Question about NetGear RangeMax WPN824 Wireless Router (WPN824NAR)
No internet access
installed ok on my lap top.cant get online message comes up wireless security settings on this computer do not match settings on netgear. please can you help
regards
Don
  • donc444 Oct 04, 2008
    ive tried every thing but it still keeps saying security settings do not match settings on netgear im no to bright so if possible explain in easy terms only been using computer a short while
    Don
    President:
  • 2,712 Answers
- Go to Network and sharing center
- The go to manage wireless connection
- Right-click on the SSID, and then select Properties.
For WPA2 Users:
- Under the Security Tab, set Security Type to WPA2-Personal.
- Set Encryption Type to NONE. (Or you may select AES if its selected as TKIP or vice versa)
- Set Passphrase.
- Click on OK.
- Then try to check your connection?
- If you cannot still browse a website then try to go back to,
- Start and select connect to and find your network name and click connect
- Input the key and connect again
- If it tells you that it was successfully connected, then try to browse a website
- If not, change the SSID or your wireless network name
- Then connect to your network again (Start and select connect to and find your network name and click connect, Input the key and connect again)
Good Luck! Hope this will help!
Posted on Oct 04, 2008
  • Swilin Sampson
    Swilin Sampson Oct 04, 2008
    If you are on Windows Vista and the above does not work, try the following:
    1. Start
    2. Control panel
    3. Network and internet
    4. Network and sharing center
    5. Manage wireless networks
    6. strongest networks will show
    7. DoubleClick (your SSID)
    Go to: security tab
    Security type: No authentication(open) drop down and choose no authentication…
    Inscription type: WEP. Use drop down choose WEP
    Network security key XXXXXXXXXX
    Hit OK and it’ll connect
  • Swilin Sampson
    1. After powering up the router, use an ethernet cable to connect your
      computer to one of the ports on it marked 1 through 4. Next open a web
      browser window on the connected computer and type http://192.168.1.1
      into the address bar and press enter. This will take you to the Netgear
      Smart Wizard welcome page, click OK to begin the configuration.
      The router will attempt to detect the type of connection you have and
      the next message you receive should be Dynamic IP (DHCP) Detected,
      click Next once you see this.
    2. Next you will enable the wireless capability of your router. In the
      dropdown box for the region where you are located select
      United States
      from the list. On this screen you should also change
      the Wireless Network Name (SSID) from its default value to
      something unique so that your Base Station will not be confused with
      another. Click Next.
    3. You should now see a message confirming that your connection is
      working and wireless is enabled. However, your are not secured yet. Read
      the notes and click Done. Then direct your browser to http://www.routerlogin.net
      to continue the configuration. A window will pop up prompting you for
      your login and password, enter admin for the username and
      password
      for the password, then click OK.
    Once you have logged in you will see the main configuration page. If you are having issues with the automatic DNS assignment from the configuration window, try to add the following manually:
    Primary: 208.67.222.222
    Secondary: 208.67.220.220
    Hope that helps!
    Genius:
  • 1,250 Answers
Log in to your router , and in security and select none or
go to wireless setting then go to wireless setting access list press wirless setup access list if it is enable then enter you mac address or uncheck it
    Scholar:
  • 148 Answers
FOLLOW THIS FEW; Troubleshooting Steps
  1. Connect your computer directly to the modem, without the router. If you cannot access the Internet, contact your ISP.
  2. Reconnect the router, modem, and computer as they were before Step 1. Can you log on to the router? If not then:
    1. Check that all cables attached to the router and computer are secure.
    2. Check the Internet LED is lit. If it is not, troubleshoot light status, as explained in the router manual.
    3. Check the LEDs for the ports with cables are lit. If not, move the cable to a different port. If there are still no lights, then troubleshoot light status, as explained in the router manual.
    4. Check if the LED on the Ethernet adapter is lit. If it is not, then troubleshoot the adapter, do not continue this document. If the adapter is not NETGEAR's, contact Premium Support, or the manufacturer.
    5. Power off the router.
    6. Power the router on again.
    7. If you still cannot log on to the router, then do a hard reset on the router, as described in Forgot or Lost Router Password.
    8. If you still cannot log on to the router, Contact NETGEAR.
  3. Run the router's SmartWizard. This lets the router discover whether you have a static or dynamic IP address, and whether you are using PPPoE to connect to your ISP. (For routers without this utility, go to Step 7.)
  4. If a dynamic IP address is discovered, go to Step 8.
  5. If PPPoE is discovered, configure your router with the username and password from your ISP. Click Apply to enter the data. Go to Step 8.
  6. If a static IP address is discovered, configure your router with this information given by your ISP: the IP address for your router, the address of the ISP's DNS, and the address of the gateway. Click Apply to enter the data. Go to Step 8.
