Water leak the water seem to be comin up on it self out of the draw where you put the power
    New Friend:
  • 38 Answers
Mabey the filter is cloged a little there is a small plastic tube from the drawer to the filter ,had the same problem cleaning the filter worked
Posted on Oct 05, 2008
It is reading F1
yes F1 is a water leak error, it means water has filled the base of the unit and shorted across the filter board flood sensor (this how it is intended to function), now can be a number of different things, we will start with easy stuff, 1. to much detergent can bubble over the overflow hole in the draw and run into the base take note if there is excessive suds in the draw you should have only a thin layer on the surface of the water. 2. the lid that comes down when you close the draw to seal off the draw is being held up by something that is too high (you shouldn't put anything in that is taller than the handle of the cutlery basket) either that or the seal itself or the motors that pull the lid down are faulty, 3. you may have a leak through the heater plate seal (easy to check open the draw and look underneath it, on the bottom of the draw there will be a plastic cover protecting the coils and heater plate simply look at it to see if any water is pooled in it or if there is any dried soap or water. 4. if not any of these you will be looking for a leaking pipe or water hose. 5. and on the rare occasion your filter board itself may be corroded from water contact making it think it is permanently being touched by water, get back to me if you require more info
Nov 14, 2011 | Fisher and Paykel Dishwashers
My 2001 dodge stratus is leaking radiator fluid bad.... I can't tell were it's comin from, only it's comin out fast. The car still runs... For a minute then it overheats and die's and won't start again...
MAYBE THE WATER PUMP OR THE SEAMS AROUND THE RADIATOR HAS BLOWN REPLACE THE RADIATOR TO MAKE SURE IT,S THE RADIATOR OR THE WATER PUMP FIRST BEFORE YOU DO ANYTHING IS ................GOOD LUCK
Mar 07, 2011 | 2001 Dodge Stratus
My pump is not drawing water from the pool, dissambeled pump and it is clean and free of obstructions. removed pump from motor and inpeller is spinning when plugged in and the defuser seems to be ok...
Ok I''m assuming the pump is mounted higher than the water level in the pool. This means it needs to be primed. If everything is air tight, it should be self priming. Check to be sure your piping is open from the skimmer to the pump and not clogged. You can put a garden hose into the suction line of the pump and feel for flow coming up out of the bottom of the skimmer. If that is ok, then fill the pump strainer basket with water. Be sure filter is selected to filter. Make sure that the basket cover is tight to the cover gasket. After filling basket with water, quickly close the cover and start pump. If it still doesn't work, fill the basket again with water and check for any leaks. If the mechanical seal is leaking, it will not self prime. I'm not sure what type of pump you have, but Hayward has complete manuals for their pumps on www.haywardnet.com. Most pumps work about the same. GOOD LUCK!
Aug 02, 2010 | Pool & Spa
Leaking water from bottom draw
To put machine into test mode: Press and hold keylock, then press and hold start button. Hold both in until machine beeps (if you have display, it will show all symbols). Press power button- display should now show HO. Press start button until LD shows in display- this tests lid motors. Activate lid motors by pressing keylock button- if you open drawer about 3 inches, you should see lid come down. Pressing keylock again will raise lid. Raise and lower lid several times by pressing keylock button to ensure lid is working properly- if not, lid motors need replacing. Good luck!!
Mar 18, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Grind
you have to service de 4wd lock system
or replace the cap your self should be easy with basis tools because the lock doesnt desengage weel no more
Sep 23, 2009 | 1992 Toyota 4Runner
Water leaking on fill , fiil hose is not leaking , appears to be comins out under tub
either your tub seal is getting bad between tub and transmission or your "water fill" tube to the "size of load" water fill control on control panel has a leak in the plastic tube
Aug 25, 2009 | Maytag Washing Machines
Fridge Leak
We fixed the leak by putting a pipe cleaner down the hole inside the fridge, at the back. This cleared the tube as it had gunk and grime blocking it. Now the water can run freely down the tube and into the drip tray which is at the back of the fridge above the motor.
Jun 12, 2009 | Fisher Refrigerators
Impeller rotates, seems to work well, o-rings appear to be OK, but pump will not draw water through the pump
this usually indicates an air leak in the plumbing. it will **** air because it is easier than water if there is a leak in the plumbing.
good luck David
May 27, 2009 | AO Smith Centurion 1081 1.5 Hp Standard...
Water still leaking
If the water is running down the front from underneath the drawer, then I would say that the hose is blocked from the dispenser into the drum.
You need to remove top cover, locate large black hose from dispenser into drum, feel and manipulate it to free any blockage of soap powder..
If the water still does not go into the drum, then you are going to have to remove hose to clear blockage.
Plz rate my solution.
Thanks.
Jan 08, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Washing Machines Logo
51 people viewed this question
Top Washing Machines Experts
