Question about Toshiba Satellite L45-S7423 Notebook
Primary and secondary mouse disabled
Please help! My primary and secondary mouse pad/select keys have been disabled. For a while they would work when they wanted to and now they do not work at all. For a while the secondary mouse click would open the options menu everytime I tried to select something with the primary. Now neither of them work and I have to navigate with the tab key and arrow keys. I never had this problem before; it all started soon after my cat ran across the keyboard, I think he must have pressed some combination of keys that caused this. How can I fix it??
    Genius:
  • Toshiba Master
  • 1,250 Answers
I think the buttons of the mouse pad are on press mode you should consult a technician for this
Posted on Oct 04, 2008
Mouse won't left click
mouse is most likely dead. you can switch the mouse properties so that the right key acts like the left key which requires uses of the window key on the keys board to access menu then use tab keys and then arrows keys to move to control panal the tab and use arrow keys to goto mouse and select switch primary and secondary button...but if your not into that just buy another mouse they re rather cheap
Dec 07, 2012 | ASUS Computers & Internet
Cq60 frozen mouse pad
Since you don't seem to want to help us in helping you, by being more detailed about your mouse, or mouse pad, problem, I will give you some general advice:
- This is a laptop, yes?
- It has one of those little areas where you can use your finger, instead of a mouse?
- Look in Device Manager, or even in the Mouse option in Control Panel, and see if you have a mouse configured for your laptop, in addition to the built-in finger pad for use as a mouse.
- If you find there are two separate devices, one for the laptop-supplied mouse square, or rectangle, with the buttons on the bottom, for use instead of a mouse, and one for an external mouse, then make sure you have designated the built-in pad for use as a mouse. If, however, you want to use an external mouse, then you do the opposite, and ensure that the external mouse is selected as the device you wish to use for a mouse, and disable the built-in mouse/finger pad software, so that you do not have a conflict.
One or the other must be primary, and the one not primary must be disabled, or your laptop must be told not to use that other one.
Apparently - again, because you gave us absolutely no details - there is a hardware conflict and the laptop doesn't know which device to use, so it is not using either, and you're stuck without the benefit of any pointing device.
All the work you need to do with device manager and control panel must be done with keystrokes, and for that you must use Windows' Help to learn which keys will do what. Usually the four arrow keys, near the numeric pad, along with Page Up and Page Down, and the Tab button, or Shift+Tab, to go backwards, are all you might need to reset things the way they need to be set.
I hope you understand that absent any details at all, the only advice you will get from anyone here, is going to be educated guesswork.
Best of luck to you.
Cheers!
-a.
Jun 16, 2012 | Compaq Presario CQ60215DX PC Notebook
My mousepad is working but the cursor between left and right button doesn't work? I have a ACER Aspire 9300
1) Go to control panel (either with the help of keyboard or mouse)
2) Open Mouse
3) On Button Tab Select Button Configuration ( Switch Primary and Secondary Buttons)
4) Also Check your Touch Pad Driver Software
Thanking you
May 16, 2011 | Acer Aspire 9300 Notebook
Would like explanation of function key symbols I want to turn off the finger pad.
function key is Fn key on keyboard.
these keys might be in orange color
with the help of these keys you can control sound volume. you can adjust screen resolution like brightness .you can also turn off/on wireless features.These keys are like shorcuts keys to perform few functions on your laptop.
To turn off your the finger pad
You can use the Mouse Properties window to disable the touch pad and track stick or adjust their settings.
Open the Control Panel, and then click Mouse. For information about the Control Panel, see Windows Help and Support Center <findinfo.htm>.
In the Mouse Properties window:
Click the Device Select tab to disable the touch pad and track stick.
Click the Touch Pad tab to adjust touch pad and track stick settings.
Click OK to save the settings and close the window.
May 07, 2010 | Dell Latitude D610 Notebook
Cs walked on my laptop. noow cursor pad not working. Help
have a look at the F keys - is possible one of those disables the touch pad
you can enable and disable the touchpads Touchpad: - to enable or disable a touch pad/pointing device from the Start Menu > control panel > Change to claasic view - {on left hand menu} click on the mouse icon Mouse Properties dialog box, click "Device Settings tab" select the device click to Enable or Disable OR You may need to enable in the bios/setup menu - as the PC boots - you should get a message on how to get into the bios/setup - usually using F2 or DEL Key or F10 see if touch pad needs to be enabled there OR one of the F keys may disable/enable - depends on the model of the Laptop - toshiba sometime use FN+F9 key
Apr 20, 2010 | Compaq (153515-001) Touch Pad
The touchpad stopped working after a powerpoint presentation i made. A friend helped me set up the laptop to the projector and he did press keys. Did he accidentally press some inactivating key in the...
FN + F9 should enable / disable the touchpad goto control panel - mouse - and see if you can change disable/enable touch pad from there Otherwise post back what windows version you have
Touchpads
you can enable and disable the touchpads Touchpad: - to enable or disable a touch pad/pointing device from the Start Menu > control panel > Change to classic view - {on left hand menu} click on the mouse icon Mouse Properties dialog box, click "Device Settings tab" select the device click to Enable or Disable OR You may need to enable in the bios/setup menu - as the PC boots - you should get a message on how to get into the bios/setup - usually using F2 or DEL Key or F10 see if touch pad needs to be enabled there OR one of the F keys may disable/enable - depends on the model of the Laptop - toshiba sometime use FN+F9 key
Apr 10, 2010 | Toshiba Satellite M55-S325 Notebook
Problem with mouse in my new Dell laptop
Touchpads
  • If this solutions solves you problem, please do not forget to rate my solution.
  • If not, then please comment back so I can help some more
Mar 25, 2010 | Dell Inspiron 1420 Laptop
HOW TO DISABLE TOUCH PAD DELL LAPTOP
You should have a "FN" key on the keyboard and one of the "F" keys should have a symbol that looks like the touch-pad, hold FN while using this key should disable it, failing this in control panel, then mouse and pointers, you should have touchpad setting there should be a disable button/radius.
Sep 04, 2009 | Dell Inspiron XPS M140 Notebook
Left click on mouse pad doesn't work!!!
i think u must have switched the primary and secondary buttons on ur mouse.i assume ur using windows.goto control panel-->mouse-->choose buttons tab-->u'll see a check box which sud read switch primary and secondary buttons.remove the check mark from here.sud solve ur issue...
Jun 22, 2009 | Dell 2 Button Mouse 6u226
Acer aspire one touchpad right button not working
you can try using the function key ( fn ) and the touch pad key on my acer it is the F7 key hold the fn key and press and release the touch pad key that will turn the touch pad mouse off and on also goto control panel / mouse and try switch primary and secondary see if that will make the right button work if not its probly hardware related and your best bet is to keep the external mouse going rather than fixing that one
Mar 24, 2009 | Acer Aspire One Netbook 8.9" Notebook
Open Questions:
Toshiba Satellite L45-S7423 Notebook Logo
121 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
