Question about Haier Washing Machines
Display is reading unbalanced after spinning i have taken item out and tried to spin again i have also put drain cycle on to empty water out still comes up UNB what do i need to do to put another wash load on Thankyou.....
Hi......no i did not fix the problem but i can not afford the premiumm plan...its back to washing by hand.
Thankyou....
Posted on Oct 05, 2008
Clothes coming out soaking wet
put it in the spin cycle and if nothing is coming out the drain hose it is most likely the drain pump ....just a fyi some are easier than others to replace.
I don't see the make and model of this machine so to give you specifics I can't. just general directions.
also I would check under the dasher there is a screen under there if you wash DIRTY clothes and maybe add a case of dog/cat hair it could be restricting the flow but wouldn't stop it totally.
also another fyi if you do get to that point use a toothbrush to clean it as you don't want to poke any holes in it.
Hope this helps.
Jan 20, 2015 | Dishwashers
I have a Whirlpool WFC7500V Front Load Washer and after the load is done the clothes are still soaking wet, is there a step i am missing why are the clothes still really wet. Do i need to drain or is the...
What spin cycle are you using? Try a faster spin option. (The wrinkle release setting uses more water and a lower spin speed.)
Try putting fewer items in a load in the futute and make sure it isn't unbalanced. (One really heavy item could imbalance the load and shift the spin efficiency.) Redistribute the clothes and run a Drain/Spin cycle.
Make sure to use HE detergent (don't use more than the recommended amount of detergent).
The other issue to check is if the machine is draining properly. Check that the drain hose isn't clogged. Also check the voltage at the washer - low voltage will result in a slower spin cycle. To correct this, you probably will want to call an electrician.
I hope this helps.
May 05, 2011 | Whirlpool Washing Machines
Water is in the drum after a complete washing cycle, you can't see the water but you can here it slushing around and leaves a foul order when not used for several days.
Make sure that the outlet hose is not blocked and the filter is clear.
If this is OK then the following from Maytag may be helpful. If not call a repair man for service.
Is the Delicate or Hand Wash cycle selected?
Spin speeds can vary by the cycle that is selected. Your washer is designed so that in certain cycles, such as the Delicate or Hand Wash cycles, the spin speeds are slower. In these cycles, more water is retained in the load at the end of the cycle to protect the delicate fabrics from shrinking and wrinkling. Select the appropriate cycle based on the fabric being washed.
Was Max Extract selected?
Ideal for heavy loads such as towels and bedding, Max Extract removes more water from loads during spin.
Were you washing one bulky item, such as a rug or large blanket?
Consider adding more items to help balance the load during spin. Select Drain/Spin or Spin Only cycle and restart the washer. Your washer is designed to detect an unbalanced load and automatically lower the spin speed. Unbalanced conditions are more likely to occur with a single, bulky item.
Are excessive suds present?
Use only HE High Efficiency detergent. Using non-HE detergent or more than the manufacturer's recommended amount of detergent can cause excessive suds. The excess suds can cause the washer to run at a reduced spin speed, which will result in very wet loads.
See also: Why HE High Efficiency detergent is required
Is the drain hose kinked or is the drain clogged?
Make sure the drain hose is not kinked. Straighten the hose for adequate water flow. Remove any blockage from the drainpipe or utility sink. Use the U-shaped drain hose form or hose retainer on the drain hose, and secure the drain hose. See the Installation Instructions for details.
Is the end of the drain hose more than 96" (244 cm) above the floor?
The drainpipe (standpipe) height requirements are: 96" (244 cm) maximum and 30" (76.2 cm) minimum. Your washer will not be able to adequately pump the water out of the washer if the drainpipe (standpipe) exceeds 96" (244 cm). In this case, the water may flow back into the washer. See the Installation Instructions for details; find them by entering your model number in the Manuals and Literature search below.
Is your outlet voltage low?
Check the electrical source or call an electrician.
Sep 10, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag washer won't shift to rapid spin dry (only slow back & forth)
Hi Jim, you issue could be caused by a couple either one of a of the following,
1) Draining problem, cant empty the water from the machine within the prescribed time limit - preventing the spin programme to commence. check pump filter is clear and waste water is pumping from the end of the waste hose, the hose itself could be blocked with limescale and detergent residue.
2) Unbalanced load, most machines wont spin 1 item, its a safety thing, if a machine spins with one heavy item it puts the drum out of balance resulting in excessive drum movement possibly damaging the inside of the machine and put indue stress on the bearings. Try putting it on a spin cycle with no clothes in
Unbalanced load detection can also be caused by a faulty motor tacho, this usaually positioned at the rear of the motor, this sends an electrical signal to the programmer telling when it is 'Safe' to spin. There also the posibility that the programmer is not reading the tacho signal or misinterpriting it.
May 20, 2009 | Maytag Washing Machines
Clothes come out soaking wet
Is the Delicate or Hand Washables cycle selected?
Spin speeds can vary by the cycle that is selected. Your washer is designed so that in certain cycles, such asDelicate or Hand Washables cycles, the spin speeds are slower. In these cycles, more water is retained in the load at the end of the cycle to keep delicate fabrics from shrinking and wrinkling. Select the appropriate cycle based on the fabric being washed.
Was an Extra Low, Low or No Spin option selected?
Select the highest spin speed for the fabric being washed. If extra low spin or no spin was selected, the washer may not remove enough water from the load.
Consider adding more items to help balance the load during spin. Select $FL-drainspin cycle and restart the washer. Your washer is designed to detect an unbalanced load and automatically lower the spin speed. Unbalanced conditions are more likely to occur with a single, bulky item.
See also: Why HE High Efficiency detergent is required.
Make sure the drain hose is not kinked. Straighten the hose for adequate water flow. Remove any blockage from the drainpipe or utility sink. Use the U-shaped drain hose form on the drain hose, and secure the drain hose. See the Installation Instructions for details; find them by entering your model number in the Manual and Literature search below.
The drainpipe (standpipe) height requirements are: 96" (244 cm) maximum and 30" (76.2 cm) minimum. Your washer will not be able to adequately pump the water out of the washer if the drainpipe (standpipe) exceeds 96" (244 cm). In this case, the water may flow back into the washer. See the Installation Instructions for details; find them by entering your model number in the Manual and Literature search below.
Check electrical source or call an electrician.
Dec 13, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Will not spin,
Dec 11, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Code to restart washer Duet
Answer Is the Delicate or Hand Washables cycle selected?
Nov 22, 2008 | Whirlpool Duet GHW9150P Front Load Washer
My haier washing machine doesnt work properly
get rid of it. I had two of these that did the same thing. people all over the internet are suffering with haier washing machines! They are utter rubbish and I will never buy haier again!
Jul 30, 2008 | Haier 14.3 lb. Washer/Dryer Combo
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
Washing Machines Logo
144 people viewed this question
Top Haier Washing Machines Experts
Gerry Harvey
Gerry Harvey
Owen Barnes
Are you a Haier Washing Machine Expert? Answer questions, earn points and help others
