Question about Samsung U900 Soul Cellular Phone
Predictive text Over time the T9 dictionary has stored unusual choices that appear before more commonly used words. For example, when the letters for "you" are entered it will by default suggest "Yov" and "by" is suggested as "29". Is there a way to reset the dictionary to its initial words?
  • Anonymous Oct 06, 2008
    Most annoying when sending text that the phone selects incorrectly spelled words like yot for you and fob instead of for; sending text using predictive text is now a chore! I'm not happy - the phone is not easy to use at the best of times so the additional problems are making it not the best choice of phone.
  • Anonymous Oct 07, 2008
    I have the same problem with my Samsung... "is" = 47 and several others words. It learned it when i typed it in the address box by mistake and cannot find a way to undo the programing.
  • 6 Answers
I had this problem and it was very annoying. What you have to do is..... create a new text message, enter the text that is annoying (mine was is coming up as 47). When you type the word and it comes up with the annoying one, select the word that you wanted and enter a space, and do it again and again (you can do this in the same text message - it can take up to 20 goes and eventually, the dictionary recognises that you actually wanted "is".
Posted on Dec 08, 2008
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 147 Answers
Have you guys tried going to the options while dictionary is on?
There's a feature in my SE phone that's named My Words that displays the list of words listed in your T9 dictionary...there u can edit and delete the words in your T9 dictionary list, Samsung phones might have such feature too...but maybe the term "My Words" in my phone is called differently in Samsung mobiles. Try checking it out.Good luck!
Posted on Oct 09, 2008
Text Mode show on display nokia1600 handset
You can enter text in two different ways: the traditional text
input indicated by , or predictive text input (built-in
dictionary) indicated by .
To use traditional text input, press the key marked with the
letter that you want repeatedly until the letter appears.
To turn on predictive text input when writing text, select
Options > Dictionary and the desired language; to turn it off,
select Options > Dictionary off.
To use predictive text input, do the following:
1. To enter the word you want, press each key once for a
single letter.
2. If the displayed word is the one you want, press 0, and
start writing the next word.
To change the word, press * repeatedly until the word you
want appears.
W r i t e t e x t
24
If ? is displayed after the word, the word is not in the
dictionary. To add the word to the dictionary, select Spell,
enter the word (using traditional text input), and select OK.
Tips for writing text with traditional and predictive text input:
• To add a space, press 0.
• To quickly change the text input method when writing
text, press # repeatedly and check the indicator at the top
of the display.
• To add a number, press and hold the desired number key.
• To get a list of special characters when using traditional
text input, press *; when using predictive text input, press
and hold *.
or check this link
http://nds1.nokia.com/phones/files/guides/Nokia_1600_UG_en.pdf
Nov 14, 2011 | Nokia 1600 Cellular Phone
How do i set predictive text on samsung m8800
Follow the below mentioned method, also see the advantages of T9 dictionary :
1.
Check your manual to learn more about text messaging
Check your cell phone's user manual to see if your cell phone has the T9 function. While most new phones contain this function, if you have an older phone, you'll want to check to be certain. Look under the Text Messaging section in the manual.
2.
Enable T9 for easy texting
Enable the T9 setting on your cell phone. Some phone require that you enable this function. Check under your cell phone's Options menu and also under the text messaging options. Depending on your cell phone, you may be able to set T9 as the default method of text input or you may have to toggle the text input functions to choose T9 for every text message. Generally, the toggle key will be your asterisk key. Again, check your cell phone's manual for more information.
3.
Choose your language and other preferences for T9 texting
Pick your T9 preferences. Your T9 function may allow you to set several preferences. The most typical preference is language, and you also may able to set whether you want your cell phone to use T9 for word completion only or to predict which word you will type next. You may also be able to set the "delay" - the amount of time before your T9 function changes the letters you are typing to what it thinks they should be. Again, try your Options or Preferences menus in the text messaging module of your cell phone or consult your cell phone's manual. You will want to try different set-ups to determine which works best for you and your style of text messaging.
4.
T9 gives you more then one way to select the right word for your text message
Type your text message, toggling for T9 if your phone requires it. Once the T9 function is enabled or toggled, simply type the word you want. Do not be concerned if the letters do not appear correctly when you first start typing the word - they will correct themselves when you finish typing the word, as long as you spell it correctly. Your phone may offer a drop-down menu with word suggestions as you type. If your word shows up, scroll down and select it if you wish or continue typing your word. If your phone does not offer a drop-down menu, and the word that you type is not the word that you wanted, press the Down arrow key on your cell phone and another word will show up. Keep pressing the Down arrow until your word shows up. When you have the word you want, use the space function to continue typing.
5.
Add your own text expressions to T9
Add your own words to the T9 function. The T9 function comes with an extensive dictionary, but you can add your own words or abbreviations, too. Again, you may have to dig around the Options or Preferences section in the text messaging module of your phone. Once you find it, simply type and add your own special words or expressions to have them at your fingertip when you text.
Use T9 to express yourself in your own unique way!
Jun 12, 2011 | Samsung M8800 Pixon - Unlocked QuadBand...