  7. If the Smart Wizard does not find an IP address:
    1. Power off the router.
    2. Power off the modem.
    3. Power on the modem.
    4. Power on the router.
    5. Go back to Step 3.
  8. Click Test to access NETGEAR's online test page. If the page displays, then you have Internet access!
  9. If the page does not display in a minute, see No Internet With New Router, Computer or Adapter: MAC Spoofing.
  10. Find out if the modem's IP address can be seen by looking at the Router's Status Page, as described in the manual. If not, then reboot the modem, router, and computer, in that order — waiting for each to completely reboot before rebooting the next.
  11. If the modem's IP is seen, then there is a problem with your browser's settings. Your security may be set too high for the Internet service you are trying to use, or your browser may be configured for a dial-up connection. In Internet Explorer you check this using Tools > Internet Options > Security > Default Level. If the slider is set to "High", change it to "Medium". Click Tools > Internet Options > Connections. If the radio buttons in the center are not greyed out, then settings for a dial-up connection are being used.
    Genius:
  • 1,269 Answers
You'll just need to enter the security key on your laptop. Sometimes its a WEP key or WPA key. You should have wrote it down when you setup the router initially. If you don't know the security key, you can get on the router's Setup Page.Connect your laptop hardwired to the router first. Open Internet Explorer and type http://192.168.1.1 and enter. It will prompt you for username and password. admin is the username without password. Then you can get the wireless network key on the wireless tab. Its called WEP key or WPA key. Hope that helps. When you get the WEP key. G
  • Michael Galve
    Michael Galve Oct 04, 2008
    If you forgot the router's wireless password, you can just reset the router. Press and hold the reset button at the back of the router for about 10 seconds then release, unplug the power to the router for about 20 seconds the plug it back in. On you laptop, look at the bottom right hand, right-click on the little computer icon that say wireless network.
    -Select Network and Sharing Center.
    -From there, Manage Wireless Network
    -Remove all the listed network there (highlight each and click remove.) Just clear all.
    -Then click on Add > Add a network in range of this computer
    -Select the Netgear signal on the available list and click Connect.
    -It should say successfully connected.
    Hope that helps!
  • 19,396 Answers
Disable all the firewalls on your computer, ensure that the wireless card on computer is on and is working fine. ensure you entered the right network key.
  • Ginko
    Ginko Oct 04, 2008
    You need to know what network key is used on the router. If you do not know the wireless encryption key, you will need to connect to the router using a cable and to set up your own wireless key.
    See here how to set up router security: Netgear Wireless Router Setup
I am a Comcast customer with high speed internet. I am trying to get my wireless router to work on my lap top (Toshiba). The lap top will work if connected to the modem directly. However, when I try to...
to configure the netgear router and to secure its network. . . .1, first make sure that your laptop is connected directly to the netgear router via ethernet cable.2. after securing step 1, on your computer, open browser, ( internet explorer or firefox )3. go to the address bar, the one with the http:\\ and erase everything inside it.4. type in there, 192.168.1.1 or www.routerlogin.net.5. username is " admin "password is " password "6. you would see netgear set up wizard. 7. for wireless configuration, click wireless settings on the left side of the set up wizard.8. you can edit network name, and get your network security key under security options. make sure to choose WPA PSK TKIP. so that you can have a personalize network key9. the network security key is the " passphrase "then click apply.then your all set for wireless connectivity.
Aug 12, 2011 | NetGear WGR614 Wireless Router
Can't get my lap top to connect wirelessly to my router. Model # WRT54G2. The laptop says it is reaquiring the network address, but nothing happens.
The Network and Sharing Center in Microsoft* Windows Vista* can be used to set up a secure wireless connection to the Internet.
Note: If an Internet connection is not automatically made by the operating system, you may need to contact your access point (AP), broadband wireless router manufacturer, or Internet Service Provider (ISP).
Set Up a Secure Wireless Connection to the Internet
These steps assume that your network adapter; AP or router; and cable, DSL or another type of modem have already been physically connected and configured. They allow you to create a new connection and configure it accordingly.
Follow these steps to set up a secure wireless connection to the Internet.
Note: If a wireless profile does not exist, you will need to create a secure wireless profile before you can set up a wireless connection to the Internet.
1. Access the Network and Sharing Center.
2. Select Set up a connection or network.
3. Click Connect to the Internet.
4. Click Next.
5. Select Wireless. At this point, if the network(s) that are listed say that the network settings do not match the network requirements, as shown in Figure 1, create a secure wireless profile and then follow the steps again.
6. Select a network and click Connect. If you are not connected to the Internet, you may need to contact your AP/router manufacturer or ISP.
