Question about Acer Aspire 5600 Series 5630-6951 Laptop
I have a Acer Aspire 6920 only 4mths old. The CineDashMediaConsole has stopped working.
  • Anonymous Nov 11, 2008
    the cinedash media console has stopped working it shows full volume and mute at the same time
Take the battery out and put it back in. I had the same problem with it.
Posted on Nov 12, 2008
  • 659 Answers
You are going to have to re-install it or it might have a repair function when you add remove programs, or on vista programs and features
acer ushally puts all their software in the base of the c:\ drive
so if you went c:\acer
there should be in there somewhere the install file for that as well but if you remove it from the control panel it might give you the option to modify or repair it as well.
Posted on Oct 04, 2008
How to get Acer Aspire F-15 to turn on after months of trouble-free working - machine only 4 months old yet has suddenly stopped working?
If it's not very old you should have a warranty. I would get a hold of the company you bought it from. Could save you a lot of money.
Oct 14, 2016 | Acer Computers & Internet
How do you open a port
  1. USB ports stopped working Acer Aspire 5750 - Tom's Guide
    www.tomsguide.com/.../usb-ports-stopped-working-acer-aspire-5750.ht... Apr 23, 2014 - USB ports stopped working Acer Aspire 5750. Tags: Aspire. Laptops... I have an Acer 5750 none of the USB ports work I tried disabling them all ... on Acer Aspire 4935 laptop Forum; Acer Aspire Computer - USB not working ...
Jul 11, 2015 | Acer Aspire Computers & Internet
Hi, I need help with my acer aspire 5750, the Multi-Touch Touchpad has stopped working. It works as in its moves the cursor on screen but the secondary touch control that controls; Circular-motion...
Hi
can you please check that the touchpad has not been locked i dont think it has but worth a try
by pressing FN+F7 or FN+F9
also check that the nulock has not been ingaged by mistake
also the scroll lock
or go to
start
all programs
acer
acer management
contents
scroll down to find the touchpad/pointing device
go over to the right by the green icon and hit the install tab
and let windows re install the touchpad
may be this will help
many thanks
Jul 07, 2011 | Acer Aspire One PC Notebook
CineDashMediaConsole.volume not working.
Cinedash FIX for Windows 7
This works to fix the CineDash Media Console!
I had the same problem with my Aspire 8920G
Now it works fine.
Getting the CineDash Media Console and Launch Buttons working
If you have problems with either the CineDash Media Console or Launch buttons then you will be happy to hear that the solution for fixing these is easy!
The first thing that you will need to do is install the “Launch Manager” which can be downloaded off the Acer website. Go to http://www.acer.com and click the service support, then driver download. Go to your model. Download the Launch Manager on the acer site. The filename should be “Kilimanjaro_v2.0.00_Vistax32×64_XPx32×64.zip” the version of Launch Manager under the Windows Vista operating system .This will get the Email, Web and Empowering Technology buttons working with their default settings. If you need to change what the buttons do, you can launch the application named “Launch Manager” in the start menu.
Uninstall any previous version of Launch Manager
The solution to my problem was to get the Launch Manager to run in compatibility mode for Windows Vista Service Pack 2.
Unzip. Explore the new folder and right-click Setup.exe.
To do this go to the Launch Manager Install directory (C:\Program Files\Launch Manager ), right-click on “setup.exe”, select the “troubleshoot compatibility” tab, check the “Troubleshoot program” check box and then click “The program worked in earlier versions of Windows but won’t install or run now”. Then select “Windows Vista Service Pack 2”. Then click “Start” program. Now everything should work properly! It will install. But don’t reboot yet!
Now locate and explore the freshly installed folder in your program files directory – (probably C:\Program Files (x86)\Launch Manager or C:\Program Files\Launch Manager depending on if you are running 64-bit or 32-bit)
right-click on “LManager.exe”, select the “troubleshoot compatibility” tab, check the “Troubleshoot program” check box and then click “The program worked in earlier versions of Windows but won’t install or run now”. Then select “Windows Vista Service Pack 2”. Then click “Start” program. Now everything should work properly! It will install.
Reboot and enjoy properly synced volume, and fully functioning buttons.
Feb 16, 2010 | Acer Aspire 6920 Notebook PC
Aspire 4520 epower management DMC has stopped working
uninstall any game recently installed (cossacks).
May 29, 2009 | Acer Aspire 4520 Notebook PC
My Acer Aspire 3000, Keybourd Stopped Working
i had the same problem. the battery does something during startup and the only way i found to fix it was to turn it on without a battery while its plugged into the adapter, or leave it in standby instead of shutting down... i dont know if theres a better way, but thats what i do.
Apr 11, 2009 | Acer Aspire 3000 Notebook
Keyboard and mouse stopped working
I would check the Flex cable's first. If keyboard is not working sometimes this does not allow the pad to work. Here is one of the sites I use for repairs. Good luck and have a good day.
http://www.insidemylaptop.com/taking-apart-acer-aspire-5100-laptop/
Feb 16, 2009 | Acer Aspire 5100 Notebook
How to use the CineDashMediaConsole on a ACER Aspire 8920
Every now and then, the CineDash media console on the Aspire Gemstone Blue models freezes, turns off, refuses to work, leaves you in locked out of the car in the pouring rain… The causes are endless, but the solution is quite simple.
To reset the CineDash, remove the power cable AND the battery for more than ten seconds.
Tadaa!
Sep 18, 2008 | Computers & Internet
Web cam is not connected!!!
hmmmm,
Make sure it is plugged in fully and has the appropriate software drivers installed
Jun 30, 2008 | Acer Aspire 5610-4648 Notebook
Pioneer DVR-K17RS ATA ACER CODE=39
Hi How old is this laptop? If it is brand new, then you should be able to send it back to acer. Its the problem with drive or mainboard not with the drivers.
Thanks
Mar 16, 2008 | Acer Aspire 5610-4648 Notebook
Acer Aspire 5600 Series 5630-6951 Laptop Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
