
4. Select 2 and push OK, Select 7 and push OK, 8 and push OK, select 3 and push OK and the purge counter is now reset to 00000.
5. Press STOP/EXIT key to go to root of maintenance mode
6. Enter code 99 to exit maintenance mode: Select 9 and push OK, Select 9 and push OK.
Jul 24, 2011 | Brother DCP-110C All-In-One InkJet Printer
I HAVE BROTHER DCP-195C MODEL IN THIS PRINTAR 1 EROR IS UNIT EROR 50 I DO NOT ANY PRINT AND I DO NOT DO ANYTHING PLEASE HELP ME WHAT I DO I HAVE NO OTHER MONEY SO I DO NOT BUY NEW ONE AND I HAVE SMALL...
Hello, I have a printer model (Brother DCP-195C). And now this printer is an error with the word (Unit unable 46 See troubleshooting and routine maintenance chapter in user's guide) And please help me forgive somebody
Oct 10, 2010 | Brother DCP-110C All-In-One InkJet Printer
Brother DCP-110C printer not printing!
Clean the heads....................
found in printing preferences / maintainance
Jul 16, 2010 | Brother DCP-110C All-In-One InkJet Printer
My brother dcp 110c dosent print clearly on the black faded in colour all the rest of the colours afe fine
goto ink maintenance on the panel and select print nozzle check... check the print out to see if all the ink are printed out .. if not, try doing head cleaning to see if it resolve your print out problem.
May 28, 2010 | Brother DCP-110C All-In-One InkJet Printer
My brother dcp 110c printer is unable to initiate and refers to routine maintenance - it does print out test sheets however and I have undertaken routine maintenance - not sure what else to do
Unplug the printer from power cord.Press and hold the "menu" button, then plug the device.You'll see on the LCD screen a "machine error" code.If this code is 40,41,49 or 4F the print head is defective.If the
error is 50 or 51 there is error in Purge unit and printer require service.If the error is 48 - defective print head cable or circuit board.If the error is 46 the waste ink tank is full.Follow this:
1. Pres 'menu', 'mono start' then 'menu' one by one...
2. Press the arrow up or down to go to 'maintenance 80'.
3. Press 'mono start' several times to go to 'Purge'. Finding the PURGE will show some numeric value
which is Iassume the number of times the printer had cleaned.
4. Press 'arrow up' key and scroll for number "2" then press "set".Do the same for numbers 7, 8 and 3.
After you have entered this combination, the purge numeric value will be reset to 00000.
5.Restart printer
Nov 13, 2009 | Brother DCP-110C All-In-One InkJet Printer
Brother DCP 110C error unable to print
Hey, its the in-built annual maintenance by "Brother", get it to the service centre, if the warranty is valid. I've faced the same problem sometime last year, I'm facing it now. Which my warranty has already expired.
Sep 05, 2008 | Brother DCP-110C All-In-One InkJet Printer
Brother DCP-110C printer/copy/scan/photocapture
so please tell us, what does the display tell you? Is it unable to clean? If so search for "unable to clean" or Error 46. This is explained a thousand of times here...
Mar 16, 2008 | Brother DCP-110C All-In-One InkJet Printer
Unable to clean
you need a new waist ink absorber box and have to do a reset. The absorber box can be purgchased from a service partner (see brother homepage of your country). Same procedure:
http://www.fixya.com/support/t139675-need_reset_purge_counter_due_error_46
Mar 08, 2008 | Brother DCP-110C All-In-One InkJet Printer
Brother DCP-110C All-In-One InkJet Printer Logo
258 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