To access the Network and Sharing Center, use one of the following methods:
  • Start » Control Panel » Network and Internet » Network and Sharing Center
  • Start » Network » Network and Sharing Center
  • Right-click the network system tray icon (the icon that displays two computer monitors) » Network and Sharing Center
Jan 10, 2011 | Linksys Wireless-G WRT54G Router
Hi do you know how I can connect my lap top to the internet wireless with my linksys wireless router ? the lap top asks for an access code and I do not know what it is or how to find it do you know how to...
The access code or password is the encryption key in your wireless router, without this key the wireless router won't allow the laptop/computer to connect to this wireless router.
The WEP, WPA, WPA2 encryption key is in your router's wireless settings. Log into your router and got to the wireless settings, you will need to get the SSID and the encryption key. Then go to your computer/laptop's wireless card and configure it with the router's SSID and encryption key, so it will then connect to the wireless router and the Internet.
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Dec 27, 2010 | Linksys Wireless-G Broadband Router
I need security code # for my wireless linkys router
You will need to check the wireless settings of the router.
Is there any computer online using the router.
check the IP address on that computer.
If yes then you can open the router set up page on that computer.
router set up page is the page where you can check all the router settings.
Click Here for more information about the routers and network
Mar 06, 2010 | D-Link Computers & Internet
No Internet via zoom X6 wireless router to desk top, lap top ok.
Access your zoom router by using the laptop which still has access to the router.
Your going to have to open your Wireless Network Connection Status window located under your network settings.
If you see this window your going to left click the (details) button
Now you should see a IP DNS server address
for example: 192.168.1.xxx
Type that address onto the address bar of your web browser.
it should take you to your router setup page.
There you will need to check if the lan port is enabled
Feb 04, 2010 | Zoom X6 Adsl Modem/router Rohs...
I can not connect my wireless Camera to My laptop Vista
You need free Dynamic DNS service from sites like NO-IP.com
Mar 21, 2009 | Computers & Internet
Cannot install D-Link router
You may try typing admin on the username field. Just leave the password field empty.
Once you're in the setup page, click on WIRELESS tab which on the left side of the page. On the Wireless page, you will see the wireless settings set in the router. You may also enable the wireless security on that page if there is not security enabled yet.
Please check this for your reference http://support.dlink.com/Emulators/di524/h_wireless.html
Hope this helps!
Nov 12, 2008 | D-Link ADSL2/2+ Modem/Wireless Router...
Can't connect home comp to laptop
how many wireless computers do you have?
is it a dekstop or laptop?
if desktop have you installed a wireless adapter? if laptop, is it using a built-in wireless adapter, have you enabled the wireless adapter or have you installed a wireless adapter?
please make sure first that the wireless adapters are installed properly or enabled on your computers, if everythings OK.
access the setup page of your router and change the wireless settings of it.
how to access the ui
- open the internet explorer
- on the address bar type in 192.168.1.1 hit enter
- enter admin under password, leave it empty for the username and click ok
- click the wireless tab
- set the wireless mode to mix, change the wireless network name or ssid with any preferred name you want to use, make sure to enabled the ssid broadcast and then click save settings.
- after that, under wireless tab, there are sub tabs, click wireless security
- set wireless security to WPA-PERSONAL, and under passphrase, enter your desired password for wireless connection, take note of it and please be reminded that its case sensitive.
- click save settings.
for your wireless computers, if adapters enabled and working fine, on the system tray you should have an icon for the wireless connection, doubles click on it and it will pop for the wireless connection window wherein you can see the name that you set on your router, all you have to do is select the name click on connect and it should ask you enter a password, enter the passphrase you set on the router and click connect. then check if you can go online, if yes do the same thing with other computers.
Have a great day ahead.
Sep 28, 2008 | Linksys WRT160N Wireless Router
Wpa encryption for wireless router snb5600
Hi
That's not a lot of info to go on, but let's try: first, you've got to set the router up for the WPA encryption and put the passphrase in there. You have to do that set-up while you're connected by wire to the router otherwise you'd lose the wifi connection half way through the process. Once the router is set up, do the matching thing on your computer, switch on wifi, and disconnect the cable from your computer to the router. Get back if that's what you'd already done and let us know what stages worked and at what point it fails.
Jan 25, 2008 | Computers & Internet
Wireless router
Do you see a little monitor Icon in the lower left bottom. If so go ahead and right click on it and select wireless connections , If not open network connections, now you should see detect wireless networks, Click on that,( IF SO ) Now you should get a window that shows your wireless connections, Select the network you have by clicking on it, and then in the lower left of the window Opened you should see a connect button, select that, you should be able to go online now if not let me know, there are some other things we can try to get you up and running just write back here if it does not work and as soon as I get this I will get back to you. I am sure its nothing we can't solve. Ok thanks bear001
Dec 23, 2007 | Linksys Wireless-G WRT54G Router
NetGear RangeMax  WPN824 Wireless Router (WPN824NAR) Logo
99 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