Daughter borrowed phone and switched the text msg typing to auto fill and numbers. I have tried every thing and I can't figure it out, can you please help me? Thank you, Susan
Based on your description, what you are referring to is called T9 Predictive Texting. It allows words to be entered by a single keypress for each letter, as opposed to the multi-tap approach used in the older generation of mobile phones in which several letters are associated with each key, and selecting one letter often requires multiple keypresses. Example, when typing the word 'love' in a T9 activated phone, all you have to do is press the numbers 5, 6, 8 and 3 once in sequence. As compared to the regular texting, in order to complete the word 'love', you have to press the number 5 thrice, the number 6 thrice, the number 8 thrice, and the number 3 twice.
If you want to disable T9 predictive texting, it can usually be disabled by pressing and holding the hash or number key (#).
Hope this information is helpful.
Apr 08, 2011 | LG Cell Phones
Samsung Genio touch: The predictive text often makes up words as the first choice. e.g. On't - not, ar - as, Rm - so, Ger - her. Is there any way to delete these words from the dictionary as it is very...
I don't think you can delete words. However, if you re-enter the word you most want to appear first in predictive text by the 'add word' facility (even if the word you want is already there further down on the scroll menu) it will then become the first suggestion. So if you're always getting 'Gs' instead of 'it' simply re-enter 'it' in 'add word' (watch the case) and you'll get 'it' first. Get it.
Aug 15, 2010 | Samsung S3650 Corby / S3650 Genio Touch...
How do i remove predictive text?
Go to message - create message - options - dictionary then select dictionary off. The predictive text will be off. Thanks
May 15, 2010 | Lands Phones
When I text I get an underline and I can't get anything but the first letter of a 3 letter set on the keys
You must disable your Predictive text option, T9® predictive text mode allows you to type words with only one keystroke per letter, and the phone interprets what word you want. For example, to type the, press 8, 4, 3. To enable/disable T9® predictive text mode, select Options. Scroll to and select Prediction on or off.
Oct 22, 2009 | Nokia 2610 Cellular Phone
Samsung SGH-c225 predictive text malfunction
If you have accidentally saved a word into the T9 dictionary (ie, "IS" comes up with "47" or "Get" comes up with "HDU", you can teach the dictionary to revert back to the original word.
What you have to do is..... create a new text message, enter the text that is annoying, (ie, "IS"). When you type the word and it comes up with the annoying one, select the word that you wanted and enter a space, and do it again and again - you can do this in the same text message - it can take up to 20 goes but eventually, the dictionary recognises that you actually wanted "IS".
Nov 13, 2008 | Samsung SGH-c225
Reset the T9 text dictionary
I ran into this problem as well, and it is extremely annoying. I just lived with it for the longest time and then I finally decided to go looking for a solution. That came to a quick end when I found the Samsung FAQ and it said that there is no way to delete words from the predictive dictionary. However, that got me thinking. If it's predictive, can I teach the predictive to write the correct word? The answer is YES! Open a blank text message, don't worry about a number just go to the text entry portion. Type out the word and press zero to change it to the correct word instead of the numbers. Do this 10-20 times IN A ROW and then the phone will recognize the right word as being most used and change it back to that.
Sep 25, 2008 | Samsung SGH-a737 Cellular Phone
The text dictionary keeps giving me the wrong words and i cant change, how do you knock it off. the phones a samsung d900i
Using T9 mode
T9 is a predictive text input mode that allows you to
key in any character using single keystrokes.
Entering a word in T9 mode
1. Press [2] to [9] to start entering a word. Press
each key once for each letter.
For example, press [4], [3], [5], [5], and [6] to
enter HELLO in T9 mode.
T9 predicts the word that you are typing, and it
may change with each key that you press.
2. Enter the whole word before editing or deleting
characters.
3. When the word displays correctly, go to step 4.
Otherwise, press [0] to display alternative word
choices for the keys that you have pressed.
For example, OF and ME use [6] and [3].
4. Press [ ] to insert a space and enter the next
word.
Other T9 mode operations
• Press [1] to enter periods or apostrophes
automatically.
• Press [ ] to change case. Lower case (No
indicator), Initial capital ( ), and Capital lock ( )
are available.
• Press [ ] to insert a space.
• Press the Navigation keys to move the cursor.
• Press [C] to delete characters one by one. Press
and hold [C] to clear the display.
Adding a new word to the T9 dictionary
This feature may not be available for some languages.
1. Enter the word that you want to add.
2. Press [0] to display alternative words for your key
presses. When there are no more alternative
words, Spell displays on the bottom line.
3. Press <Spell>.
4. Enter the word you want using ABC mode and
press <OK>.
"The faulty interface lies between the chair and the keyboard"
Apr 21, 2008 | Sony Ericsson w580i Cellular Phone
Probs with text
Go to Settings->Other->Text Input->Personal Dictionary or Word Completion. If you have Personal Dictionary enabled, any predictive text words you've used in the past are still stored. With Word completion on, your Razr is auto-completing words from the Personal Dictionary. If you like to type the words in yourself, letter by letter, just turn these settings off. You can also want to reset your Personal Dictionary.
Jan 30, 2007 | Motorola Mobility RAZR V3
Samsung U900 Soul Cellular Phone Logo
1,040 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
